Hi to all! I took my recently purchased 1966 BJ8 out for a shake down run of about 100 miles last week and had these questions about the use of the OD. The OD engages just fine when I flip the switch, but when I hit the gas hard at about 50 mph it drops out. It feels like hitting passing gear in an automatic drive car. As soon as I let the gas off a bit, the OD kicks back in. Is this normal?
Next, I have read on some of the older posts here that you should engage the OD while slowly accelerating. What is the proper proceedure to disengaging and can I leave the switch on while down shifting, even to 2nd gear?
Thanks,
Charlie
Thanks,
Charlie
Hi Guest!
