Anyone familiar with GM Electronic Climate Control
wkilleffer
Hey everyone,
I've posted a post similar to this on an Oldsmobile-related forum, but it doesn't seem to have alot of traffic. I'm sure there are other forums out there that could be helpful, but I'm missing them somehow.
Not too long ago, I did some work on my 1993 Cutlass Supreme Convertible that got the Electronic Climate Control back into an operational state.
The problem is that the PO removed the actuator motor from the heater blend door actuator arm over the summer and moved the arm to full cold. Well, this was great for summer, but it's colder now. He kept the old part so I would have something for a reference when replacing it.
I ordered the replacement from rockauto.com and installed it yesterday. I dialed the temp up to 90, watched the motor move, then opened the blend door, then put the motor on the arm and fastened it down. That was one of the most PITA jobs I've ever done on a car... The motor appeared to be responding to input from the ECC control panel, so I didn't give it much thought after I was done.
The problem now is that it seems to get stuck on heat. It was cooler last nite, so I dialed in a little heat. When I tried to turn the heat down, nothing happened. It was like it had gone to full-on, boiling hot heat. I even pushed the Cooler button all the way down to 60, and the fans came on full speed and blew nothing but extremely hot heat.
I also tried installing it by unplugging the actuator and adjusting the blend door arm in such a way that it matched the actuator gear cam, put everything back together, and plugged the actuator in last. Then, I started the car. The climate control was off, and I had a fingertip on the actuator. I felt it activate and stop. I waited about a minute, and turned the climate control on. Once again, regardless of temperature setting, the vents blew nothing but hot air.
What have I done, or not done, that was wrong? I know it's installed in the right direction cause it will only fit one way.
Any suggestions would be appreciated, as well as directions to other potentially useful forums.
Thank you,
-Bill
Banjo
Not real familiar, but here's some info.
Press OUTS TEMP and BI-LEV at the same time to enter the diagnostic mode. Press any mode button to get out.
a 2 digit code is a hard fault, a 3 digit code is an intermittent fault.
00= nothing wrong (At least in the processor's eyes)
01 or 101 in-car air temp sensor short
02-102 in car air temp sensor open
03-103 outside air temp sensor short
04-104 outside air temp sensor open
(one of these sensors may be the problem).
05 or 105 air temp valve motor circuit
09 or 109 serial data line failure
to reset codes pull the ELEC 15-amp fuse in the instrument panel fuse block.
hope this helps.
K
KSIS
this sounds like the same system on the newer SAABs with the error codes.
racingenglishcars
Seems to me that by installing the arm and motor when temperature is set to 90 deg and heat flap full open, you are assuming the two are congruent. This may be incorrect, as you have probably already guessed, however it may not be too far off.
As you said, the actuator is responding. It doesn't look like that is a problem then. It really sounds more like the temperature feedback mechanism isn't working properly. When the output temperature gets hot and the interior warms up, you would expect the actuator to reduce heat. If it isn't moving towards cold, maybe it just doesn't know that the interior is already warm enough.
I don't know anything specific about this system, just general control system knowledge. To maintain the temperature, it must measure the temperature, compare it with a target temperature and send a "error" (deviation) signal to an amplifier which powers the actuator. A couple things can go wrong. Sensor not giving signal, comparator not comparing the temperature signal to the target, amplifier not working, actuator working reverse from that desired.
In the last case I can only describe an imaginary scenario:
It could be that when the interior gets hot, the resulting actuator motion would move for example out. If the flap is made so that when the actuator moves out then temperature gets hotter, then the control system is reversed. It would (in this imaginary case) need reversing so that when the actuator moves out, the flap would move towards the colder direction.
wkilleffer
wkilleffer
Ok, here's what happened:
I started the car this morning and did the diagnostic check as described by Banjo. Got a 00, then a 05. I didn't have the actuator plugged in at the time. The interior got hot pretty fast.
This afternoon, I pulled the 15amp fuse and plugged the actuator in. Then, I replaced the fuse and started the car. The climate control turned itself on at 75degrees. I adjusted the temp and *think* I heard the actuator responding, but not sure. Either way, the interior quickly got too hot. I tried the diagnostic check again, and got a 00.
I'm going to have another look at the FSM and see if I've missed something. Thanks for all the assistance so far.
-Bill
wkilleffer
wkilleffer
Ok, an update:
I figured out that I'd been trying to install the actuator onto the flap arm the wrong way. A little fiddling, and I got it on correctly. This *almost* solved the problem. The actuator responded to input from the ECC control panel.
But while driving earlier this evening, it seemed stuck on hot. So, I did the diagnostic thing, and got a code 105, which is the intermittent air temp valve motor circuit fault.
Trying to decide if this warrants checking the wiring in the area of the control panel. Someone did some really bad stuff in that area when they installed a fancy radio, amp, and sub. My attempt to put everything back to rights might have resulted in a less than ideal connection.
But it seems as though I'm on the right track.
Thanks, y'all.
Banjo
Here's hoping William. Sounds like you're making progress.
racingenglishcars
racingenglishcars said:
... actuator working reverse from that desired.
Looks like you got it :smile: Hurray.
wkilleffer
wkilleffer
Well, I kinda got it....
It still wants to default to heat, and now, even with the temperature set at the lowest setting of 60degrees, it will blow boiling heat for several minutes before switching to cool.
The PO said that was why he unhooked everything, and that it would switch to hot from cold on a hot summer day.
Makes me wonder if the interior temp sensor may be bad, even though the diagnostic thing isn't showing any codes. Exterior sensor seems accurate.
Banjo
In 93 the diagnostics were really just for an aid. they weren't extremely accurate. You may have a problem that is just outside the "fail" parameters of that system.
wkilleffer
wkilleffer
The FSM mentions being able to enter a deeper level of checks and diagnostics by pressing the WARM button after entering the OUTSIDE TEMP/BILEVEL diagnostic mode. Doesn't give many details. Any idea of what can be done in there? Cause alot of problems?
T Anyone familiar with "True Spark" distributors? Triumph 10
B anyone familiar with these? MG 3
K Anyone racing a TR3 and familiar with cam profiles Racing 0
Basil Hye-Dra-Cyl Brake cylinders - anyone familiar? Jaguar 0
AngliaGT 1997 Miata - Anyone Have a Picture on How to Mount the Front License Plate Bracket? Other Cars 12
AngliaGT Anyone Plan on Attending the SCCA Runoffs at VIR Next Week? Racing 6
R TR2/3/3A Does anyone know the paint Code for british Racing Green for a 1954 TR-2? Triumph 12
Celtic 77 Anyone recall Hobo Hill in New York State? Racing 0
T Rut's 4 speed shifter modification - anyone have knowledge? Spridgets 3
JPSmit Gear reduction starters anyone? Restoration & Tools 5
L Can anyone tell me what car this is from please? Other Cars 0
DrEntropy Show this to anyone under 40... Restoration & Tools 9
K TR2/3/3A Can anyone confirm that if you replace the ammeter with a voltmeter ( generator removed and alternator added) that you...... Triumph 5
D Can anyone identify this vintage car? Other British Cars 17
T Can anyone identify this bumper Spridgets 5
AngliaGT Morgans - Anyone Heard From John Sheally lately? Other British Cars 13
johntennyson Anyone Know These Guys? Or Remember Sprite-Midget Owners' Group? Spridgets 29
K TR2/3/3A Anyone remember the "rattling gear shift" fix? Triumph 8
roscoe Comments, anyone? Austin Healey 3
BillyB62 TR2/3/3A Anyone seen a valve cover like this Triumph 0
T TR2/3/3A Has anyone designed a hand brake warning light for the TR3? Triumph 3
Pythias Sprite Winged Bonnet Badge.... ANYONE? Spridgets 16
B Anyone have a Europa Twin Cam for sale? Lotus 6
B Anyone have spark advance data for Piper camshafts? Spridgets 1
Got_All_4 TR5/TR250 New Hazard Relays Does Anyone know How to Hook Up Triumph 7
steveg TR6 Metal Dash - does anyone make one? Triumph 13
T Powertrain locked up three times whilst driving today - anyone have thoughts? Spridgets 15
S TR2/3/3A Anyone care to share their bondo applying techniques Triumph 20
DrEntropy MGB Clevis pins, anyone? MG 3
69MGC Wanted Anyone know this guy? MG Classifieds 2
B Does anyone still make or sell a quality condenser? Austin Healey 14
W TR6 Anyone add Exhaust tips to standard exhaust Triumph 4
K TR2/3/3A Anyone have a picture of the crankshaft pulley.... Triumph 1
K Anyone racing a TR3? Racing 5
S General TR Can Anyone identify this TR Triumph 3
C Anyone know where to get one of these? Austin Healey 6
Grantura_MKI T-Series MG TD anyone? MG 5
HealeyRick Why Would Anyone Butcher a Healey with a V8? Austin Healey 26
K TR2/3/3A Anyone running NGK spark plugs? Triumph 26
K TR2/3/3A Anyone heard of an oil additive called 'Molyslip E" ? Triumph 5
Basil SS100 anyone? Jaguar 5
Jim_Gruber Recovering Dashboard - Anyone tried this approach? Spridgets 4
T TR2/3/3A Anyone running tubeless radials on TR3 steel radials? Triumph 2
R General TR Anyone going to TRA in North Georgia? Triumph 0
R Wanted Anyone have one of these? Triumph Classifieds 6
mt10flyer TR2/3/3A Anyone race prepped a TR3? Triumph 3
Rut TR4/4A Sorry Top anyone? Triumph 0
Got_All_4 General TR Anyone know where to get one of these? Triumph 5
