5-speed trans capacity??
Nelson
I don't have my paper work with me and I can't recall how much oil the 5-speed should have. I filled it till it ran out the fill hole and now I wonder if I messed up and overfilled it. How much should it have in it??
nomad
Till it runs out the fill hole!! (Assuming you are filling thru the plug in the side of the trans.)
Kurt.
Nelson
Nelson
Thanks. I was hoping I had done it OK. Now to get the SU's and the timing set correctly. I drove it today for the first time but it lacks the power it should have and it overheated. The air temperature was 90ish but the radiator went in the 200 degree range. My buddy thinks the timing may be a factor and he doesn't like the way my H4's are set. There are times when this hobby isn't the fun I'd like it to be.
You running twin H4s on a 948, they don't even do that with 16.0 to 1 948 race engines, way too much carb for streetable 948 car. I'd look at finding a set of HS2s for that car.
Nelson
Nelson
These carbs were an option installed by Donald Healey in England shortly after I bought the car from him. They installed them along with what they called a "high efficiency exhaust system." It was headers and a pretty much straight muffler. Back here in the States Dave Tabor reworked the engine to what he said was as much as could be done to it and still have a street driver. It has the valves fron a 1098, the head was shaved 0.080 and it was bored 0.040. Along with that the engine was balanced and the flywheel lightened. There is also a hot street cam. It ran very well for me for nine years before I pulled it to do the body rebuild that I just completed.
S For Sale 3000 BJ8 Laycock 4 speed with 22% OD trans & 2 6 cyln engines / long blocks / BUNDLE Austin Healey Classifieds 1
Patrick67BJ8 Speedometer Cable-5-speed Trans Austin Healey 6
6 datsun 210 5 speed rear seal won't stay in trans. Spridgets 22
bugedd 5 speed conversion trans oil Spridgets 7
B Datsun 5-speed trans for sale in Los Angeles Spridgets 4
RickB Maybe a new small 5+ speed trans-plant?? Spridgets 6
B Anyone need a 5-speed trans? [NFI] Spridgets 35
B Anyone need a 5-speed trans? [NFI] Spridgets 1
BugeyeNJ58 Garage Clean Out-1100 Engine and 4-speed Trans. Spridgets 5
mrsprite Datsun 5-speed trans. for sale Spridgets 4
RickB 5 speed trans, please look & tell me it is the one Spridgets 13
bluemiata90 MIATA 5 SPEED TRANS INTO A 1974 MIDGET, POSSIBLE?? Spridgets 2
Bruce_B Motor & trans are in..5 speed question for my BE Spridgets 1
14dna 5 speed trans MG 7
B Possible Datsun 5-speed trans avail near Seattle Spridgets 0
mjobrien 3 Speed Trans Austin Healey 4
J Five Speed Trans. MG 8
M Wedge Trans Oil for TR7 5-Speed ? Triumph 7
R MGA MGA - Rebuild stock trans/go for 5-speed? MG 2
Y TR6 TR6 5 speed Trans Triumph 10
crispy Idle Speed Variation Austin Healey 19
Cappy Toyota 5-Speed Austin Healey 3
Cappy Toyota 5 Speed transmission Austin Healey 4
T Wedge TR7 4 speed wheel cylinders on 5 speed (locating pin) Triumph 0
G TR4/4A "Engine seized after engaging overdrive at low speed. Triumph 26
T maybe a Datsun 210 5 speed available in Oakland? Spridgets 2
B 1966 TR4A two speed wiper motor Triumph Classifieds 1
I GT6 A type OD vs D type - engagement speed? Triumph 3
HealeyRick Toyota 5 Speed - Truck or Supra? Austin Healey 16
Michael Oritt Toyota 5-speed shifter bushing Austin Healey 7
roscoe 5 speed conversion question Austin Healey 9
Lin Toyota 5-speed bell housing drain hole Austin Healey 14
roscoe Caving In [5-speed conversion for BN2] Austin Healey 29
HealeyPassion Aftermarket heater/defroster with 3 speed fan Austin Healey 15
Editor_Reid “Healey: Cars for Speed & Glamour” Exhibition Austin Healey 5
S TR2/3/3A Speed O not working Triumph 27
M TR6 5 speed conversion Triumph 16
PAUL161 T-Series Who's still building 5 speed conversions. MG 4
Z For Sale TR4 - 4 Speed Triumph Classifieds 7
M For Sale 5 speed kits for supra conversion Triumph Classifieds 0
B Trying to contact Pete Delaney 5 speed. Austin Healey 15
M 5-speed, 1968, 4.2, E-Type, OTS Jaguar 3
Bayless Question on 1 speed wiper motor Spridgets 2
Rut 5 speed install Spridgets 14
drooartz Leaking 5-speed drain plug Spridgets 26
Michael Oritt Toyota 5-speed Problem Austin Healey 28
F TR6 Squeal When Turning Sharply at Low Speed Triumph 6
S Wedge 4-speed gearbox problem Triumph 6
J For Sale 1976 Sptifire with 1.8L Miata engine/5-speed [running like a boss!] Triumph Classifieds 0
