MGB-GT 67 GT front hub removal
Monark192
I'm starting in on getting the 67 back on the road and starting with the front brakes. What is the secret to getting the dust cap of the hub bolt on a wire wheel car. Does it unscrew somehow or pry off using the small hole in the side of the hub or...? It has a small threaded shaft sticking out of it so is there a required tool?? Thanks in advance.
tony barnhill
Great Pumpkin - R.I.P
On the passenger rear of your engine, the last head stud has a smaller open female end...take that head stud out of the engine, insert the smaller female end into the hub & screw it onto the dust cap (there's a small male stud on the end of the dust cover that'll go into the female end on the head stud) & then just pull the dust cover off!
Reverse to put it back in....& then reinstall the head stud & torque it down.
Monark192
Monark192
Thanks Tony. I couldn't readily identify the head stud but knowing the principle, I made a puller out of a long bolt with a thick nut at the end to thread onto the dust cover. First one is out. The second is proving more reluctant.
vping
Bronze
Always the case.
Monark192
Monark192
Don't know if I can pull any harder. :frown:
Oh well, I'm sure it will pop right out tomorrow.
tony barnhill
Clamp a big vise grip on your puller & hit it with a BFH, knocking the cap loose - hit outwards not inwards!
Steve_S
Do you really remove a head stud just to take a grease cap out? You can buy a coupling nut for 39 cents at any hardware store that will do the same thing. I never disturb the head bolts unless necessary.
Monark192
Monark192
I thought it seemed a bit complicated. However, 9 minutes after posting my question, I had a detailed answer that didn't rely on specialty tools. You gotta love this place. Got the passender side rotor replaced and new pads almost in last night - I forgot to order new cotter pins with the rest of my brake parts and nether the local Autozone or Lowes had any long enough. I will be warming up the BFH as Tony suggested to have another go at the drivers side this weekend.
tony barnhill
Actually, Steve, whenever I disassemble an old engine, I keep that one stud & the long nut on top of it...I've welded a handle across a couple of them & have them in my specialty drawer.
Platinum
Yup! Me too. Made up one back in th' day with a "T" handle.
Best on the Web, Simon. :laugh:
Monark192
Monark192
Got it done - a little lovin from dear old BFH and it came right out. Was able to finish up both sides at the front - new pads, rotors, and hoses. Yeah. Still waiting on UPS to deliver rear pads which had to be shipped from the east coast so on to draining fuel tank and re plumbing soft fuel lines.
Getting closer to that first drive one step at a time.
K TR2/3/3A Front brake hub removal to access Vertical Link bolts(screws) Attached pictures. Triumph 1
Scotsman TR2/3/3A tr3 front wheel hub stud removal Triumph 2
H front hub removal Austin Healey 37
19_again front hub removal MG 3
C BT7 Front Hub Removal Austin Healey 4
19_again front hub removal MG 18
M Front Hub Grease Cap Removal MG 9
M Front Hub Removal Question Triumph 4
A Front Hub Removal Spridgets 3
P Front hub & rotor removal Austin Healey 12
Carlbanan56 MGB Front hub MG 4
K TR2/3/3A How to remove the front brake hub from the brake disc? Triumph 11
A BN7 Front Hub Stud Nuts Austin Healey 5
K TR2/3/3A Securing new brake disc to the front hub? Triumph 4
K TR2/3/3A Front Hub and Felt Seal Triumph 1
Tybalt Spitfire Spitfire vs GT6 Front Hub Question Triumph 0
MikeAH100M 100 Front Hub Spacer/Distance Piece Austin Healey 2
warwick-steve Missing grease cap in front hub Austin Healey 8
warwick-steve Front hub bearing grease repacking Austin Healey 28
K TR2/3/3A Front hub oil seal Felt? Triumph 1
K TR2/3/3A Front wheel hub "felt" again? Triumph 2
K TR2/3/3A Front hub wheel bearing nut? Triumph 1
aero3113 Front Hub Inner Bearing Seal Austin Healey 7
pkmh "Bearing Outer Race" Re-installation at Passenger Front Hub Extension Austin Healey 4
Jeepster Front hub replacement. Austin Healey 34
R TR2/3/3A front hub seal options Triumph 9
Bob_Spidell Securing Front Hub Bolts Austin Healey 8
T TR4/4A Front hub grease cap sizing - anyone had a cross reference part # for a FLAPS? Triumph 2
C Front Hub Castle Nut Austin Healey 8
B TR2/3/3A TR3 Front Hub Felt Seal questions Triumph 2
M_Pied_Lourd TR2/3/3A 59 TR3A Front Hub Oil Seal Triumph 2
R BJ7 front hub shim question Austin Healey 18
catfood Removing front hub Austin Healey 6
RAC68 Calculating Front Hub End-Play Austin Healey 32
S Correct way to remove grease retaining cup from front hub? Austin Healey 7
Jim_Gruber Removing front wheel bearings from hub Spridgets 6
bertl Front Hub Spacer Kit Triumph 1
BillD Front hub puller Spridgets 21
6 front hub options... Triumph 4
S Spitfire Question on front Hub for a triumph Spitfire. Triumph 4
pkmh Dismantling BJ8 Front Hub From Caliper Disc Austin Healey 20
Willie_P TR 3/4 Front Hub Install - question Triumph 15
J Front hub mystery Austin Healey 0
britndablood To install or not to install Front hub spacer Austin Healey 8
Lon_S What hub puller tool works well for the front hub? Spridgets 2
TR4nut Front Hub Felt Seal - Old vs New Triumph 15
D Need a front hub Austin Healey 1
S Front Hub Replacement Austin Healey 7
G Front hub Spridgets 2
TonyPanchot tork settings for 1997 front hub Jaguar 1
