Russ,
I noticed for some reason you had entered this entire question as your "signature" in your registration profile. I'm sure that was not what you intended, so I have deleted your "signature". If you want to add a signature, just go to your "My Profile" and add what you want (like, "Regards, Russ" for example). Whatever you have in your signature in your member profile gets added to the bottom of each post you make here. (Note that my signature is the quote you see below the dashed lines in this post)
[ 01-10-2004: Message edited by: Basil ]</p>
