A little dampness on the backplate
TRMark
Bronze
While waiting for brake & clutch master cyl. rebuild kits, I decided to look at a few other areas of the TR4. The inside back plate and hub are just a bit moist, kinda like slightly greasy dirt, nothing on brake shoes, drums or externally. I see there are two seals in there, a hub and an axle. Do I need to replace them both, how difficult is it to do. I have not had to replace them before.
Geo Hahn
...I see there are two seals in there, a hub and an axle. Do I need to replace them both, how difficult is it to do. I have not had to replace them before.
The axle -- pretty easy in the grand scheme of things. Main thing is to get the correct end float when assembled (which should be okay by just using the same shims and changing no other parts.
The hub -- on a scale of 1 to 10 I'd rate it a 12. IOW, in some cases nothing short of a nuke will separate those parts.
If I had it to do over I'd try replacing the axle seal and see if that takes care of it. I had a TR 'expert' show me how to pull the hub apart and I in the end I needed a new hub and axle.
TR3driver
Great Pumpkin - R.I.P
I agree with Geo. In addition, the outer seal shouldn't leak unless the wheel bearing has been overgreased. The inner seal is the one that holds back oil.
If you do decide to replace the outer seals, your best bet is probably to remove the axles with hubs still attached, and send the assembly off to someone like Mark Macy. I've managed to come up with a process that so far has worked 3 times for me (first hub came apart easy), but it was a lot of work to machine the press plates to fit snugly behind the hub.
tinman58
I am in the middle of this right now. I thought no big deal.... well the hub's and axle's are at the machine shop and He only want's to do one at a time. The first one is almost done. He thinks nit bwas about 40 ton's of pressure and heat to get the first bone apart. No wonder my 3 prong gear puller did not work..
titanic
With that much pressure&heat, I wouldn't be surprised if the flange was bent or the axle mushroomed. Berry
TR3driver
Me too, but maybe he will get lucky.
TRMark
TRMark
Bronze
Thank you for getting me going in the right direction. I'll order the axle seal, I don't want to even think about separating the hub.
P General Tech Positive Earth?? Very confused. A little help? Triumph 19
JPSmit Lovely little Spridget video Spridgets 4
charlie74 Spotted this little gem in Bishop, CA Spotted 2
Got_All_4 Wedge Looking at a Local TR8 For Sale Little Ruff Triumph 1
Lin A little "Stay-at-Home" Healey Nostalgia Austin Healey 10
P A little identification help please Other British Cars 10
S TR2/3/3A The little things Triumph 2
S TR2/3/3A little rubber plugs Triumph 3
K TR2/3/3A What is the little white fiber thing for that comes in the Lucas points box? Triumph 2
S TR2/3/3A Tr7 and a little extra Triumph 2
S TR2/3/3A source for those little drain hoses Triumph 6
S TR2/3/3A this little miss in the engine Triumph 17
D Best little tube bender Restoration & Tools 8
N TR6 Need a little wiring help with a 74 Tr6 Triumph 6
S TR2/3/3A little caged nut headlights Triumph 2
S TR2/3/3A little more door gap Triumph 14
S TR2/3/3A What's a little thing that made a huge difference in your vehicle? Triumph 37
HighAltitudeTR3 TR2/3/3A Running a little hot... Triumph 14
drooartz A little winter drive Spridgets 3
C Brakes....a little help please? Austin Healey 9
B The little silver indicator knob Austin Healey 0
S TR2/3/3A little miss problem Triumph 12
catfood Must have a little more faith in my system... Austin Healey 4
John Turney A Little Early Austin Healey 11
Joe Reed MGB A little different DGV installation... MG 12
Jim_Gruber A Little Saturday Night Time with Bugsy II Spridgets 6
Jim_Gruber A little Thanksgiving Help - Bugsy is now up in the air Spridgets 14
trrdster2000 GT6 Another little difference, big problem. Triumph 11
Rut MGB Last little bit MG 0
TomMull TR2/3/3A Little Bits and part numbers Triumph 3
S My New Little Friend... Spridgets 2
Jim_Gruber A Little Bling for Bugsy II Spridgets 8
NutmegCT Tom's new SLBC [Sorta Little British Car] ! Other British Cars 46
Boink Bugeye gets a little attention... Spridgets 0
M Clutch problem, a little different than usual Spridgets 8
T 1933 Standard Little Nine Carburetor Other British Cars 8
Rut Pushed it a little too hard, eh? Spridgets 1
A TR4/4A My next restoration with a little help from "Fantom Works" Triumph 2
D Off Topic Little British Car Day Triumph 1
Gerard An education on how Fedex does business - a little off topic Spridgets 21
drambuie No sound affects when breaking those little Christmas lights! Austin Healey 16
S Off Topic Reason 193 why I love little british cars [especially TRs] Triumph 8
pkmh Interesting little jack stand discovery, "Drednaut" Austin Healey 0
RickB Poor little MK2 Sprite - Seattle Craigslist 'Sebring bonnet' Spridgets 24
RickB Anyone doing a steering wheel swap - a little loctite might be a good idea Spridgets 2
DNK TR6 Well I'm a Little Confused Triumph 4
DrEntropy MGB A little thing MG 4
Basil Admin Note One more little change MG 1
Trevor Jessie The Ugly Bug just got a little uglier Spridgets 20
S My little 68' Sprite Spridgets 24
