210 tranny starter cover
lbc_newbie
When I pulled the engine and tranny, I noticed that the starter bendix is completely exposed on the back-side of the bell-housing. Anyone know where I can get a cover? It looks like it will have to be custom made. I understand on the original Brit transmission, there is a small cover to hide the Bendix drive sticking out there. It can be modified to fit. Anyone have one lying around?
Nelson
I didn't like having the starter exposed on my 5-speed so I now have a fabricated cover over it. I have a photo of the cover on the third page of my webshots photos. I drilled and tapped three 10-32 holes in the tranny cover to hold it in place. When I installed it I sealed the joint with RTV since I wanted it to be waterproof. I haven't gotten around to getting a picture with in place. I doubt that there is a commercially available cover. HTH
nomad
If your setting up a new 210 5sp I believe it is possible to have a engine plate made up and your flywheel turned to fit a datsun ring gear so that you can use a datsun starter and stock transmission housing. That seems to be a lot neater solution than what is common. Ask Paul A at morris service about this. Seems I heard it somewhere.
KA
Billm
Actually Kurt that was my car you are talking about- I put a Datsun ringgear on my Spridget flywheel and use a Datsun starter, then no hole in the tranny is required.
Bill
Westfield_XI
I used a gear drive starter on my A-series with 210 gearbox and didn't have to cut a hole in the bellhousing. The starter would be a nice upgrade in it's own right.
texas_bugeye
Ditto! Same setup cant be beat.
nomad
I had forgotten you had that setup on your car Bill. Seems like a good way to go. Hope to see you and Bill L for Midget 50. I was wondering if gear reduction requires different rear plate and ring gear change?
lbc_newbie
lbc_newbie
Sorry to confuse you, Bill! I forgot the quote....
Nelson, do you have the design specs on this? I'd love to fabricate one without having to re-invent the wheel! BTW, awesome job on your LBC, buddy!
Jim_Gruber 210 Tranny Shop Manual Spridgets 2
Jim_Gruber 210 Tranny Case Mods started this evening Spridgets 15
Rut 210 tranny Spridgets 10
lbc_newbie Datsun 210 tranny....ventilation or missing screw? Spridgets 2
Gundy Looking for a Datsun 210 tranny Spridgets 16
lbc_newbie Gear oil type for 210 4 speed tranny.... Spridgets 3
mrsprite Who needs a Datsun 210 tranny? Spridgets 12
T maybe a Datsun 210 5 speed available in Oakland? Spridgets 2
T 1979 Datsun 210 at U-Pull in West Palm Beach, FLA Spridgets 1
Rut Datsun 210 Spridgets 5
T Finding Datsun 210 transmissions or other obscure used components Spridgets 1
Jim_Gruber Searching for Datsun 210 Front Bellhousing from a Trashed 210 Spridgets 10
Rut 1275, 210 5 speed, adapter kit, 3.90 Spridgets 6
bugedd Datsun 210 Trans Question Spridgets 9
RickB Datsun 210 5 speed dogleg on Seattle Craigslist $350 -nfi Spridgets 5
RickB Datsun 210 with manual transmission $500 Spridgets 0
RickB OT - NMC - looking for a radiator for my wife's 210 Spridgets 8
C 1981 Datsun 210 for $900 Spridgets 0
R WANTED : Datsun 210 5 speed gearbox Other Cars 9
Gerard Release bearing return spring for 210 gearbox Spridgets 3
Rut 210 for sale Spridgets 1
RickB Thought I saw a 210 - but it was just a B Spridgets 6
BlueMax 210 5 speed Gearbox Spridgets 0
6 datsun 210 5 speed rear seal won't stay in trans. Spridgets 22
Jim_Gruber 210 5 Speed listed on Bugeye Parts Forum Spridgets 1
bugedd Datsun 210 trans question Spridgets 33
RickB Datsun 210 on Craigslist Spridgets 5
B Datsun 210 5-speed [NFI] Spridgets 5
B Datsun 210 5-speed [NFI] Spridgets 0
RickB Datsun 210 motor and 5 speed Spridgets 6
M T9 or Datsun 210? Spridgets 15
B How to identify a Datsun 210 5-speed transmission Spridgets 0
B Datsun 210 donor Spridgets 2
RickB Datsun 210 with 5 speed on Seattle CL $500 Spridgets 19
M Datsun 210 transmission 5 speed shift lever Austin Healey 4
B Dat 210 w/5-speed in Seattle area [NFI] Spridgets 4
G 210 5 speed parts problems Spridgets 3
G What's the slave cylinder part # for 210 swap? Spridgets 1
G Datsun 210 5 speed disassembly Spridgets 22
B Datsun 210 trans value? Spridgets 32
G Found a 210 for $200 sitting in a field Spridgets 9
G Found a 210 wagon Spridgets 9
T Shift Levers for Datsun 210 5 speeds???? Spridgets 34
RickB Orlando CL - Datsun 210 with 1500 & 5 speed +weber Spridgets 4
RickB Datsun 210 w/5sp Seattle Craigslist [nfi] Spridgets 0
T Datsun 210 - noisy? Spridgets 8
RickB Datsun 210 for sale in WA [craigslist] Spridgets 3
M Datsun 210 Trans Problem Spridgets 9
John Moore Woo Hoo! I found a 210 Box Spridgets 4
B Another Datsun 210 w/5-speed in Seattle Spridgets 9
