TR6 1973 tr6
sundown
Thanks guys for the fuel filter issue. I check the fuel pump seems to be working fine. I can't seem to get that sluggish movement figured out it almost feels like the car is doing the cha cha.I double checked the ignition timing the dizzy gap is good I did start fussing with the carb mixtures on the 175cd zs It seems even when i completely rich them out when i lift the piston it almost stalls as if they are too lean ? Thanks
poolboy
When you say "turning the valve down" what exactly were you doing ?
The air valve should not move one bit or you will tear the air valve diaphram.
And in order to enrichen the mixture you must turn the allen wrench clockwise, which raises the needle.. If you went counterclockwise..oh oh .
Please explain.
sundown
sundown
Sorry for the confusion I am turning the allen wrench clockwise which is raising the needle to the point where will not turn anymore but when i lift the carb pistons 1/16 up as noted in the bentley manual the engine wants to stall out as if it is too lean of a mixture?
poolboy
The carbs used in 73 were unique in a certain respect.
73 was the first year that an anti runon feature was incorporated into the carbs' design..and I have a feeling that the design to accomodate that feature was problematic from the beginning because in 74 a new design came out and remained unchanged until the very end in 76.
I've worked on enough of the 73 carbs to say..it's a common problem.
If your "vent valve" looks like this that may be the problem particularly if the problem you describe happens at idle and during the transition form idle to accelertation.
poolboy
See if you can blow air into this nipple when the engine is not running..you should be able to with no noticeable resistance:
J TR6 1973 TR6 Rear Brake Operation Questions Triumph 4
M Wanted Tr6 1973 Triumph Classifieds 2
nichola TR6 1973 TR6 Restoration - it’s a roller again! Triumph 4
sundown TR6 1973 Tr6 alternator Triumph 6
B For Sale 1973 tr6 Triumph Classifieds 0
GBRandy TR6 1973 TR6 Rear Frame / Body Bushings Triumph 3
W TR6 1972 or 1973 TR6 Triumph 9
sundown TR6 1973 TR6 plugs Triumph 4
sundown TR6 1973 TR6 mossmotors sport exhaust system Triumph 6
sundown TR6 1973 TR6 blow by or leak? Triumph 6
sundown TR6 1973 TR6 flasher question Triumph 6
sundown TR6 1973 tr6 Triumph 3
sundown TR6 1973 TR6 Heater Triumph 1
sundown TR6 1973 TR6 seats Triumph 1
sundown TR6 1973 TR6 vacuum reading Triumph 2
sundown TR6 1973 TR6 oil between the head and engine block? Triumph 11
sundown TR6 1973 TR6 carb/ TBV Triumph 5
sundown TR6 1973 TR6 bypass valve Triumph 1
sundown TR6 1973 TR6 fuel pump Triumph 4
sundown TR6 1973 TR6 ZS carb mixture Triumph 2
sundown TR6 1973 TR6 door check straps Triumph 3
sundown TR6 1973 TR6 hydraulics Triumph 1
sundown TR6 1973 TR6 emissions plumbing Triumph 1
sundown TR6 1973 TR6 emissions plumbing Triumph 8
sundown TR6 1973 TR6 timing light Triumph 3
sundown TR6 1973 TR6 vacuum leaks Triumph 1
sundown TR6 1973 TR6 brake booster hose Triumph 7
sundown TR6 1973 TR6 charcoal canister Triumph 6
B TR6 1973 tr6 water pump Triumph 4
sundown TR6 1973 TR6 strombergs Triumph 3
sundown TR6 1973 tr6 Triumph 8
sundown TR6 1973 tr6 Triumph 5
sundown TR6 1973 tr6 Triumph 0
sundown TR6 1973 tr6 oil pressure light Triumph 3
sundown TR6 1973 TR6 flasher unit Triumph 1
sundown TR6 1973 tr6 wiring Triumph 21
jerrybny TR6 1973 TR6 Seat Covers Triumph 2
2wrench GT6 1973 Triumph GT6 MK3 Engine for a TR6, yes or no? Triumph 10
G TR6 Zenith Stromberg [1973 TR6] help Triumph 5
JoeC TR6 1973 TR6 parts car Triumph 2
jerrybny TR6 1973 TR6 Front License Plate Bracket Triumph 1
R TR6 1973 Final drive issues Triumph 5
K 1973 MGB for sale MG Classifieds 0
S For Sale Triumph GT6 Workshop Manual on CD/ROM – 1966 through 1973 Models Triumph Classifieds 0
doc50 Wanted H2 SU carbs / manifold for 1275 1973 MG MIdget Spridgets Classified 3
J MGB 1973 MGB Value MG 8
E TR6 1973 TR-6 Unbalanced Intake Triumph 11
Paulus Thermovacuum switch for a 1973 V12 XKE Jaguar 4
Boink 1973 Marcos MINI Spotted 1
