2nd gear whine [1500 midget]
RobSelina
Get a lot of gear whine in 2nd gear. Is this normal? anything that can be done to quiet it?
Thanks! /ubbthreads/images/graemlins/thumbsup.gif
Rob
aeronca65t
Not especially normal.
Be sure that your car has real gear-oil in the trans. The older Midgets (1275) use motor oil in the trans and it's a common mistake to put motor oil in a 1500 box.
The Red Line synthetic gear oil is excellent...will make a noticable improvement in shifting and smoothness (and available from their web site).
gear oil is the stuff, i used hypoid gear oil, and it all blew out. i found some gear oil that speciffically said not for limited slip. only for topping off a limited slip. it was a Coastal product.i have had no more problems i have never tried the redline stuff.
mark /ubbthreads/images/graemlins/driving.gif
Bugeye58
I run Royal Purple in both the Spitfire racing gearbox, and the street GT6 and have had no problems. These are both essentially the same tranny as the 1500 Midgets.
Jeff
RobSelina
RobSelina
good deal, heard good things about redline synth and royal purple... I'll get some redline and switch out the fluid. I've heard this is an interesting task since you have to fill from within the interior, removing some rubber covers... is this the case?
rob
here is what i did Rob,
Drain and Replace the drain plug. use a length of rubber hose long enough to reach the fill plug from under the hood. three foot or so. i think i used 5/16. my oil came in a round bottle the type with the tapered cap, that you cut with a knife. press firmly into the hose and start squeezing. takes a few minutes. worked for me.
Matthew E. Herd
Seeing as I have the same problem that Mark had with the oil blowing out of the breather, I actually obtained a pump, I believe its referred to as a 'suction pump' at the parts store, but it has a flexible tube on it and a piston which will allow you to push or pull fluid as necessary (like into the trans fill hole from underneath the car).
RobSelina
RobSelina
thanks guys, i'll see how much one of the pumps will run me at NAPA and pick it up if it's not an arm and a leg and my first born...if it is, I'm copying mark /ubbthreads/images/graemlins/smile.gif
Matthew E. Herd
Figure 5-10 bucks ... the hose'll be about 3-5 ... not a big difference, and the pump can make stuff flow UPHILL (ooohh ... ahhhh!) /ubbthreads/images/graemlins/smile.gif
Good luck!
luke44 TR2/3/3A TR3 not engaging 2nd gear Triumph 24
tr6nitjulius General Tech Visual/audible Fix no 1st/2nd gear Triumph 0
tr6nitjulius General TR Final solution to no 1st/2nd gear issues Triumph 2
Got_All_4 TR6 2nd Gear Bush Problem TR6 Looking at Steel Triumph 12
K TR2/3/3A Gear shift pops out of 2nd gear sometimes? Triumph 5
AUSMHLY 2nd gear should I file it? Do gears have a hard coating? Austin Healey 7
doc50 TR2/3/3A Pops out of 2nd gear Triumph 7
Csarneson Source for BN4 2nd Gear Austin Healey 8
R bj7 hard shifting into 1st & 2nd gear Austin Healey 6
H 1st and 2nd gear problems Austin Healey 5
B 2nd gear blocking ring failure BJ7 Austin Healey 5
Coyote1 2nd Gear OD or Not Triumph 19
H jumping out of 2nd gear Austin Healey 3
theleisure 2nd Gear, Please Don't Go Away! Spridgets 8
Jayrz Poor Shifting 2nd gear MG 5
71tr TR6 Moss replacement 2nd gear bush - TR6 Triumph 0
AUSMHLY 2nd gear Austin Healey 5
zimmy wanted- 2nd gear for 1275 Spridgets 9
zimmy jollyroger -2nd gear for 1275 Spridgets 4
zimmy 2nd gear Spridgets 6
T General TR Another trans popping out of 2nd Triumph 14
tr6nitjulius TR6 TR6 No 1st/2nd problem/solution Triumph 4
M T-Series MG TD 1st/2nd sliding hub end play MG 1
W TR6 Seat diaphragm failure on 2nd seat! Triumph 8
W Find gearbox rebuild [2nd synch shot] South. California Jaguar 1
AUSMHLY Shifting into 2nd, problem because of the Flywheel? Austin Healey 21
KVH General Tech Grinding Gears in Shift From 1st to 2nd Triumph 13
DerekJ Jack Rawles Racing at Zandvoort. From 6th to 2nd. Austin Healey 4
TR3driver TR4/4A New document available - TR4A Spare Parts Catalogue 2nd edition Triumph 5
Lotus Club SoCal 2nd Saturday Breakfast – Lotus Club of SoCal Activities Planning Meetings Lotus 0
M TR2/3/3A 2nd commission [vin] number??? Help. Triumph 12
glemon TR5/TR250 Tranny Won't go into 2nd TR250 Triumph 13
F 2nd set of detail questions: 1963 BJ7 Austin Healey 21
dougie Cali Healey Owners - Sonoma June 2nd -5th Austin Healey 9
Jim_Gruber 2nd Grease Fitting on Fulcrum Pin Spridgets 5
bigjones TR2/3/3A TR3/4 clutch adjustment and shifting into 2nd Triumph 5
EricG Sunbeam Gathering- Oct. 2nd, Columbia,SC Sunbeam (Rootes) 0
R lost 1st and 2nd! Spridgets 10
regularman 2nd condenser in a short time. Spridgets 13
B Last Green Valley Rallye, May 2nd Jaguar 5
AUSMHLY Youtube...Finished my 2nd video....007 Healey Austin Healey 16
J Downshifting from 3rd to 2nd Austin Healey 7
T 2nd day of Amos Triumph 24
D no syncro 2nd advice MG 13
A Gearbox rebuild - popping out of 2nd advice? Video Austin Healey 18
Mg_Bizzle Considering 2nd hand engine, advice needed MG 26
Brosky 2nd Valley of Sin run SE MA & RI Triumph 0
fmichaels 2nd tranny rebuild inprog Spridgets 11
T Crypt Clutch 2nd Look-see Triumph 203
aeronca65t OT: Mother Ship is out of here! 2nd Diff broke! Spridgets 0
