kyreb1862
I started to install a new shift knob in my 77 B and I've run into a problem. My current shifter knob is a two piece one. The bottom part is retained by a round nut with a slot on either side. Apparently I need a tool with two prongs that will fit over the end of the shifter lever and engage the slots in order to be able to turn the nut. What have you guys used to do this little task?
Regards John
Regards John
