Ed_K
To get ready for the convertable top installation, I filled the old screw and nail holes in the four wood pieces with epoxy, then sanded. Lastly I painted the wood pieces with fiberglass to seal out moisture. The fiberglass cured hard in the container that I mixed it in, but it is still sticky on the wood pieces ? I guess since it was painted on in a thin coat, there is not enough material present on the wood surface to heat up and cure ? If I put the pieces in front of an electric space heater, will that create enough heat to cure the fiberglass coating that I painted on the wood ? Or will I be cleaning the wood pieces tommorrow with acetone to remove all of the uncured fiberglass resin ?
I guess I should have used something else to seal the wood other than fiberglass resin.
Hi Guest!
