AH 3000 aluminum gas tank
davidb
Why is it by the time you've tackled the (apparently) simplest of jobs, you've had to drag out every tool in the garage, and several others that you've managed to bum from the neighbour. Anyhow, I picked up a new aluminum gas tank at a great price that had been sitting around in someone else's garage for years, but it was missing the large sealing bolt on the bottom. The question I have is should I be using a stainless steel bolt as a replacement, to prevent galvanic reaction? Or maybe some anti-seize? As well, what about the gas line feed? Looks like it's a brass nut - could I perhaps use some teflon tape on the tank threads, or will it react with the gas? I'm also assuming that the large sealing bolt is the same dimension (it's a big mother) whether the tank is steel or aluminum....... Any other precautionary thoughts on aluminum tanks would be appreciated. Nothing like working on a Healey to remind yourself how old you're getting, and why those little Mazdas look better every day. OK back off, and drop that Churchill hub puller - I was just kidding. Cheers Dave
JAV
One thing you need to verify is if the pickup tube is correct. Mine was over an inch off the bottom, resulting in running out of gas early, especially on hills. Did I mention I live on a hill. With some gas resistent tape any nut should be fine.
JAV
64/66 BJ8s
davidb
davidb
Hmmm - thanks for the reply JAV. Wouldn't have thought of the pick up tube. How did you determine that yours was off the bottom? I can't see much inside of mine because of the inner baffles............Norton Commando, nice brute. I assume it's the 750?
Teflon tape isn't actually used for sealing, it's to lubbricate the threads so that the fittings can be drawn up tight. I typically don't use Teflon on brakes or fuel systems, and it would not provide any barrier between dissimilar metals. Honestly, I'd be more worried about the fitting seizing, that eroding, so without doing any research on the topic, I'd grab a brass plug. Aluminum and stainless steel are both soft metals, so seizing would be a possibility. Anti-seize is rarely a bad idea, and my can of choice is Thomas & Betts' Kopr-Shield.
I solved the "running out of gas uphill" problem by having my tank built with the pickup at the rear of the tank. I bought the car when I lived in San Francisco...
davidb
davidb
Thanks for your input Randy. I'll see if I can find a brass plug as suggested. Interestingly I did some research on the net and as you point out, using Teflon tape for gas/gasoline fittings is not recommended. It seems that the recommended method is using Permatex Aviation sealant, or Loctite 577 on the threads, which like anti-seize, provides a barrier between dissimilar metals, as well plugging any prospective leak. God knows the beast leaks like a Liberian tanker in any case. Cheers. Dave
kkaa
I would just add that Permatex makes sealants for fuel fittings and is like a paste you can apply. Ive had great success with it, better than cranking down on a tiny never stop leak, like the ones just above the exhaust pipes, oh yea FUEL PUMP location!!! I had a nagging drip, used it on inlet and outlet there and tank, no worries and feel a lot safer...
S Aluminum wing vents for BT7 3000 Austin Healey 1
Z 3000 Front Wheel Bearings Austin Healey 3
G Custom-Bodied Austin-Healey 3000 Coupe Austin Healey 17
D Wanted: Healey 3000 MkIII body and chassis Austin Healey Classifieds 0
BoyRacer Engine Swap: 3000 Engine Into a BN1 Austin Healey 22
S Grill cowl top piece for AH 3000, BT7, $65 Austin Healey Classifieds 0
G Healey 3000 cutaway display engine Austin Healey 12
pbraun For Sale Healey 3000 transmission Austin Healey Classifieds 0
O HD8 carb on Healey 3000 Austin Healey 62
S For Sale 3000 BJ8 Laycock 4 speed with 22% OD trans & 2 6 cyln engines / long blocks / BUNDLE Austin Healey Classifieds 1
S For Sale Austin Healey 100-6 and 3000 Factory Service Manual on CD/ROM. Austin Healey Classifieds 0
S For Sale Austin Healey 3000 and 3000 MK II Factory Parts Manual - BN7 & BT7 on CD/ROM Austin Healey Classifieds 0
G 1960 3000 BN7 Top Help Austin Healey 0
C Austin Healey 3000 in Modsports Austin Healey 4
F After 30 years of ownership I decided to clean my 1961 Healey 3000 BT7 Austin Healey 0
C 1962 Healey 3000 Mark II Steering Box Austin Healey 9
Drone Dog 1962 3000 Hood/Bonnet Grille Austin Healey 5
maxwedge5281 Front Shroud Differences: 3000 vs. BJ8 Austin Healey 5
maxwedge5281 Wanted wtb....bn6,3000 front shroud Austin Healey Classifieds 10
M 3000 BJ8 Door Seals Austin Healey 9
AUSMHLY 1962 3000 Mk II BT7 speedometer Austin Healey 2
B Wanted 100-6 or early 3000 upper and lower grille opening pieces Austin Healey Classifieds 1
A AH 3000 rear disc brake conversion Austin Healey 28
60TR3A Cost to Rebuild a Healey 3000 Engine [And Recommendations About Who to Do It] Austin Healey 14
B Max Dia for Cylinder Bore for a 3000 Austin Healey 5
M Wanted Healey 3000 Austin Healey Classifieds 4
lbcspinners 1962 Austin-Healey 3000 Mk II BN7 Tri-Carb 2-Seat Roadster: for sale on BaT Austin Healey 2
Marvin Gruber Most popular color for A/H 3000 Austin Healey 56
BN6 Healey 3000 Camshaft Identification Austin Healey 4
M For Sale Churchill 18G106 Valve Spring Compressor for Austin Healey 3000 Austin Healey Classifieds 0
S New Member 1967 Austin Healey 3000 Austin Healey 5
C For Sale 1965 Austin Healey 3000 MKIII Austin Healey Classifieds 0
D For Sale 1967 Austin Healey 3000 MKIII BJ8 Austin Healey Classifieds 0
Healey Nut 3000 oil sump pans Austin Healey 16
BN6 Healey 3000 and 100/6 Factory Hardtops serial numbers Austin Healey 5
J For Sale Healey Books: Anderson/Moment Restoration Guide; Robert Bentley; 100-6/3000 Factory Austin Healey Classifieds 7
J For Sale 1 owner 1959 Austin healey 3000 BT7 Austin Healey Classifieds 0
Tremelune Wanted Austin Healey 3000 with a modern engine Austin Healey Classifieds 0
B A/H 3000 braking system Austin Healey 2
BN6 Austin Healey 3000 Cylinder Heads Austin Healey 19
Alfred E. Neuman Late Healey 3000 Spotted 0
J 3000 [BT7] with 100-6 Grill Austin Healey 2
T Securing the Tonneau on a 3000 MkII Austin Healey 4
T Heater/Ventilation Controls on a 3000 Austin Healey 5
S For Sale AH 3000 Motor Mounts Austin Healey Classifieds 1
T Trade 3000 Speedometer for 100/4 Speedometer TRADE Austin Healey Classifieds 0
Fortius For Sale AH 3000 MK III Phase II 1967 - Denis Welch Engine & Parts Austin Healey Classifieds 0
pbraun For Sale 1963 Austin-Healey 3000 BJ7 Austin Healey Classifieds 5
BoyRacer 100/6, 3000 Disc wheels Austin Healey 4
crya For Sale 1964 Austin Healey 3000 Austin Healey Classifieds 1
