TR6 1973 TR6 flasher question
sundown
Having a heck of a time trying to figure out this issue. If you read my previous post about wiring I just cannot figure this out. I bought a new hazard flasher unit. I did not hook up the connections to the unit the wires were just hanging there yet for some reason I tried the flashers and they work? I have look at the wiring diagram hard to follow since some of the wires are not the correct wire color. Getting nervous no fires please. Any Help?
TR3driver
Great Pumpkin - R.I.P
Not sure there is much we can do to help. Someone has obviously made some "improvements" and you're probably going to have to either work out what they are, or figure out how to remove them.
But just to double-check, you mean that the hazard (aka 4-way) flashers work without the flasher module connected, right? Do they work with the key off? Do the regular turn signals work as they should (with the hazard switch off of course) ?
sundown
sundown
Yes the flasher does work without the module when the key is off and when the key is on.The turn signals work perfectly as do all the other lights (headlights, brake lights, reverse lights) when the key is on, but the headlights will stay on even the key is off. Thanks for any input
TR3driver
Can you hear what is clicking when you run the hazard flashers?
The original wiring to the hazard switch is rather odd, and keeps the turn signals from working if there is a problem with the hazard switch. But if the turn signals don't work with the key off and the hazards do, then I think there is likely to be another flasher unit somewhere. The turn flasher normally only gets power when the key is on.
trrdster2000
Randall is right, there are two different flashers one for each system, so all sounds well. There is one flasher on the left hand front inner finder and the other is under the dash near the Tachometer.
Wayne
Gliderman8
Wayne the "one" by the tachometer is a voltage stabilizer. The flasher for the turn signals on the TR6 is located on the passenger side footwell, attached on the right side kick panel.
trrdster2000
Thanks for the correction, been a while since I had to mess with a "6". Better knock on wood, mine will get me back.
Wayne
sundown TR6 1973 TR6 flasher unit Triumph 1
J TR6 1973 TR6 Rear Brake Operation Questions Triumph 4
M Wanted Tr6 1973 Triumph Classifieds 2
nichola TR6 1973 TR6 Restoration - it’s a roller again! Triumph 4
sundown TR6 1973 Tr6 alternator Triumph 6
B For Sale 1973 tr6 Triumph Classifieds 0
GBRandy TR6 1973 TR6 Rear Frame / Body Bushings Triumph 3
W TR6 1972 or 1973 TR6 Triumph 9
sundown TR6 1973 TR6 plugs Triumph 4
sundown TR6 1973 TR6 mossmotors sport exhaust system Triumph 6
sundown TR6 1973 TR6 blow by or leak? Triumph 6
sundown TR6 1973 tr6 Triumph 3
sundown TR6 1973 TR6 Heater Triumph 1
sundown TR6 1973 TR6 seats Triumph 1
sundown TR6 1973 TR6 vacuum reading Triumph 2
sundown TR6 1973 TR6 oil between the head and engine block? Triumph 11
sundown TR6 1973 TR6 carb/ TBV Triumph 5
sundown TR6 1973 TR6 bypass valve Triumph 1
sundown TR6 1973 TR6 fuel pump Triumph 4
sundown TR6 1973 TR6 ZS carb mixture Triumph 2
sundown TR6 1973 TR6 door check straps Triumph 3
sundown TR6 1973 TR6 hydraulics Triumph 1
sundown TR6 1973 TR6 emissions plumbing Triumph 1
sundown TR6 1973 TR6 emissions plumbing Triumph 8
sundown TR6 1973 TR6 timing light Triumph 3
sundown TR6 1973 TR6 vacuum leaks Triumph 1
sundown TR6 1973 TR6 brake booster hose Triumph 7
sundown TR6 1973 TR6 charcoal canister Triumph 6
B TR6 1973 tr6 water pump Triumph 4
sundown TR6 1973 TR6 strombergs Triumph 3
sundown TR6 1973 tr6 Triumph 8
sundown TR6 1973 tr6 Triumph 5
sundown TR6 1973 tr6 Triumph 0
sundown TR6 1973 tr6 oil pressure light Triumph 3
sundown TR6 1973 tr6 wiring Triumph 21
jerrybny TR6 1973 TR6 Seat Covers Triumph 2
2wrench GT6 1973 Triumph GT6 MK3 Engine for a TR6, yes or no? Triumph 10
G TR6 Zenith Stromberg [1973 TR6] help Triumph 5
JoeC TR6 1973 TR6 parts car Triumph 2
jerrybny TR6 1973 TR6 Front License Plate Bracket Triumph 1
R TR6 1973 Final drive issues Triumph 5
K 1973 MGB for sale MG Classifieds 0
S For Sale Triumph GT6 Workshop Manual on CD/ROM – 1966 through 1973 Models Triumph Classifieds 0
doc50 Wanted H2 SU carbs / manifold for 1275 1973 MG MIdget Spridgets Classified 3
J MGB 1973 MGB Value MG 8
E TR6 1973 TR-6 Unbalanced Intake Triumph 11
Paulus Thermovacuum switch for a 1973 V12 XKE Jaguar 4
Boink 1973 Marcos MINI Spotted 1
