A type OD clutch lining thickness
titanic
Does anyone (Randall?) know the thickness of the lining of the OD clutch when new and when it is considered no longer useable? I would like some measurements to the rivets. Thanks. Berry
TR3driver
Great Pumpkin - R.I.P
Sorry, no help here. I've seen a spec somewhere, but it was in terms of how far the clutch could move, not lining thickness. I made notes last time I was inside an A-type (had a clutch that was actually too thick!), but there is no telling where they are now.
TR3driver
Ah, found it. TR4 workshop manual gives clutch travel as .080" to .120", plus has the note "allowance for wear 1/8" of direct drive clutch".
I'm not quite sure what that means, but I did confirm that less than .060" or so is a problem :smile:
T
titanic
Thanks Randall. I was a little confused by the spec. too. I posed the same question to John Esposito a few days ago, but haven't received a response. I just bought an extra OD trans quite cheap(by today's standards) but there is only .030" meat left on the clutch. There is a rebuilder in the Portland, OR area that relines the clutches using only bonding, instead of rivets. Anyone had any experience on problem with the procedure? Berry
R TR6 Clutch Master Cylinder Hydraulic Line (Thread / Flare Type) Triumph 4
D Clutch-Type Differential Austin Healey 5
T TR2/3/3A Question on A type overdrive spec for "clutch movement from direct to overdrive" Triumph 7
Q Series 1 E Type Clutch Jaguar 2
Got_All_4 TR2/3/3A What clutch plate do I use with a J or A type Triumph 1
B Ball Bearing-type Clutch Release Bearing for BN2 - Availability ??? Austin Healey 2
D SI E Type clutch master cylinder Jaguar 3
H MK2 lover, but... what about an E type? Jaguar 5
D TR2/3/3A layout for lap type seat belt Triumph 5
5 Wanted Wanted 1966 mgb banjo type axle rear hub MG Classifieds 0
J For Sale Bilstein Front Shocks for Jaguar E-Type 727-498-6493 Jaguar Classifieds 0
71TR6 TR6 Type-J Overdrive identification Triumph 4
B Thread Type and Size of BN2 Intake/Exhaust Studs Austin Healey 0
Editor_Reid V-12 E-Type Body Number Location Jaguar 3
M For Sale 2017 Jaguar F-TYPE Premium 2-Door Convertible for Sale mlbirk@aol.com Jaguar Classifieds 0
K TR2/3/3A The Amco chrome tube type grille ....... Triumph 9
T TR2/3/3A A type overdrive hard engagement Triumph 36
S TR2/3/3A Wedge type and Dzus type side- curtains Triumph 1
R TR6 J-Type overdrive will not disengage when warm Triumph 8
6 E-Type brake light pressure switch location Jaguar 5
A SOLD!! TR3A Girling Type A brake caliper for right front Triumph Classifieds 0
M Front caliper rebuild 1970 Series 2 E-Type Jaguar 0
M General Tech J Type OD Stuck in OD - Fixed Triumph 2
ROARRR Is there any problem swopping in a 3.0 in place of the 2.5 L engine in my Jag X Type? Jaguar 0
M General TR Source for J Type O/D Solenoid Circlip Triumph 0
M Wanted Wanted: Inoperative J Type OD Solenoid! Triumph Classifieds 2
V vintage glue type for veneer? Sunbeam (Rootes) 13
Joel Lester TR2/3/3A What type of valve to use when rebuilding the head? Triumph 10
M TR6 Gear Oil Type and how to add 1973 TR6 Triumph 9
Basil Remember the Royal Electric E-Type Electric Upgrades of All Sizes 0
S TR2/3/3A lifter type Triumph 3
1 TR2/3/3A TR3 Fuel Pump Thread Type? Triumph 4
RonC TR2/3/3A J Type Overdrive in TR3A Triumph 4
M TR6 1973 TR6 Coolant Type? Triumph 5
S TR2/3/3A 187 NOS sleeved type thermostat Triumph 16
Basil The new Kia E-Type? Jaguar 6
H TR4/4A A-type overdrive pump Triumph 4
Got_All_4 TR6 Refurbishing gearbox with A type overdrive Triumph 7
P Wanted E type spare tire bracket Jaguar Classifieds 2
P Wanted 62 E Type spare tire bracket Other British Classifieds 1
Got_All_4 TR6 Routing Speedo cable for a J type tranny in my TR250 Triumph 4
Got_All_4 TR5/TR250 Trying to figure out rear transmission mount with a J type tranny Triumph 9
I GT6 A type OD vs D type - engagement speed? Triumph 3
J For Sale Jaguar E Type and MK2 spares Jaguar Classifieds 0
VooDooDaddy63 Basic E-Type Question: Fasteners - Metric or SAE or ...? Jaguar 15
D TR2/3/3A Type A overdrive not engaging Triumph 0
D TR2/3/3A Type A overdrive not engaging Triumph 16
S For Sale Lotus Elan Factory Workshop Manual on CD/ROM - Type 26 - 1963 - 1965 Other British Classifieds 1
B Resistor type vs non-resistor type spark plugs for 100-6 Austin Healey 17
