TR6 1973 TR6 carb/ TBV
sundown
Took a ride last night the TR is running pretty good except when I let off the gas it starts to pop from the exhaust the timing is spot on via a vaccum gauge.Could it be the carb mixture or do I need to mess around with the TBV?
TR3driver
Great Pumpkin - R.I.P
Either way will work, I believe. The TBV was essentially to suppress the popping with leaner mixtures. (Well, actually to suppress the misfiring under overrun conditions, but that's what causes the popping).
titanic
I might be wrong, but I thought the purpose of the TBV was to limit the vaccum on overrun to reduce emissions. SUs of the same era used a less elegant approach-a spring loaded valve in the throttle disc.
Berry
poolboy
It's name Throttle Bypass Valve pretty much describes it's function
When the manifold vacuum exceeded approx. 22 in-Hg the valve is supposed to open and allow whatever mixture is in the carb at the time to bypass the closed or nearly closed throttle disc and enter the combustion chamber.
That addition combined with the limitation of manifold vacuum provides a better mixture so that the combustion is more likely to take place within the combustion chamber instead of waiting until to explode as it enters the exhaust system with more available oxygen. I imagine this cleaner combustion is desirable as far as emissions go as well.
The diaphragm that surrounds and seals the valve, doesn't seem to last all that long. When it's flexibility is lost, the valve may not be able to respond to the manifold vacuum it senses.
The valve doesn't open and you sometimes get that popping
I have mine disabled with a gasket sealing both the inlet and outlet, but I still don't get that popping when I down shift...sometimes if the engine is really hot..a gurgling sound right at first during substantial engine breaking conditions.
sundown
sundown
Thanks, poolboy I am going to disable mine as well. I do not like that pop pop sound. Would a too lean carb cause that also?
poolboy
Yes I believe too lean a mixture will contribute to the popping..Just keep track of your adjustments and do a little experimenting.
But incase I was misunderstood, disabling the TBV may increase the chances of the popping continuing or increasing.
You might also consider disabling the Vacuum retard by removing the vacuum tube from the bottom of the rear carb and capping the same nipple.
That same high manifold vacuum that activates the TBV, will also activate the Vacuum Retard..
The retarded timing doesn't exactly provide ideal conditions for combustion, either, as evidence by the engine picking up idle speed when the retard is disabled and the timing allowed to advance.
You'll have to adjust the idle speed down, though..if the retard was working properly in the first place.
By doing a little experimenting, I think you'll quiet things down.
sundown TR6 1973 TR6 ZS carb mixture Triumph 2
J TR6 1973 TR6 Rear Brake Operation Questions Triumph 4
M Wanted Tr6 1973 Triumph Classifieds 2
nichola TR6 1973 TR6 Restoration - it’s a roller again! Triumph 4
sundown TR6 1973 Tr6 alternator Triumph 6
B For Sale 1973 tr6 Triumph Classifieds 0
GBRandy TR6 1973 TR6 Rear Frame / Body Bushings Triumph 3
W TR6 1972 or 1973 TR6 Triumph 9
sundown TR6 1973 TR6 plugs Triumph 4
sundown TR6 1973 TR6 mossmotors sport exhaust system Triumph 6
sundown TR6 1973 TR6 blow by or leak? Triumph 6
sundown TR6 1973 TR6 flasher question Triumph 6
sundown TR6 1973 tr6 Triumph 3
sundown TR6 1973 TR6 Heater Triumph 1
sundown TR6 1973 TR6 seats Triumph 1
sundown TR6 1973 TR6 vacuum reading Triumph 2
sundown TR6 1973 TR6 oil between the head and engine block? Triumph 11
sundown TR6 1973 TR6 bypass valve Triumph 1
sundown TR6 1973 TR6 fuel pump Triumph 4
sundown TR6 1973 TR6 door check straps Triumph 3
sundown TR6 1973 TR6 hydraulics Triumph 1
sundown TR6 1973 TR6 emissions plumbing Triumph 1
sundown TR6 1973 TR6 emissions plumbing Triumph 8
sundown TR6 1973 TR6 timing light Triumph 3
sundown TR6 1973 TR6 vacuum leaks Triumph 1
sundown TR6 1973 TR6 brake booster hose Triumph 7
sundown TR6 1973 TR6 charcoal canister Triumph 6
B TR6 1973 tr6 water pump Triumph 4
sundown TR6 1973 TR6 strombergs Triumph 3
sundown TR6 1973 tr6 Triumph 8
sundown TR6 1973 tr6 Triumph 5
sundown TR6 1973 tr6 Triumph 0
sundown TR6 1973 tr6 oil pressure light Triumph 3
sundown TR6 1973 TR6 flasher unit Triumph 1
sundown TR6 1973 tr6 wiring Triumph 21
jerrybny TR6 1973 TR6 Seat Covers Triumph 2
2wrench GT6 1973 Triumph GT6 MK3 Engine for a TR6, yes or no? Triumph 10
G TR6 Zenith Stromberg [1973 TR6] help Triumph 5
JoeC TR6 1973 TR6 parts car Triumph 2
jerrybny TR6 1973 TR6 Front License Plate Bracket Triumph 1
R TR6 1973 Final drive issues Triumph 5
K 1973 MGB for sale MG Classifieds 0
S For Sale Triumph GT6 Workshop Manual on CD/ROM – 1966 through 1973 Models Triumph Classifieds 0
doc50 Wanted H2 SU carbs / manifold for 1275 1973 MG MIdget Spridgets Classified 3
J MGB 1973 MGB Value MG 8
E TR6 1973 TR-6 Unbalanced Intake Triumph 11
Paulus Thermovacuum switch for a 1973 V12 XKE Jaguar 4
Boink 1973 Marcos MINI Spotted 1
