Any pictures of Rx7 E-brake cables?
toysprite
Hi all,
So I started working on my sprite again. Been a while. And whats really weird is that all the problems I had before are still there. Hummm. I thought maybe they would just go away if I walked away for a while. Anyway, I installed an rx7 axle and all is well except the E-brake. I cobbed something together that I thought might work but it was a miserable fail. So I know it's been done before and would appreciate a picture or a really good explanation on what was done.
The car is a 68 sprite and the axle is the non vented rotor axle.
Thanks for the help.
Jim_Gruber
Go to The Mite.com
. He's got pics of RX-7 Axle in his Sprite.And he got the E-Brake cable to work.
T
toysprite
Ok so I looked at the Mite. He uses a mechanical caliper for the E-brake. I'm just using the original Rx7 calipers. So I would still like to see what others have done using the Rx7 stuff.
Thanks
Jim_Gruber
Someone else did this. Was it Brandon/Branson someone in the MidWest dropping a 13B or was it a Toyota or Ztec engine into a Spridget. I seem to recall he fixed by coming in from a different angle. Like swapping L & R calipers or something so that E-Brake cable could come in from the bottom.Check on SpriteSpot.com under Lumps Section. There you'll find a build site for a 20A Toyota Swap and I recall him mentioning issues with E-Brake set up. I do remember E-Brake cable fed from the bottom hence my thought about swapping the rear calipers around. Let me know if that nugget stored in the back of my brain was correct.
T
toysprite
I didn't even think of Sprite spot. It was a guy that put the Ztec in. Lots of pictures. I think I might be able to figure something out now.
Thanks for the help!
Jim_Gruber
Another useful nugget from my cluttered brain. Glad I could
help.
Hamish Racing TR2/3/3A Pictures through a corner. Triumph 7
steveg TR6 Hood release pictures needed Triumph 22
A Disc Brake pictures Austin Healey 1
HealeyRick Disoriented Pictures FORUM Help 11
Cutrog1 Attaching pictures while editing FORUM Help 7
trrdster2000 Spitfire Added a few pictures to my Photo Album of the Spit6. Triumph 0
2 TR2/3/3A Non OD speedometer cable routing diagram/pictures. Triumph 7
T General TR Request pictures of TR3B & TR4 electric temperature gauges Triumph 15
Jim_Gruber Pictures of Clutch Slave Plumbing with Gerard's Kit Spridgets 4
T Trouble inserting pictures to post FORUM Help 2
V Last few months in the UK Pictures TVR 5
Drone Dog looking for pictures / info 62 BT7 Austin Healey 5
T TR2/3/3A Clutch and oil line Pictures requested Triumph 9
T TR2/3/3A Pictures of my TR3 with over riders on front Triumph 14
J pictures of a 3000 on a rotisserie ?? Austin Healey 5
K TR2/3/3A Auxillary dash switch pictures? Triumph 14
M Off Topic TRA National event pictures Triumph 6
T TR2/3/3A Before and after lever shock absorber pictures Triumph 12
V TVR Vixen S2 New Pictures TVR 1
J TR2/3/3A 1957 rear seat carpet pictures Triumph 7
B Longbridge 100-6 Throttle Linkage Pictures - Any Out There? Austin Healey 27
gbtr6 TR6 Need pictures of heater hose routing Triumph 0
T TR2/3/3A Requesting some Pictures for metal work Triumph 9
Basil TR2/3/3A Karls59tr pictures Triumph 9
B Rear seat backrest pictures Austin Healey 6
T TR4/4A Anyone have pictures handy of TR4a with TR6 steel rims? Triumph 13
S General TR British Car Show Pictures - Is there Interest in Posting? Triumph 7
Tinkerman TR2/3/3A Pictures needed Triumph 4
boxofparts TR2/3/3A Pictures of my own Garage Find TR3 Triumph 10
7 unable to upload pictures - Java problem? FORUM Help 7
RickB General Tech Need pictures showing how to connect choke on HIF carbs. MG 2
Randy Forbes Randy's Healey pictures links... Austin Healey 1
Basil Posting pictures on BCF Triumph Classifieds 0
Basil Posting pictures on BCF Spridgets Classified 0
Basil Posting pictures on BCF Jaguar Classifieds 0
Basil Posting pictures on BCF Other British Classifieds 0
Basil Posting pictures on BCF Austin Healey Classifieds 0
M TR2/3/3A TR3 progress pictures Triumph 26
D Pictures of Trailer hitch install on a BJ8 Austin Healey 0
J One of you guys had great pictures of front apron Triumph 20
drambuie Adding a backup fuel pump Anyone have pictures? Austin Healey 6
AH67 62 MKII Tri Carb, done with some pictures Austin Healey 9
cdsmith Pictures of brakes? Spridgets 3
66healey Aftermarket brake booster pictures Austin Healey 7
N Healey meeting - pictures Austin Healey 1
N Pictures?? Spridgets 2
Morris Dash pictures Spridgets 0
Randy Forbes Healey pictures... Austin Healey 17
B TR2/3/3A Need pictures of TR3B for reference Triumph 9
