TR2/3/3A Apron support and pin/latch assembly TR3
Tr3aguy
Guys,
I need a breakdown or picture of the spring pin assembly the latch or holds up the bonnet. It is attached to the support brace that attaches under the apron support.
Also what color is the apron support supposed to be?
Thanks
TexasKnucklehead
Something like this? I'd guess it should be the same color as the body of the car, but mine is black (now).
Geo Hahn
Designed by the same guy who did the Claymore mine.
I, too, think body color is correct - though, of course, the paint will wear off pin with use.
TexasKnucklehead
Great. I know how helpful a picture can be. That assembly is one of those that seems obvious when it comes apart, but after it's painted is very difficult to tell how it went together.
It's finally getting cool enough to go into the garage. I don't think it was over 95 yesterday, but I've got myself involved in a few other projects and the TR3 is buried again. I have made some progress with body panels, and have brackets for seat belts ready to be welded. Both outer rockers and dog leg bottoms have been fitted as well as one rear fender patch. Soon I'll start welding. I wasn't expecting so much reforming of replacement parts. Progress is slow, but coming.
Vaark01
JP,
Body color is the correct answer. However as Geo says, the paint on the pin will scrape off with use. I took the paint off my pin and polished it as best as possible. It looks nice.
Paul
Geo Hahn
When reassembling I probably used zip ties or dental floss or such to hold the spring in a compressed state until all was secure, then cut & set it free.
Here's a pic (why did I leave those bolts unpainted?):
PSUTR3B
Why leave the bolts unpainted? Because it looks good!! I know at the factory they were painted but most of us painted the wings, apron, etc off the car and then assembled. That latch was toward the end of assembly. Brushing in the bolts and washers would be a royal pain and I just think they look better unpainted--assuming that is the way they were all left.
The only clear memory of assembling the latch is that it was not easy and and took more than one effort. I don't think I painted the pin.
Gary
Moseso
Awww! Where's the fun in that? The last time I did it (out on the driveway) I shot bits of it into the neighbor's yard -- twice -- before finally getting it to go together. :crazyeyes:
TR3driver
Great Pumpkin - R.I.P
tinman58
The big washer on the bottom of the spring is somewhere in the attic of my garage! Went flying while trying to assemble it. I ended up using a big fender washer.
CJD
You know, I've been looking at those 2 little side brackets for a year wondering where they go. Mystery solved! Very helpful pics!
John
MGTF1250Dave
Aloha JP,
If you want to avoid the excitement of shooting pieces around the garage or over to your neighbor's yard you can try this. Drill a small hole through the bottom of the plunger about 1/8" from the end and use a cotter pin to hold it in the assembly. My plunger was also damaged by vibrating against the top plate of the housing to the point a large slot was worn into it. I had to weld it up and grind it smooth as a repair. To prevent that from happening again I used a nylon gromment by enlarging the hole in the top plate. Here are some photos:
F TR2/3/3A Tie member[front apron support tube] Triumph 11
71TR6 TR2/3/3A TR3A Wing to Apron Mismatch Triumph 9
H TR2/3/3A rear apron Triumph 2
C TR2/3/3A History of apron badge Triumph 3
J TR2/3/3A Front apron position Triumph 9
D TR2/3/3A front Apron fitting Triumph 5
S TR2/3/3A sections meet on the apron Triumph 3
M TR2/3/3A Late 57 Production with a Small Mouth Apron Triumph 16
R TR2/3/3A Removal of Small Mouth Front Apron Triumph 4
S TR2/3/3A tr3 front apron body work Triumph 9
K TR2/3/3A The "air vent"on the lower part of the front apron below the grille.... Triumph 5
MGTF1250Dave TR2/3/3A Rear Apron Replacement Triumph 2
Tinkerman TR2/3/3A TR3 A 1960 adjusting apron Triumph 4
S TR2/3/3A tr3 apron Triumph 3
toysrrus TR2/3/3A "WANTED": TR3 Small Mouth Front Apron Medallian Triumph 14
S TR2/3/3A grill and apron opening Triumph 18
Tinkerman TR2/3/3A 1960 TR-3A Hood to Apron Fitment Triumph 13
GTP1960 TR2/3/3A Weather seal between apron & wings? Triumph 4
Tinkerman TR2/3/3A Apron fitment Triumph 10
D Front apron panel on BJ8 Austin Healey 4
Tinkerman TR2/3/3A Apron letters "TRIUMPH" Triumph 5
Tinkerman TR2/3/3A Apron installation 1960 tr3 a Triumph 11
J TR2/3/3A Hood lift to front apron, what size are the screws that go from bottom up? Triumph 10
A TR2/3/3A Triumph tr3a Apron removal Triumph 33
J One of you guys had great pictures of front apron Triumph 20
A TR2/3/3A TR-3A Apron letter at last Triumph 3
M_Pied_Lourd TR2/3/3A 3A Front Apron Question Triumph 17
T TR2/3/3A The light came on: my TR3 rear apron. Triumph 12
J TR2/3/3A TR3 Rear Apron Replacement Triumph 4
B TR2/3/3A Need TR3B front and rear apron, sidescreens Triumph 19
RedTR3 TR2/3/3A TR3 Apron Removal/Radiator Replacement Triumph 10
K TR2/3/3A Mounting TR3 Body to frame with front apron on? Triumph 4
Gordon_Dedrick TR2/3/3A TR3A apron badge Triumph 7
M TR2/3/3A TR-3A - Front Apron Medallion Triumph 2
M TR2/3/3A Fitting front apron TR3 Triumph 12
L TR2/3/3A TR3A - Front Apron/Air Duct Triumph 3
L TR2/3/3A TR3A - Front Apron/Bonnet Prop-Assembly Logistics Triumph 4
G Small Mouth Apron Triumph 2
R TR4/4A TR4A Front lower Apron Triumph 2
luke44 TR2/3/3A TR3A Front Apron - Lower Area Triumph 3
A removing front apron Triumph 10
TR3driver Smallmouth apron wanted? Triumph 0
tlthorne T-Series TD front apron MG 3
A TR2/3/3A TR3A apron picture needed please Triumph 4
T TR2/3/3A TR3 front apron Triumph 6
mountainman TR2/3/3A Tr3 Front Apron Triumph 17
angelfj1 TR2/3/3A TR3A - grill to apron attachment Triumph 12
Tinkerman TR2/3/3A TR3A Front Apron Assembly Installation Triumph 1
G Small mouth apron Triumph 0
