2002 Beetle question
JPSmit
My wife got in the car this am and it started, goes into gear fine but will not accelerate at all. push the pedal and it idles. Nothing changes - any ideas?
jessebogan
Failure of the throttle body, or gas pedal sensors. Was the battery disconnected? There is a re learn process that can be done with a scan tool (VW specific, not autozone quality...)
JPSmit
JPSmit
battery was not disconnected
jessebogan
You need to have someone re set the adaptations. If they can do that, they can look at the appropriate "address" and verify if the pedal sensors are working, and whether or not the throttle motor itself is responding on command. I know of no short cut.... sorry.
jessebogan
jessebogan
Oh wait, I did think of something. I don't think the ECU will let it raise the RPM if the brakes are applied. Check that the brake lights are not stuck on.
JPSmit
JPSmit
So, lifted the hood, pulled the cover off the hood, spent the 13 minutes the mancode requires staring intently at the engine, closed the hood and called CAA and had them tow the car to my mechanic. Got a call today, had done every diagnostic exercise he knew and and a few he made up - then looked at the gas pedal and realized the variable resistor had come unplugged. Plugged it in and it's good to go. Only charged me 1/2 an hour diagnosis. I figure he spent three times that.
Platinum
He's a keeper! :laugh:
G FOR SALE - 2002 XJ8 Vanden Plas Jaguar Classifieds 0
P 2002 Accord problem Other Cars 31
Michael Oritt Post- Open Roads 2002: Tahoe to MD the long way Austin Healey 19
Michael Oritt Open Roads International 2002: A Journal Austin Healey 37
M Looking for a Vendor to Repair 98 - 2002 XJ8 ECM Jaguar 2
Marvin Gruber 2002 XKR Jaguar 6
T BMW 2002 race car Other Cars 20
S POWER WINDOW PROBLEM ON A 2002 XK8 Jaguar 6
BritCarFan 1998-2002 Land Rover Discovery Rover / Land Rover 1
PeterK TR2/3/3A BMW 2002 fan on my TR3A Triumph 17
W 1995 4.0 SE/2002 Discovery II Trailer Hitch Rover / Land Rover 1
C 2002 2003 vandenplas Jaguar 2
Sherlock Neat BMW 2002 prototype Other Cars 7
Bret MGB MGB Driver Vol 12, No. 6 Nov/Dec 2002 MG 0
jackq 78 Beetle vert Other Cars 0
jackq Custom Beetle Other Cars 8
JPSmit New Beetle electrical question Restoration & Tools 9
JPSmit Beetle Signal Symptoms Other Cars 6
JPSmit VW Beetle trivia question Other Cars 16
J 66 beetle question for the beetle gurus Other Cars 4
G Midget versus Beetle Cabrio Spridgets 5
DonC1948 TR6 A "CLASSIC" question. Triumph 6
K TR2/3/3A Cylinder Head Bolt question.... Triumph 3
D TR2/3/3A TR2 Flying Mile question Triumph 11
M New Member with an HD8 Carb Question Austin Healey 1
Gliderman8 TR6 New shocks (damper) question Triumph 4
D TR2/3/3A Windshield assembly question Triumph 6
T MGB Quick question about something that don't really matter just want to know. MG 9
CARSINC Throttle linkage question Spridgets 1
S TR6 Steering question you will not hear every day Triumph 1
JPSmit Hypothetical Question of sorts - wheel bolts Restoration & Tools 12
E TR6 TR6 flip-up bonnet question Triumph 4
D TR2/3/3A headlight question Triumph 8
D A distributer question on the 1275 engine. Spridgets 7
P TR2/3/3A TR2 Headlight Trim Question: Triumph 8
SherpaPilot TR6 Ignition Switch Question Triumph 13
SherpaPilot TR6 Engine Mounting Question Triumph 3
5 TR2/3/3A TR3 fender patch panel question Triumph 10
WHT Oil Sump Question For Dougie Austin Healey 0
LD-Ordie Series II gear lube question Rover / Land Rover 3
T TR2/3/3A TR3A Windshield Question Triumph 4
