MGB 71 MGB Seat belts
jhva
Greetings,
My car came with a seat belt that fastens to the rear deck f the car and is totally not adjustable. There are what looks to be something of a wheel from a recoil on the inside wheel well on both sides of the car. Anyway, I have found that with the top down it's next to impossible for the seat belt to work properly and it binds up in the top frame etc. Does anyone have any suggestions or recommendations on what to set-up on the mg.
cheers,
John in VA
davester
Kangol inertia reel seatbelts were an option and are what I have on my 71 BGT. The inertia reels are attached to brackets that bolt into the tops of the rear wheel wells. I doubt if you can get the kangols any more but there are inertia reels that will probably work in that position. There are a couple of companies that make seat belts for vintage vehicles that can probably provide a suitable unit but I can't seem to recall the names at present.
PAUL161
John, does one end of the belts attach to the top of the rear deck as the 70s did or do they attach to the tire/fender well? I thought the 1970 models were the last of the deck mounts. If you put modern belts on the car and you have the old deck mount straps, save the metal ends, if they are the same as on a 70, they are hard to find, or so I'm told. PJ
jhva
jhva
The belts are mounted on the rear deck. There are two inertial reels in the side wells but they would need replacing since they just look like two rusty steel wheels with nothing attached to them.
thanks for the info,
john
I believe the magnetic Kangol belts were used through the 1971 model year in the North American market, but stayed on through 1975 or 1976 in the UK market.
Yes, the hardware is indeed getting hard to find for the magnetic Kangols.
ralph_s
Kangols are tough to come by. Got info of seatbelts from Hagerty. The following may help:
Seatbeltsolutions.com and ssnake-oyl.com rebuild for a price $$$
Seatbeltpros.com sell aftermarket.
hope that helps
JohnGone Wanted '80 MGB without seat belts? MG Classifieds 3
S Wanted MGB Static Seat/Shoulder Belts MG Classifieds 0
Monark192 MGB Another MGB - Still no seat belts MG 16
C MGB Re strapping a MGB seat bottom MG 2
TunaJ Will MGB Upper Seat Runners work with Midget seat rails? Spridgets 1
EricJNewman MGB Modern Seat Tracks in MGB Solution MG 8
CJ Burton MGB-GT Installing Seat Covers for 1962 - 1967 MGB GT MG 0
P For Sale mgb seat covers MG Classifieds 0
mgbman1964 MGB New seat rails for my 1963 MGB MG 3
Newkie MGB Any recommendations on MGB seat covers? MG 7
S MGB Removing the passenger seat from my 71 MGB..... MG 4
K MGB 1980 MGB Seat Colours? MG 2
boxofparts MGB MGB Child Seat MG 4
kyreb1862 MGB MGB Seat Covers MG 4
kyreb1862 MGB 77 MGB Seat Belt Problem MG 9
Simmo MGB Re Engined MGB MG 4
Carlbanan56 MGB MGB rear break rebuild MG 6
C Wanted Early MGB soft top and/or tonneaus, condition not very important MG Classifieds 0
Carlbanan56 MGB Mgb turn signals MG 17
J MGB 1970 MGB Steering Lubrication MG 1
C Wanted Wanted: 1977 to 1980 MGB Dashboard MG Classifieds 0
L SOLD!! For Sale MGB Hardtop MG Classifieds 3
EvansClassicCars For Sale 1980 MGB for sale MG Classifieds 0
J MGB Tire pressure for 1980 MGB MG 14
5 Wanted Wanted 1966 mgb banjo type axle rear hub MG Classifieds 0
I MGB Purchase of 1972 MGB Roadster MG 3
C MGB-GT MGB-GT Front Ride Height MG 0
J MGB Advice for new MGB owner? MG 16
D Wanted Wanted: Chicklet Headrests for MGB/C! MG Classifieds 0
Editor_Reid MGB Anders Clausager's "MGB" book MG 4
J MGB 1966 MGB won't start MG 1
Erica General MG Oil Drain Valve -- mine is an MGB, but they have others MG 3
Erica MGB Carburetion and MGB fuel economy. MG 0
wkilleffer MGB MGB clutch slave bleed driving me nuts MG 38
R MGB side chrome installation MG 4
C MGB MGB MG 5
3798j Off Topic MGB at the Drive in Bank MG 1
wkilleffer MGB 1974 MGB clutch master cylinder questions MG 1
Rut MGB 62-67 upper MGB steering shaft MG 3
VeeCee MGB 1974 MGB Roof Installation MG 0
J MGB Just bought a 1966 MGB MG 50
T MGB MGB hoses MG 6
G MGB Sorry from the Newbie...Clutch gone on 78 MGB MG 17
Briancole702 MGB-GT 71 Mgb gt no gas in float bowls MG 1
Ranger68 Wanted 1969 MGB Sun Visor Wanted MG Classifieds 0
R MGB MGB Roadster Door Panel Speakers MG 9
DrEntropy MGB Good video on the MGB MG 0
adcronin For Sale MGB Turn Signal (lights, horn, indicator) Switch, New for 62-67, also Sprite MK 3 & 4, MIDGET MK 2-3 thru 67 MG Classifieds 0
J Wanted 1969 MGB Roadster sun visor clip MG Classifieds 4
