TR2/3/3A Accelerator rod pin removal, TR-3
Tinkerman
Hi: Is there a sure fire way to remove the accelerator rod pins short of drilling them out. Mine seem to be very well stuck and tend to resist drifting them out with a punch. Any thoughts would be greatly appreciated.
Tinkerman
mgedit TR2/3/3A Link Rod Lengths Accelerator Linkage Triumph 2
Tinkerman TR2/3/3A TR3A Accelerator Rod Dissasembly HELP! Triumph 1
CARSINC MKIII Accelerator Pedal Spridgets 0
Popeye TR4/4A Accelerator shaft install - location of bushing plates? Triumph 2
DocDup1 Wanted TR4A Accelerator Linkage Lever Triumph Classifieds 0
FlyingCat Spitfire Accelerator cable Triumph 4
B LHD to RHD accelerator controls Austin Healey 15
K For Sale TR3 Accelerator pedal assembly Triumph Classifieds 1
T TR2/3/3A Accelerator Say 1960 TR3 Triumph 11
TomMull Post-War Other Herald: Holy Moly! [Why it took me so long to make the accelerator bracket] Triumph 2
Got_All_4 TR2/3/3A Accelerator shaft question Triumph 2
J TR2/3/3A accelerator linkage for Weber 45 DCOE Triumph 4
M Accelerator Pedal Position Austin Healey 4
R TR2/3/3A TR-3A accelerator return spring Triumph 9
PatGalvin TR2/3/3A Accelerator Pedal Advice Needed Triumph 21
G Best way to remove accelerator bar part # 106762 Triumph 3
K TR2/3/3A TR3A...Kicking accelerator pedal lowers idle? Triumph 20
S XKE Accelerator Ppedal Position Jaguar 2
B Accelerator relay rods on RHD Austin Healey 2
bcbennett TR6 TR6 accelerator vibration Triumph 9
ArcticOne GT6 GT6 Accelerator Pedal Removal Triumph 8
ArcticOne GT6 Accelerator Pedal - GT6 MKI Triumph 2
bigjones MGB MGB accelerator cable MG 8
I Source for Bugeye accelerator return spring? Spridgets 2
ArcticOne Accelerator Pedal Triumph 0
I TR6 TR6 accelerator bar busing replacement help please Triumph 10
KVH TR4/4A Sticking Accelerator or SU Jets: TR4A Triumph 7
TR6oldtimer TR6 TR6 accelerator linkage help needed Triumph 9
H TR2/3/3A TR3 Accelerator Shaft -- Straight or Bent? Triumph 9
B accelerator cable Spridgets 6
Tinkerman TR2/3/3A TR 3A Accelerator Bushing Placement Triumph 21
Tinkerman TR2/3/3A Accelerator Assembly Installation TR3A Triumph 3
Tinkerman TR2/3/3A TR3A Accelerator Assembly Triumph 6
Tinkerman TR2/3/3A TR3A Accelerator Pedal Assembly Triumph 9
Tinkerman TR2/3/3A Accelerator Pedal Assembly ,TR 3A Triumph 6
glemon TR5/TR250 TR250/6 accelerator shaft bush Triumph 5
D MK2 accelerator pedal Jaguar 0
Jim_Gruber Accelerator Cable termination on carb linkage Spridgets 10
Morris 1500 Accelerator cable Spridgets 7
angelfj1 TR2/3/3A TR3A accelerator pedal/shaft Triumph 9
T Clutch and Accelerator return springs are missing Triumph 6
R Accelerator linkage removal Triumph 2
Tinkerman TR2/3/3A Accelerator Pedal Question TR3A Triumph 5
B Accelerator Cable Spridgets 4
M TR2/3/3A TR3 Accelerator Pedal Triumph 7
Tinkerman TR2/3/3A TR3 accelerator pedals Triumph 8
Atrus Accelerator Pedal Spridgets 7
Musicman That Dreaded Accelerator Bushing Triumph 5
J Spitfire Spitfire MK3 accelerator bushings Triumph 3
Johnny Accelerator linkage restoration Austin Healey 34
