Anyone got a 1500 transmission lying around?
JPSmit
I asked Bill one day too late. Here's what I am looking for. I am trying to figure out a 5 speed swap - though I haven't actually decided if I even want to go that route. At any rate, I can measure most everything with the transmission in situ, but, if someone had a 1500 bellhousing and felt like tracing the shape and holes of both ends onto a piece of newsprint or some such paper and mailing it to me I would be grateful. I don't want to pull the engine for a maybe.
PM me for my address if it's something you could do. Thanks all
Jp,
I have a bell housing in a box out in the shed. could probably get to it tomorrow.
m
Morris
I too have a bell housing in the shed. I may be able to get it out this weekend if mark does not beat me to it.
wonder of JP got snowed under...
m
JPSmit
JPSmit
kellysguy said:
what you got in mind? Top Secret?
no real secret - and no real plan either.
Thinking about 5 speeds
this is a T9 conversion - which still requires body mods which I really don't want to do. On the plus side it is much cheaper than the riverside conversion.
On the other hand, I keep reading this.
https://en.wikipedia.org/wiki/George_Turnbull_(autoindustry_executive)
basically, the line goes this way - existing 4 speed is adapted from the Marina, Hyundai Pony is adapted from a Marina - could it be possible that a Pony 5-speed could fit a Midget?
Now, Pony 5 speeds are about as common as 210 5 speed but much less costly.
All that being said, before I even try to look and certainly before I buy, I'd like to have some reference points to measure.
That's about all there is to it. so, either of you want to send it it would be awesome!
As for the snowed in, not sure if we dodged the bullet but we mostly had rain. about an inch of snow is all and it is mostly gone. That being said was supposed drop off my son at work and teach a class at 9 am, arrived at 10:50, the traffic was unbelievable, in part because I shouldn't let the non-driver choose the route. But, the ice was awful. On the bright side was supposed to do a presentation tonight and we canceled due to the weather.
Morris
If you got the time and money to experiment with this, consider the Volvo M47 5 speed. Here's my logic on this one: The Volvo M47 is the same transmission (more or less) that was used in the TR7... which used the same 4 speed as the Midget 1500. The Volvo transmission in theory will be much easier to lay hands on. It was used in the 740 and 240 from the 80's to the mid 90's.
JPSmit
JPSmit
Happy to look into it - but (hint hint) someone still needs to flip a coin and decide who traces out the bell housing :smile:
I can see the box that it is in, gettin to it? well you havent seen my shed...fraid i was a bit busy movin snow yeserday. i do have access to some large format printing paper at work. I will dig it out in the morning.
m
JPSmit
JPSmit
SilentUnicorn said:
I can see the box that it is in, gettin to it? well you havent seen my shed...fraid i was a bit busy movin snow yeserday. i do have access to some large format printing paper at work. I will dig it out in the morning.m
please wait on Morris - nothing to dig out in Texas - let's wait for his reply
dklawson
Are you sure about that? The Spitfire 1500 and the Midget 1500 gearboxes should be the same. It's my understanding that while some of the parts are common between the TR7 box and the Spitfire box they are not interchangeable assemblies.
Regardless of what else you consider when looking at the gearbox selection, keep the clutch components and gearbox input shaft splines in mind. It would be very disappointing to layout everything and in the end learn you can't find a friction disk that will fit under your 1500's pressure plate.
Morris
<div class="ubbcode-block"><div class="ubbcode-header">Quote:]please wait on Morris - nothing to dig out in Texas - let's wait for his reply[/QUOTE]
'cept the mountain of junk piled on top of the bell housing. :frown: If you want that bell housing... and can afford to ship it, I will drop it off with the UPS or FedEX guy on Monday.
OK I am going in...
Give me two hours if you dont hear from me by then- send in the rescue team
Cover Me!!
JPSmit
JPSmit
'cept the mountain of junk piled on top of the bell housing. :frown: If you want that bell housing... and can afford to ship it, I will drop it off with the UPS or FedEX guy on Monday. [/QUOTE]
NO NO NO - don't want the bell housing - I have that! Just the tracing on the two ends with outside shape and hole locations - fold up paper, put in envelope - send.
JPSmit
JPSmit
SilentUnicorn said:
OK I am going in...
Cover Me!!
Noooooo save yourself run man run!
JP
How is this?
G
SilentUnicorn said:
OK I am going in...
Cover Me!!
u-ohhh., better call out the dogs...it's been a while...
Morris
You know what I have that I can send you that will be a lot cheaper to ship than the bell housing? The back engine plate... Heck, I think even I can afford to ship that. It's on me if you want it.
kellysguy said:
SilentUnicorn said:
OK I am going in...
Cover Me!!
The dogs helped! I could hear them Howling..and got my bearing back.
JPSmit
JPSmit
SilentUnicorn said:
JP
How is this?
perfect - all I need, thanks so very much - I'll PM my address
simon1966 Anyone got a 100 being transported? Austin Healey 10
F J hooks an wing nuts for attaching hard top to body BT-7 - anyone got photos? Austin Healey 5
CJD TR2/3/3A Anyone got a TR2/3 Frame?? Triumph 56
weewillie my son got this yesterday and if anyone can help Other Cars 6
pjsmetana Fuel Filter, anyone got a part # for this thing? Triumph 11
RickB Anyone got a couple of these to share? Spridgets 2
JPSmit anyone got a radio? Spridgets 11
B Anyone got a 75 Speedo Cable? Spridgets 1
7 MGB-GT Anyone Got a Webasto Folding Sunroof in Their GT? MG 6
G AAARRRGH - anyone got a tip for these bushings? Triumph 11
TXCoyote Anyone got a LT77 for sale Rover / Land Rover 0
soren_ak hi gang - anyone got any info on this top. Austin Healey 5
Rob_Edwards Anyone else got one of these? MG 25
jlaird Oh me anyone got an extra 6 grand? Spridgets 0
A Anyone got a Sunbeam motorcycle ? Sunbeam (Rootes) 3
AngliaGT 1997 Miata - Anyone Have a Picture on How to Mount the Front License Plate Bracket? Other Cars 12
AngliaGT Anyone Plan on Attending the SCCA Runoffs at VIR Next Week? Racing 6
R TR2/3/3A Does anyone know the paint Code for british Racing Green for a 1954 TR-2? Triumph 12
Celtic 77 Anyone recall Hobo Hill in New York State? Racing 0
T Rut's 4 speed shifter modification - anyone have knowledge? Spridgets 3
JPSmit Gear reduction starters anyone? Restoration & Tools 5
L Can anyone tell me what car this is from please? Other Cars 0
DrEntropy Show this to anyone under 40... Restoration & Tools 9
K TR2/3/3A Can anyone confirm that if you replace the ammeter with a voltmeter ( generator removed and alternator added) that you...... Triumph 5
D Can anyone identify this vintage car? Other British Cars 17
T Can anyone identify this bumper Spridgets 5
AngliaGT Morgans - Anyone Heard From John Sheally lately? Other British Cars 13
johntennyson Anyone Know These Guys? Or Remember Sprite-Midget Owners' Group? Spridgets 29
K TR2/3/3A Anyone remember the "rattling gear shift" fix? Triumph 8
roscoe Comments, anyone? Austin Healey 3
BillyB62 TR2/3/3A Anyone seen a valve cover like this Triumph 0
T TR2/3/3A Has anyone designed a hand brake warning light for the TR3? Triumph 3
Pythias Sprite Winged Bonnet Badge.... ANYONE? Spridgets 16
B Anyone have a Europa Twin Cam for sale? Lotus 6
B Anyone have spark advance data for Piper camshafts? Spridgets 1
Got_All_4 TR5/TR250 New Hazard Relays Does Anyone know How to Hook Up Triumph 7
steveg TR6 Metal Dash - does anyone make one? Triumph 13
T Powertrain locked up three times whilst driving today - anyone have thoughts? Spridgets 15
S TR2/3/3A Anyone care to share their bondo applying techniques Triumph 20
DrEntropy MGB Clevis pins, anyone? MG 3
69MGC Wanted Anyone know this guy? MG Classifieds 2
B Does anyone still make or sell a quality condenser? Austin Healey 14
W TR6 Anyone add Exhaust tips to standard exhaust Triumph 4
K TR2/3/3A Anyone have a picture of the crankshaft pulley.... Triumph 1
K Anyone racing a TR3? Racing 5
S General TR Can Anyone identify this TR Triumph 3
C Anyone know where to get one of these? Austin Healey 6
Grantura_MKI T-Series MG TD anyone? MG 5
