Spitfire 1979 Triumph Spitfire 1500
timtucker
The soft top on this car is the wrong color (camel) it should be black...anyone have a good top supplier that I can get a original top for it? Thanks!
N For Sale 1979 Triumph Spitfire Triumph Classifieds 2
T Spitfire 1979 Triumph Spitfire 1500 rear wheel alignment Triumph 4
B Spitfire Sellng my 1979 Triumph Spitfire 1500 Triumph 1
humanoid For Sale - Haynes Triumph TR7 (1975-1979) Owners Workshop Manual Triumph Classifieds 0
C Triumph colors from PPG book 1979 Triumph 2
T 1979 Datsun 210 at U-Pull in West Palm Beach, FLA Spridgets 1
J Spitfire 1979 Spitfire Running rough [sputtering, exhaust poping] at start up Triumph 2
boxofparts MGB busy tach on 1979 MGB at 75 mph MG 3
FlyingCat Wanted 1979-80 Spitfire Radiator Mount Bracket and Cradle Triumph Classifieds 0
Morris For Sale Fuel Injected 1979 MG Midget Spridgets Classified 0
wingsandwheels For Sale 1979 MGB for sale MG Classifieds 0
Z MGB 1979 Timing problems after removing distributor - Help Please! MG 28
wingsandwheels MGB 1979 MGB coil w/ altered wiring MG 6
B Spitfire 1979 Spitfire Emissions Triumph 4
D 1979 Spitfire Spotted 0
R Spitfire Lbs of compression Spec for 1979 Spitfire. Triumph 3
N MGB 1979 MGB exhaust replacement. MG 1
Andrew Mace Wedge 1979 [Fed.] TR7 fuel tank questions Triumph 6
A MGB 1979 MGB Flasher Big Headache MG 3
AngliaGT 1979 B Owner's Manual MG 6
T MGB 1979 MGB with Weber carb MG 6
R MGB Testing temp sending unit 1979 MGB MG 6
startech47 1979 Midget rear hub bearing nut torque spec. Spridgets 3
M zenith float adjustment 1979 MG 1
ronzet Needed EGR valve for a 1979 MG Midget Spridgets 20
H Valve cover paint 1979 Midget Spridgets 8
startech47 1979 Midget Wheel Bearing Numbers Spridgets 0
P 2 midget problems 1979 help! Spridgets 2
C MGB 1979 MGB Zenith Stromberg Carburetor MG 3
B Have Available for Midget [Its from a 1979]... Spridgets 0
B 1979 Midget Wiring Diagram, Harness, etc. Spridgets 6
PATR8 1979 MG for sale MG 1
B 1979 MG Midget Headrest available..just pay shipp. Spridgets 2
1979Roadster 1979 OVERDRIVE TRANNIE MG 3
B Help with 1979 Radiator Spridgets 19
1979Roadster MGB 1979 MGB SITTING FOR 17 YEARS MG 12
B 1979 MG Midget Headrest Available! Spridgets 3
C MGB 1979 MGB steering wheel socket? MG 1
C MGB 1979 MGB door mirrors MG 4
B My 1979 Midget...before and on its way to rebirth! MG 10
kyreb1862 Wedge 1979 TR7 Roadster Automatic Triumph 0
startech47 Static timing a 1979 Midget Spridgets 4
X 1979 LE console removal MG 9
S 1979 rear shock conversion kit worth it? Spridgets 10
S White disk in drivers seat 1979 Midget? Spridgets 3
M Spitfire Removing the emergency brake grip;1979 Spitfire Triumph 0
I 1979 wont go into reverse MG 10
H Geoff Healey @ Encounter 1979 - 8trac tape Austin Healey 9
C MGB 1979 MGB Photos MG 6
G Good ideas for 1979 MG B MG 2
