Well, our 2000 Vanden Plas has been off the road now for about 3 weeks. She cranks and cranks, but will not start. She doesn't even try to start, all she does is crank. We have had a new fuel pump fitted, as well as a new evaporative loss flange, link lead, seal, and new sparkplugs, but still the same thing.
Does anyone have any idea what the problem could be without me having to resort to take her into Jaguar? I am going to replace the fuel pump relay, but I do not know which one is for the fuel pump in the trunk fusebox. Also, I have tried and tried to find the inertia fuel shutoff switch beneath the passenger side fascia, under the glovebox... but I cannot for the life of me locate it to see if it has been tripped.
I know another possible reason for this non-starting could be the immobiliser malfunctioning and staying ACTIVE and thus telling the fuel pump relay to keep its mouth shut, so to speak, and not relay power to the fuel pump, but is there any way to check for this personally? Or again, is that something it needs to be hooked up to a Jag computer to do?
Any help would be appreciated, as I am at a loss really. The Fuel Pump Relay was tested as good by our mechanic, but I am not going to put too much faith in him anymore, after charging us so much money to repair the car, then returning it in the same condition it was in prior to him taking it.
Here are a couple of photos that may be of help, one is off the trunk fusebox and the other is of the area the inertia fuel shutoff switch should be. From what I have been told, the inertia switch is a black box, about the size of a cigarette-pack, with a push-button type device in the top. I have looked and looked some more, and for the life of me cannot locate the bloody thing, so any help on that and which relay the fuel pump is, I would appreciate greatly.
Thanks guys,
Scott
Thanks guys,
Scott
