Air Cleaners for 72 B
Deadeye
Member
Can someone recommend a basic exposed element air cleaner I can use to replace the factory ones on my 72 B? Hopefully something common enough that I can get them via Advance Auto Parts.
Thanks,
Deadeye
G
I made one similar to the K&N aluminum out of wood. I used the stock filter elements and the bottoms to the metal air cleaner along with the stock bolts. I used silicon rubber to seal the filters to the wood and lock tight on the bolts torqueing them down to just snug as the filters just began to give and the locktite holds it fine. I ran the edge through my router with a Roman Ogee bit. Looks and works great and no money out of my pocket.
Simmo TR6 Weber Carbs and Redline Air Cleaners Triumph 1
E MGB SU carb air cleaners MG 10
S TR2/3/3A Stock air cleaners and aftermarket air cleaners. Triumph 7
AH67 Air Cleaners for Mark I BT7 Austin Healey 4
C runs better without air cleaners?? Austin Healey 19
T TR2/3/3A TR4 Air cleaners on TR3 Triumph 7
P K&N Air Cleaners Spridgets 5
S BJ8 Air Cleaners - correct finish? Austin Healey 21
S Air Cleaners Spridgets 18
S Best air cleaners/ filters for street Spridgets 8
W Weber/stromberg air cleaners Jaguar 3
F Thoughts on aftermarket air cleaners? Austin Healey 12
Ed_K Modifing the stock BJ8 air cleaners Austin Healey 0
Trevor Jessie Custom Air Cleaners Spridgets 12
60TR3A TR2/3/3A SU Air Cleaners on TR3A Triumph 28
R Air Cleaners Austin Healey 3
PAUL161 New Vokes Air Cleaners MG 3
RickB Air cleaners for HS2 carbs? Spridgets 33
vping MGB Who has Modified MGB Air Cleaners? MG 14
angelfj1 TR2/3/3A TR-3A Air Cleaners - Proper Finish Triumph 4
A Air cleaners / carb needles MG 5
S Water transfer decal on BJ8 air cleaners Austin Healey 5
MrPandy Chrome air cleaners? Triumph 3
S TR2/3/3A Tr3 air cleaners Triumph 5
M air cleaners Austin Healey 16
A 100-4 air cleaners Austin Healey 2
M TR4/4A Difference between two Oval Air Filters Triumph 3
K TR2/3/3A Foam air filters for S U's Triumph 7
L Midget 1500 Zenith Air Filter Element: Is it a Unicorn? Spridgets 7
WHT DW ITG Air Filter Austin Healey 3
Carlbanan56 MGB Puling air MG 5
HealeyPassion AH Project: Cool Air to Engine Austin Healey 5
Writer2022 GT6 Overheating after fitting air filters Triumph 4
Celtic 77 MGB Tinny Zenith air regulator MG 0
Celtic 77 MGB Seized air pump issue MG 25
M Midget 1500 1977 Smog pump/Air Injection Pipe Spridgets 0
K TR2/3/3A TR3 front air vents mounted under the grill...seen on race cars for better air flow to radiator. Triumph 1
D BT7 Air Vent Control Cable Routing Austin Healey 0
DrEntropy MGB Air filter MG 16
JPSmit Product Review - air compressor drain valve. Harbor Freight Restoration & Tools 9
F TR4/4A Replacement air filter for SU HS6 Triumph 6
A MGB MGB flap and air box MG 60
R For Sale TR6 AIR CLEANER BOX Triumph Classifieds 1
T Air Filter Recommendations for My Tri-Carb Austin Healey 7
tahoe healey Cooper Air Filters Austin Healey 7
petnatcar Air Scoops Behind the Grille Austin Healey 0
D Wire Wheels and Air Leak Austin Healey 16
rr64 Wanted WTB: Weber 45 DCO 3 Carburetor Air Horns Other British Classifieds 2
PC air back there... Spotted 0
equiprx Air Compressor Moisture mitigation Restoration & Tools 17
