Both sides are ~long gone~ and the single 12V was held in place with "radio strapping" and a couple of Michigan license plates. GOR!
Now fabricating (the highbrow equivalent of MacGyverin' it?) a spiving aluminum base and hold-down scheme for the purpose. Should be a fine replacement for the original. Swapping the electron flow to a negative earth, the thought being I then have a choice of audio devices available. Thought about fully enclosing the battery in a liner, not sure it'd be beneficial other than as a dust/dirt/water barrier. Any opinions or experience with those liners from "the usual sources"? I did contain the Lotus Cortina battery in one years ago and it seemed to be a good deal. Kept the corrosion in the boot down after that.
