tahoe healey
Well, I'm up here in Oregon trying to get the gear box fixed. It turned out the PO left out some ball and spring assembly that holds the first motion shaft from moving. It moved and about 1/3 of the end of the shaft got ground away.The problem is that it does not seem to be available any where for the early BJ8. Bill Bolton (great guy) is trying to find one from his usual sources with no luck. We are talking about adding some metal and having it machined off. When the shaft moved it bent the cage the roller bearins were in and moved them to a 30 degree angle causing the noise I heard as well as the end of the shaft being ground off. I guess it could have been worse if the shaft came loose and distroyed everything else in the box. : /ubbthreads/images/graemlins/mad.gif( /ubbthreads/images/graemlins/mad.gif /ubbthreads/images/graemlins/pukeface.gif
