Additional fuses
John Sims
Can anyone give me an ideal of which circuits should be fused, amperage of the fuses, where the fuses should be placed, etc on a BN6?
Dave Russell
Yoda - R.I.P
Depends on how many fuses you want to add.
First would be the red wire on the back of the lighting switch. This wire feeds the front & rear running/park lights & most importantly, the number plate light. If the car gets the rear bumper whacked it frequently cuts into the number plate light feed & causes a short circuit. 10 amp USA inline should work.
An alternate would be an inline fuse in the boot just for the number plate light.
Next would be the white/green wire from the OD relay to the gearbox 3-4 switch. If the contact on top of the OD solenoid fails to open as it sometimes does, the OD solenoid will rapidly burn up. 20 amp USA should work.
Sometimes folks fuse the fuel pump supply lead, one of several white wires at the fuse block. This wire is kind of vulnerable to getting mashed under the frame. 10 amp USA would be ok.
These last two are readily acessible at the existing fuse block & you could add another OEM fuse block next to or below the existing block.
This is only my suggestion. Other folks may have different ideas. Any additional fuses are better than nothing.
M Additional Fuses Austin Healey 3
HealeyRick Healey Additional Seating Austin Healey 4
W Additional surplus inventory Spridgets 4
W Additional bonnet struts Spridgets 9
T TR2/3/3A Steering Column Felt Bush, Additional Bush, Rubber Washers, etc. Triumph 8
Tinkerman TR2/3/3A 1960 TR3 A Additional steering question Triumph 4
L BJ8 additional interior lighting Austin Healey 7
Patrick67BJ8 Additional Gauges to a BJ8 Dashboard Austin Healey 6
Trevor Jessie Found some additional HP for free! Spridgets 1
R ADDITIONAL FUSING FOR EXTRA PRECAUTION? Austin Healey 15
Michael Oritt Pre-race checklist: An additional item Racing 7
Atrus Additional Lighting [headlights] Spridgets 24
Brosky Additional progress at body shop Triumph 20
Brosky Additional bling finished Triumph 24
Randy Harris An additional thought about values Austin Healey 12
R Bugeye fuses Spridgets 14
K TR2/3/3A Fuses Triumph 3
J 1997 Vanden Plas X300 ,Help With Turn Signal Blowing Fuses Jaguar 3
W Fuses Blowing Austin Healey 11
K TR2/3/3A 30 AMP Fuses Triumph 2
longbridgehealey In line fuses Austin Healey 25
M Fuses Austin Healey 7
F TR2/3/3A Fuses Triumph 10
Jim_Gruber Blowing 15A Fuses as soon as I apply the brakes Spridgets 6
K TR2/3/3A TR3 Fuses Again Triumph 1
S TR6 TR6 blowing fuses Triumph 4
T TR6 Blown Fuses Triumph 1
B Fuses for 1960 BT-7 Austin Healey 3
RickB All 4 parking lights dead, fuses all good? Spridgets 6
W Glass fuses Jaguar 3
I TR6 TR6 correct fuses? Triumph 8
H Tr 3 fuses Triumph 10
C AH 100-6 Fuses/wiring...what did I do? Austin Healey 6
Dudly Spitfire Blowing fuses in my 79 spit Triumph 10
af3683 35A Fuses Triumph 14
M Still con-fused about fuses Triumph 22
A Midget Fuses Spridgets 7
A TR2/3/3A TR3A FUSES Triumph 4
longbridgehealey Bugeye fuses Spridgets 5
Thor lights on without any fuses- Any suggestions Spridgets 6
Paulus MGB 69 MGB fuses MG 8
D Fuses? Triumph 9
Tinkerman TR2/3/3A TR3A fuses Triumph 9
Tronch Adding Fuses Austin Healey 4
19_again Fuses in'66 B MG 12
B fuses Brit vs US Triumph 5
G Question on fuses Spridgets 9
T "British" Fuses Triumph 4
Michael Oritt Switches and fuses Racing 13
Tinkerman British fuses vs American fuses Triumph 17
