Are 1275cc cylinder heads date coded?
Vespa
Member
I just found out today that MGB cylinder heads have the date of manufacture (or, at least the date of casting) on them, and I was wondering if 1275cc heads have the same thing?
- Paul B.
Spridget64SC
Not that I am aware of after 35+ years of working on the A-Series. Some of the castings for the 1275 heads have numeric and alpha codes that may be a date code for that specific foundry. But, these castings don't come up frequently enough to discern anything meaningful. Usually see something like '07B' or '04D' inside the valve cover.
For general information, a 12G940 non-smog head would have used on 1275s sent to the USA in 1967. The 12G1316 smog head was used on the 1275 USA 1275s from 1968 to 1974. These smog heads came in two varieties. The early ones (1968-1971) had the better flowing exhaust ports. The later ones (1972-1974) have the restricted exhaust ports with the cast iron bosses aroung the exhaust valve guide. HTH - Mike Miller
dklawson
You can also order later 12G940 heads from the U.K. in both "small" and "large" valve configurations. They were used on the 1275 (including A+) for many years. I currently have a big valve 12G940 head on the Mini as its original AEG163 head had deeply recessed valves when it was time to rebuild the engine. Some of the later 12G940s are distinguished by a "relieved", rough cast area around the T-stat housing as opposed to the continuously flat surface found on a lot of the earlier heads. I have not seen date codes on any of the heads I have seen either.
Those late model Mini 12G940 heads with the bigger intake valves are notorious to crack in between the valve seats. I've seen it numerous times.
dklawson
I remember you saying that before Hap. The cracking between seats is certainly well documented for the earlier big valve head, AEG163. Do you think the cracking you have seen is more common on a 12G940 on a race engine than a street engine?
dklawson
Update.
I posted a thread on a U.K. board I frequent asking about the reliability of the big-valve 12G940 castings. I received replies from several racers and a couple of engine builders including A.C. Dodd.
Their unanimous reply was that the factory big valve head is OK with its 35.7mm intake and 29.4mm exhaust valves. However, they also said that the heads do frequenly crack when larger valves are fitted. In particular they mentioned that it is not uncommon for builders such as Slark to fit 37mm intakes and 31mm exhausts which do commony have cracking problems. Dodd's comments were that any valve larger than the stock factory size puts the head at risk.
I am not disputing what Hap has seen but I wonder (based on the comments from the U.K.) if the cracked 12G940 heads he has seen have had larger valves than what the factory installed.
A Honda bike cbr 600 f3 cylinder head on 1275cc Spridgets 2
J Carburetors for a 1275cc Engine Spridgets 11
theleisure Seized 1275cc, What the...? Spridgets 22
jaegzie No Power [Slow] through starter 59 Bugeye 1275cc Austin Healey 4
R MG Midget 1275cc restoration and preparation Spridgets 3
abarth69 What's the average cost to rebuild 1275cc Spridgets 22
abarth69 Wife's 1275cc engine help Spridgets 4
6 What size would a 1275cc bored .030 be Spridgets 3
abarth69 1275cc engine question Spridgets 28
saabmp3 1275cc HP and torque figures Spridgets 8
K TR2/3/3A Retorquing the Cylinder Head after the initial torquing.? Triumph 23
S TR2/3/3A Rebuilding a cylinder head Triumph 10
petnatcar Cylinder Head Nuts - Tightening Sequence Austin Healey 2
L Removing Master Cylinder Without Paint Damage Austin Healey 27
K TR2/3/3A Checking a cylinder head with a straight edge to see if it's warped? Triumph 22
K TR2/3/3A Cylinder Head Bolt question.... Triumph 3
W Cylinder compression Hillman super minx Other British Cars 15
Celtic 77 MGB Mystery cylinder head attachment. MG 4
K TR2/3/3A Cylinder head removal and valve adjustment Triumph 2
Donald1107 TR2/3/3A low cylinder compression Triumph 12
6 Master Cylinder Rebuild Spridgets 6
K New Clutch Master/Slave Cylinder Austin Healey 1
D TR2/3/3A cylinder head oil plug bolt size Triumph 6
wkilleffer MGB 1974 MGB clutch master cylinder questions MG 1
Racer-X- Frame mounted power brake pedal/booster/master cylinder kits for RHD cars? Restoration & Tools 1
S TR2/3/3A rear wheel cylinder Triumph 1
AUSMHLY Reduced-Shank Cylinder Head Studs Austin Healey 0
AUSMHLY Cylinder Head Studs Austin Healey 3
AUSMHLY Cylinder Head Input/Exhaust Circlip/Split pin Austin Healey 3
Got_All_4 TR6 Which Clutch Master Cylinder Fork is for TR6 Triumph 4
bighealeysource Master Cylinder Installation Austin Healey 9
bighealeysource BN2 Master Cylinder Austin Healey 91
prb51 100-6 Brake Master Cylinder Bore Austin Healey 5
bighealeysource Brake Master Cylinder Austin Healey 27
KVH General Tech Rusted Cylinder Head Freeze Plug--WOW Triumph 16
AUSMHLY BJ8 Cylinder Head Installation Austin Healey 6
A Brake Master Cylinder Freeplay Austin Healey 11
SNClocks Master Cylinder Bore Diameter Spridgets 0
W replace rigid master cylinder lines with flex. Spridgets 2
T TR2/3/3A cylinder head ,valves and springs Triumph 0
K TR2/3/3A Oil leaks at two front cylinder head studs? Triumph 3
AUSMHLY BJ8 Cylinder Head Re-Torque Austin Healey 26
6 Master Cylinder Actuator rods Spridgets 2
BoyRacer 6 cylinder flywheel on a 100 engine? Austin Healey 0
6 Master Cylinder Install Spridgets 5
Patrick67BJ8 Cylinder Compression Checks Austin Healey 30
S MGB Mgb with nissan cylinder head. I am a new member, introduction and help MG 1
R TR6 Rear brake wheel cylinder fitment Triumph 5
