Any trick to getting the bump stops off
jackag91
I need to replace the bump stops on my trailing arms (TR6) and I have no idea how to go about it. The rubber was pretty worn and just feel apart when I tried to un screw it.
Any suggestions?
PeterK
Try PBBlaster and heat with a torch around the outside of the threads. Then clamp the remaining bump stop with waterpump pliers or vice-grips and crank it out.
PeterK
PB Blaster is available in most auto stores, Walmart too I think. It's a spray penetrating-type oil that will help loosen stuck bolts, rusty bolts and the like. Work great with heat. Ventilate the air.
Scott_Hower
I love PB Blaster.
I have no less than three cans at any given time. I've tried them all, Kano Labs Kroil, LiquidWrench, CRC, Rust Reaper. Pretty much the same thing, but PB is much easier to find.
The stuff really stinks.
Twosheds
And besides, PB Blaster will melt a styrofoam cup!
You never know when you might have to melt a styrofoam cup.
hondo402000
be careful heating them up, the trailing arms are AL and unlike other metals it doesnt glow when hot it just goes to liquid
J
jackag91
Well I got one off just fine, the other one broke....now I have a stuck bolt in arm.
I guess I will let it sit with some of the pbblaster in it and try to extract it tomorrow.
PeterK
Tomorrow, heat around the outside of the threads with a propane or MAPP torch. This will expand the threaded hole and the bolt will come out easier. Work the bolt out then turn it back in a little, then back out a little more as you work. Keep the area hot with the torch. Aluminum doesn't melt until around 1400F so with a propane torch it would be hard to melt it, but don't overheat it, just get it hot enough to get the bolt out.
PeterK
There's actually another method you might try. Heat the area (as above) and then rub the broken bolt with a wax candle until it melts down into the threads. The wax gets into the threads and forces the bolt out. I've never tried this but hear that it works.
J So what is t he trick for getting the ujoints out? Triumph 3
RobSelina what's the trick to getting a steering wheel off? Spridgets 36
mctriumph TR2/3/3A Old trick on SU's Triumph 5
K TR2/3/3A The grease gun brake caliper piston removal trick..... Triumph 6
Basil Neat trick for reading oil level Restoration & Tools 7
L TR2/3/3A Any trick to removing TR3 doors? Triumph 12
N TR2/3/3A Cheap trick Triumph 5
Graham H TR2/3/3A Randall's Trick Triumph 10
W TR2/3/3A Tell me there is a trick to removing lower control arm pin... Triumph 45
S Ramps. What's the trick? Spridgets 23
T TR4/4A Composite vs cooper head gasket with Randall's "trick" Triumph 6
Got_All_4 TR5/TR250 Rope trick on a broke valve spring Triumph 8
S Trick or Treating Spridgets 5
T TR4/4A Outer tie rod ends - what's the trick? Triumph 7
S So, what's the trick... Spridgets 17
T TR6 tr6 water pump trick? Triumph 4
H Trick needed - for body curve Austin Healey 12
Henson80MGB Trick to remove rubber hose to Slave Cylinder? MG 19
C Trick Midget Mk1 Racecar Spridgets 15
P help: trick to snap and unsnap soft top ? Triumph 11
glemon 11/64s drill bit tranny mounting trick Triumph 10
M Weber Carb trick Spridgets 1
BOBBYR Trick question . See what you think. Austin Healey 10
W A neat trick Spridgets 1
Jim_Gruber Rinstalling Beehive Lamps on BE what is the trick Spridgets 7
RickB Any trick to replacing shackle bushings? Spridgets 5
J What the trick to the steering column bushes? Triumph 6
jlaird Very slick trick Spridgets 3
zimmy my new clutch bleeding trick Spridgets 10
Jim_Gruber Removing Aluminum Channel on top of door - Trick? Spridgets 5
W New or another ebay fraud trick Triumph 8
jlaird For my next trick Spridgets 5
P Nut and wire Trick Triumph 9
E TR6 TR6 Front Suspension... Is there a trick? Triumph 8
aeronca65t MGB Semi-trick MGB MG 7
G Out with the rubber-hose-to-the-ear trick..... Triumph 10
tomshobby Kind of a neat trick. Triumph 4
aeronca65t Trick Pontiac GTO Other Cars 3
A Spitfire Trick to remove 78 Spit carb? Triumph 4
G Neat trick Triumph 5
Alan_Myers TR2/3/3A TR2/3/4 cooling trick? Triumph 1
Z Rope trick works! Triumph 10
J Exhaust Valve - dollar bill trick! MG 20
Steve Secret door trick MG 1
Basil Rope Trick Triumph 2
S TR2/3/3A getting the circlip off 3rd gear Triumph 9
Celtic 77 MGB Getting closer! MG 5
JohnGone MGB Help getting my 1980 MGB to pass CA smog test MG 19
J TR4/4A Getting electrical shock from horn button when using the horn. Triumph 9
