Jim_Gruber
OK my Campbell-Hausfeld 30 Gallon 5 HP compressor has bit the dust. I was using and air hammer/chisel to remove ceramic floor tile and I'm guessing I overheated the motor and it's toast. It really did the job while it was working but wasn't up to the task.
Compressor turns freely but motor will not run, no thermal reset button that I can find on the motor and I show 120 VAC going into the motor with my VOM. Motor turns but guessing windings are burnt up.
Thoughts at this point, new electric motor from CH is $120.00/ with compressor i.e. turnkey about $200.00. Now compressor was not that stout to begin with. Anyone played around with replacing motor/compressor with something better that provides higher CFM Rate(4.9 @ 90 psi is what they claim but I don't believe). At this point I'd love an 80 gallon tank with 10+ CFM @ 90 psi to run real air tools but not in the budget right now. Looking for some thoughts and options on what others have tried before. The tank is on wheels, horizontal, and is somewhat portable. Ideally like to stay 110 VAC as I do not have 220 VAC in the garage.
