Adjustable steering wheel installation
Perry
When I bought my 3000 MKII BT7, it was missing the horn/trafficator assembly and had a wood rim steering wheel with just a metal clip holding it on the column. I have since bought and restored an original wheel, as well as the horn/trafficator assembly with wiring harness, and the spring cover with top and bottom covers. Now I can't figure out how the ****ed thing goes together.
The wheel is a very tight fit on the column.
The shop manual just indicates that the spring,etc goes first,but I can't figure out how it all fits together. Can someone walk me through it?
I think I know what to do with the horn/trafficator, but the wheel has me stumped.
Johnny
I'll give it a go, as they say. First make sure you have a steering column for an adjustable wheel. They are longer. There should be a cup to hold the chrome spring in place on both ends. The smaller cup on the bottom. There is a circlip holding the wheel on the column this has to be removed of course before installing the wheel. On my car the wheel went on quite easily without much effort, snug, but easily. Then all the trafficator parts. Don't forget to loosen the grub screws (3) on the wheel before fitting the trafficator. It might facilitate fitting the wheel if you remove the clamp holding the wheel under the dash. Good luck.
John Loftus
Perry,
You might just have the locking collar/clamp too tight. Loosen it all the way by turning counterclockwise (looking at the steering wheel from the back)and grease up the splines inside the wheel and on the steering shaft. The telescopic spring and cups goes on first (check out the Moss catalog for the exploded view which shows the two different wheel types to make sure you have all the right parts). Then just slide the steering wheel/locking collar assembly on, attach the circlip and tighten the collar.
Let me suggest not to install the trafficator until you adjust the center spoke of the wheel to the 12 o'clock position. This is best done on a straight stretch of road where you can safely pull over. With the circlip removed but the collar tight you can drive to see if the center spoke is at 12 o'clock. If it is offcenter, you pull over, loosen the collar, slide the wheel off, rotate accordingly and slide it back on and tighten the collar firmly. Then road test again. Once you are satisfied with the alignment you can then install the circlip and trafficator.
Cheers,
John
CDK
To also help assist setting the wheel straight check and or set your toe first. Then set your wheel.
I am glad I read these posts as I just noticed I do not have all the pieces on mine ( from when I got it)
CDK
[ 03-08-2004: Message edited by: CDK ]</p>
J Wanted Adjustable steering wheel circlip Triumph Classifieds 4
E Wanted wanted Austin healey 3000 adjustable steering wheel & dash pad Austin Healey Classifieds 2
Walter74 Adjustable steering wheel removal Austin Healey 4
K TR2/3/3A Non Adjustable TR3 Steering Wheel Triumph 7
R TR2/3/3A Frozen Steering Wheel [Adjustable] Triumph 7
BoyRacer Wanted Steering Wheel Hub Adaptor for non adjustable column Austin Healey Classifieds 1
AUSMHLY Adjustable steering wheel removal Austin Healey 5
D BT7 adjustable steering column / steering wheel Austin Healey 1
Lin Loosening adjustable steering wheel Austin Healey 3
Lbp TR2/3/3A Looking for info on adjustable steering wheel - Does a Healy wheel fit? Triumph 9
Lbp TR2/3/3A TR3A - Converting Adjustable Steering Wheel to Standard? Triumph 16
B Rocking movement in adjustable steering wheel Austin Healey 6
Lbp Looking for Adjustable Steering WHeel Triumph 5
F Replacing the horn push adjustable steering wheel Austin Healey 7
pkmh Removing BJ8 'Adjustable' Steering Wheel Hub Austin Healey 18
W Longbridge 100-6 and adjustable steering wheel Austin Healey 7
HealeyCopter Adjustable Steering Wheel Nut Stuck Austin Healey 10
D Adjustable steering wheel stuck Austin Healey 6
K Adjustable steering wheel setup Triumph 2
B Non-adjustable steering wheel removal/adjustment Austin Healey 1
Johnny Non-adjustable steering wheel switch mounting. Austin Healey 2
C Identifying BN1 Adjustable Steering Wheel Austin Healey 7
P Non adjustable steering wheel removal Austin Healey 7
GregW Adjustable steering wheel Austin Healey 13
JAV For Sale non adjustable steering box Austin Healey Classifieds 3
BoyRacer Did BN2s have adjustable steering wheels? Austin Healey 5
J TR2/3/3A TR3A Adjustable Steering Triumph 5
John_Koop TR2/3/3A Adjustable steering wheels Triumph 3
C Non-Adjustable steering column questions Austin Healey 14
B Wanted Need '58 TR3 adjustable steering set up Triumph Classifieds 4
60BN7 Adjustable Steering Column Won't Lock Austin Healey 9
4tecdog Adjustable Steering how? Austin Healey 8
maxwedge5281 bj7 adjustable steering column Austin Healey 14
Crankshaft Adjustable steering column? Triumph 11
I another adjustable steering column question Austin Healey 8
M Adjustable Steering column Austin Healey 9
G TR2/3/3A How does TR3A Adjustable Steering Work? Triumph 5
S Convert to adjustable steering Austin Healey 12
bighealeysource Stator tube on adjustable steering 100-6 Austin Healey 5
JamesWilson Adjustable & Non-Adjustable Steering: Interchange? Austin Healey 2
longbridgehealey adjustable steering Austin Healey 6
tahoe healey Adjustable steering tightening Austin Healey 13
bt7tricarb Trafficator question [adjustable steering] Austin Healey 22
B Adjustable Column and steering box e-bay Austin Healey 1
RandallRK Moto Lita steering hub on non-adjustable column Austin Healey 4
G Adjustable steering Triumph 4
H Adjustable Steering Problem Austin Healey 4
P Adjustable Steering Column for Spifire ? Triumph 0
P Spitfire Adjustable Steering Column Spitfire Triumph 0
P Adjustable Steering Triumph 2
