65 to 67 carbs wanted
69MGC
Hi BCF guys
I’m in need of a pair of Carbs for 67 or earlier. If you have a set please get in touch.
Thanks for all your help guys. I found a set of carbs.
thanks
Kevin
69MGC
69MGC
Yes, I have a set of early HS4s. Can rebuild and install new o/s throttle shafts.
Jim
Thanks Jim. I was able to buy a pair on eBay about a month ago for a very reasonable price including the intake and exhaust manifolds. If you still have yours what would you want for them? I might have someone else interested. Let me know
cyclingmadone
Hi I have a big valve cylinder head, and two carbs and the inlet manifold with . a repair kit, I you are interested.. £200 the lot...plus carraige
69MGC
69MGC
Thanks for the offer. I was lucky enough to find a set a few weeks ago.
69MGC MGB Wanted: Pair of 67 or earlier Carbs MG 2
SASSAMON TR2/3/3A Help Wanted In Cleaning Corrosion Off SU Carbs Triumph 20
S SU H 1 carbs wanted for 1960 Herld convertable Triumph 8
K 1966 Austin 1100 carbs? British Motor Corp 1
Basil Spitfire How do I adjust SU carbs on my Spitfire? Triumph 5
steveg HS vs HD series carbs Austin Healey 2
P For Sale v12 carbs Jaguar Classifieds 0
T TR6 My '74 TR6 Zenith Stromberg Carbs Float Bowls Leaking Gas Triumph 11
steveg TR6 HD6 carbs on TR6? Triumph 16
J For Sale Two used WEBER DGV 32/36 carbs for Triumph TR 2,3,4 Triumph Classifieds 0
K For Sale Two Rebuilt TR3 AUC 878 SU Carbs Triumph Classifieds 3
Michael Oritt Initial mixture setting for H6 carbs Austin Healey 3
Michael Oritt Leak from carbs Austin Healey 13
M BN1 with H6 carbs : what setting ? Austin Healey 56
D Starting After Carbs Rebuilt Austin Healey 30
T TR6 Carb Vacuum Port- TR6 Zenith-Stromberg Carbs Triumph 2
K 66 Austin 1100 Carbs British Motor Corp 1
Carlos TR4/4A GROSE-JET or Viton-tip for SU HS6 carbs? Triumph 15
M Cooper's Air Filter on H1 Carbs Spridgets 5
S TR2/3/3A problem just rebuilt SU carbs Triumph 28
sundown TR6 carbs Triumph 2
doc50 Su carbs for a Metropolitan? Other British Cars 1
S SU carbs AUD9124 on a Jaguar ? Jaguar 2
R TR2/3/3A Stromberg vs. SU carbs [discussion/advice] Triumph 17
D BJ8 Carbs Overflowing Austin Healey 20
T TR2/3/3A Will 5W/20 oil work ok in carbs Triumph 4
R TR2/3/3A Rebuilding H4 carbs Triumph 8
Martinld123 SU carbs lose fuel prime when not running Austin Healey 3
steveg Excellent source for info on and rebushing of SU carbs Restoration & Tools 0
Jim_Gruber Screws for HS-2 carbs Spridgets 5
Talon TR2/3/3A Float lever issue on SU type H carbs Triumph 1
D TR2/3/3A Fuel line run from pump to carbs Triumph 5
edkap2002 TR6 Topping up cd175 Carbs Triumph 8
doc50 Wanted H2 SU carbs / manifold for 1275 1973 MG MIdget Spridgets Classified 3
HighAltitudeTR3 TR2/3/3A SU H6 Carbs all out of whack!! Triumph 14
J Backfire through carbs Austin Healey 3
wangdango Colortune for HD8 Carbs? Austin Healey 55
DrEntropy For Sale MGA carbs: AUC 784 MG Classifieds 0
E TR4/4A Vacuum connection on SU-H6 carbs Triumph 4
C Ruddspeed carbs Austin Healey 28
Marla TR4/4A Carbs too lean? Triumph 11
M SU H-1 Carbs: Are These Just Different? Spridgets 2
jfarris For Sale Air Horns for SU HD6 Carbs Triumph Classifieds 4
A TR6 TR4 SU carbs for ZS carbs on TR6? Triumph 13
J Wanted tri-SU carbs, manifold and linkage for '69 series 2 4.2 Jaguar Classifieds 3
H T-Series TD carbs MG 3
Tinkerman TR2/3/3A Rebuilding SU carbs 1960 TR3A Triumph 3
M Wanted SU H6 Carbs Jaguar Classifieds 0
M MGB MGB Special Tuning 4 Cyl Carbs - Need Help w ID and Replacement Needles MG 1
Lin Helicoils in SU carbs Austin Healey 5
