longbridgehealey
I'm about to install a 12v power source in my Bugeye. Years ago I disconnected the AM radio and capped the hot wire. As I recall the radio always had power whether the ignition was on or off, so this wire must be constantly hot. If I use it as my positive connection on the adapter, will I be setting up a slow drain on the battery, or would that only apply if I was using the adapter with the ignition off?
Thanks,
Larry
Thanks,
Larry
Hi Guest!
