1952 austin somerset
JM1NA
There's one here for sale that I might actually look at on the weekend. My dad had one of these and I remember it well.
This one sounds solid with a rblt engine, but hasn't run for awhile $1300 obo Canadian...
Anyone have any info on these cars?
aeronca65t
My first car was a '51 A-40.
Basic early BMC stuff. The engine is an 850 but a newer Sprite engine will go in easily. The trans is a bit different than a Sprite. Mine had 16" wheels and hydraulic brakes only on front (mechanical in back). Lever shocks and king pins. Many had sunroofs (mine did). The trunk lid folds down and is quite large.
They have a comfy but narrow interior.
The hood has a nice "Flying A" that looks just like the Aeronca logo.
Here's a neat one (an A-35, I think):
Sherlock
That picture above is either an A30 or A35 Austin...
As for Austin info check out this website (out of Los Angeles area) www.austinworks.com This New Zealand website might be worth exploring too, run by an Austin nut... https://www.peacockfamily.co.nz/classic.html
There are probably some clubs over in the U.K., specific to Austin, that would likely have some useful websites I would think, just google search and you should find some stuff.
An Austin A40 Somerset is under-powered, typical of many 1950's British family cars. In stock form I'm sure it would be a great local runabout in the Vancouver/Fraser Valley area. Or as Nial mentioned, there are ways to upgrade them very easily using genuine BMC equipment. The only other thing I'd caution is to not pay too much money for it... dollar value on a Somerset (post-restoration) will never be very high and likely never go up much either from present values, personally I wouldn't pay more than $750 for a Somerset needing full restoration, from what I've seen a nice example goes for around $5,000 Canadian, and there are plenty of Somerset's in British Columbia and across the country so they aren't ultra-rare like some cars may be.
Just my two cents and I'm not claiming to be an expert but there is generally lower high-dollar interest in an Austin Somerset than in a sports car of similar age and this will likely always be the case.
[ 04-01-2004: Message edited by: Sherlock ]</p>
Graham
Don't be scared of an A 40 though.
They are not overpowerd but they can still keep up with modern trafic reasonably well. We had an A 40 Devon in the family for years, and after my grandfather had stoped driving an aunt took over the little green Austin. They used to come up to the farm here from Perth (about 120 miles) in it regularly and it never once let them down. It would cruise quite hapily at about 55 MPH but was usualy driven a little slower. The engine is bulletproof, the gearbox can give trouble with age but is not usually to much of a problem, and the suspension and rear axle are well made and relativly trouble free. There were not a lot of Somersets here but thousands of Devons and Dorsets. The Somersets that were here though didn't seem to give too many problems and I still know of a couple of complete ones owned by their original familys.
They weren't renowned for rust over here, but we have a very dry climate that may help keep it at bay and despite what you may read here about Lucas the lord of darkness, the electrics don't give a lot of trouble either. Just bare in mind that it is a 50 year old family saloon and not a sports car and I am sure it will give you good service.
Good luck.
JM1NA
JM1NA
Thanks, all,
I realize that a somerset will never really be worth much, and it would be a money losing scenario. This beast has been painted with tremclad to keep it from rusting. But supposedly the floors, etc are very solid and the car doesn't need any rust repair. But of course, who knows until you see it. This would just be an occasional driver to the Brit car shows, etc. around here. I've already got a fun sportscar that can handle highway speeds.
I thought the convertible model had twin carbs, and thought the somerset cars had 1200 cc engines in them, but I may be wrong.
There was also a '64 Ford Anglia($600), and a Sunbeam talbot drophead for sale here as well($3,000). Oh and a couple of early '70's Cortinas. Spring cleaning, I guess...
tony barnhill
Great Pumpkin - R.I.P
Hey, its an unusual old car - question is: can it be saved (****, the resale value!)? &, do you want it? I'm a sucker for little orphan cars so I say - GO FOR IT!
Eric
My first car was an A40 Somersault. Yes they were 1200 cc's. Mine was very beat, but I learned a lot. Warped head and shot Armstrong lever shocks - boingy, boingy, boingy......... Very cool car for a young hippy in the late 60's/early 70's. I believe they're early B series engines (not the A's in the Sprites), but I could be wrong.
I've thought about buying one several times, but decided I'd rather have an A40 Dorset pickup.
[ 04-02-2004: Message edited by: Eric ]
[ 04-02-2004: Message edited by: Eric ]</p>
aeronca65t
<blockquote><font size="1" face="Verdana, Arial">quote:</font><hr>Originally posted by Eric:
.....they were 1200 cc's. ....I believe they're early B series engines (not the A's in the Sprites]<hr></blockquote>
You're correct. My earlier reference to 850 cc was wrong (I must have been thinking of Minors).
I think the 1200 cc engine in these Austin cars was the basis for the "XPEG" engine that caused a lot of anguish among MG purists worldwide.
In the 40s and 50s, MG cars came with "real" MG "XPAG" engines. BMC switched over to the Austin-based "saloon engine" in the TF1500 calling it the "XPEG" engine (and they continued to use this saloon-based engine in the MGA and MGB).
If you talk to a real, old-time, died-in-the-wool MG purist, you might hear that the last "real" MG was the early TF (with the last XPAG engines).
An 1800 cc MGB engine would probably fit in one of these cars pretty easy (and I'm positive I saw a 1275 in a Devon, one time). Unfortunately, most of the surviving cars are probably runnning 350 Cu. in. Chevy engines and drag slicks.
waltesefalcon
Nials picture has Peter Brocks name on it. Isn't he the guy who first penned the Cobra Daytona Coupe?
Cheers,
Walter
Graham
Don,t know about that, but one of Australias most famous national sedan racing drivers is Peter Brock. If that is his car, the photo must be decades old.
He has raced Holdens (and others) here for 30 years, no idea if he ever raced Austins. If he did I bet he would never own up to it.
aeronca65t
<blockquote><font size="1" face="Verdana, Arial">quote:</font><hr>Originally posted by waltesefalcon:
Walter
<hr></blockquote>
Yeah, I noticed that too.
I looked around another Aussie site.....this "Pete Brock" is a different guy (and as Graham says, the Aussie guy is a racer, and not a designer.
waltesefalcon
Thanks Nial that clears that up.
Cheers,
Walter
Graham
I don't follow the car racing all that closley anymore, but if they were racing up a "hill", it was probibally mount Pannorama at Bathurst. That is where the Bathurst 1000 (klm) and formerly the Bathurst 500 (mile)is run. It is the most famous domestic car race in Australia, and Peter Brock has won it more times than anyone else, nine times I think, and although nearly retired now he is a local legend. I find it hard to imagine him though driving an Austin A35 race car. A friend here interupting me as I write this says he thinks he did start racing with something like that, so I just dont know.
BEEJAY7
Graham
It was a specific Hill Climb event on closed Public Roads, it was not part of a Race. Looked a really great event.
Talking of Historic Racing, went to Castle Coombe Circuit on Monday, Tony Jardine, (Part of the UK ITV Formula One coverage team) was racing an Austin A40 and Rowan Atkinson (Black Adder) was due to be in the same race with his Aston Martin but didn't turn up.
Regards
Alan
Regards
Alan
[ 04-13-2004: Message edited by: BEEJAY7 ]</p>
Graham
Alan,
It was a hill climb was it ? as mount Panorama is also a public road. They close it off several days a year and hold race meetings on it, and it looks strange on the TV to see people sitting around their houses watching the race. On most days of the year you can take your own car around the track, and the same road rules apply there as anywhere else. It is a race track though, and they race up one side of it and down the other, and it is a "mountain" and quite steep at that. I don't think they run hillclimbs as such there though, I mean the timed against the clock one way type. Whenever they hold any event there though, you can bet Brock'y won't be far away.
V For Sale 1952 Austin A40 Sports Other British Classifieds 0
rovernut 1952 Austin Princess Limo Other British Cars 15
H listing for literature for Healeys from 1946 ti 1952 Austin Healey 1
L For Sale 1952 MG TD MkII MG Classifieds 2
Joe_Healey 1952 Nash Healey Lightweight Austin Healey 12
L T-Series 1952 TD Steering wheel removal MG 8
L T-Series 1952 MG TD2 Title from the USA MG 7
vickxxx T-Series 1952 MGTD spark plugs. MG 4
vickxxx T-Series 1952 MG TD barn find.... MG 7
smaceng T-Series Does a 1952 MGTD use a 12V battery? MG 4
Sarastro T-Series History of a 1952 MG TD MG 3
M Post-War Other OD Switch - 1952 Renown Triumph 2
V 1952 Vincent Black Lightning British Motorbikes 2
S T-Series 1952? Arnolt-MG-closed-coupe-MG-TD-variant-NICE MG 6
vping T-Series Finally my next project - A 1952 TD MG 4
N wrecked my 1952 willys today Other Cars 9
apbos 1952 Noddy British Motorbikes 2
apbos 1952 Singers in CA Other British Cars 7
Z MK IV 1948-1952? 1.5L Dizzy Jaguar 0
SilentUnicorn 1952 Vincent Black Lightning British Motorbikes 0
AngliaGT 1952 Morgan - $1200 Other British Cars 15
martyc T-Series 1952 MG TD For Sale MG 27
vping My 1952 Pics - Comments & tips welcome MG 15
A 1949 - 1952 Ford Prefect Other British Cars 9
Bruce Bowker T-Series 1952 MG TD MG 4
K T-Series 1952 MG TD tires MG 9
dougie Austin Healey 4000 Austin Healey 3
L For Sale Austin Healey Parts!!! Austin Healey Classifieds 0
dougie Celebration of Austin Healey Double Event September 2024 Austin Healey 2
E For Sale Austin Healey 100 and 3000 parts Austin Healey Classifieds 1
Editor_Reid Summer Edition of "Austin-Healey Quarterly" Austin Healey 4
M For Sale Austin Healey 100-4 Lemans Kit OEM Austin Healey Classifieds 5
V Opinions on 1953 Austin-Healey Austin Healey 26
BoyRacer Austin A90 mystery engine British Motor Corp 2
Martinld123 Steering Wheel Alignment [Lost centering on steering box 1956 Austin Healey, BN2] Austin Healey 14
K Carburetor options for a 66 Austin 1100 ? British Motor Corp 3
ROARRR For Sale 1930-40's AUSTIN 10 SALOON! straight, good glass, no through rust, very complete Austin Healey Classifieds 0
Editor_Reid "Austin-Healey Quarterly" e-zine Spridgets 2
Editor_Reid "Austin-Healey Quarterly" e-zine Austin Healey 8
N For Sale Austin Healey Frogeye Sprite Spridgets Classified 0
dougie 1960 Austin Healey 3000 Works Lightweight vs. 1962 Ferrari GTO Austin Healey 6
S Wanted Used Austin-Healy 100/100-6/3000 Restoration Guide By Gary Anderson And Roger Moment Austin Healey Classifieds 14
P Austin A40 Devon windshield. British Motor Corp 2
A Austin A40 trafficator steering wheel Other British Cars 5
T Wanted PANTHER J72 or AUSTIN POLICE CAR switches Other British Classifieds 1
D Wanted Austin healey Tire - used Austin Healey Classifieds 4
G 1951 Austin A40 British Motor Corp 15
T "B" designations for Austin Healey 3000s? Austin Healey 1
TRopic6 For Sale Austin A30 A35 A40 factory manuals Other British Classifieds 0
P Austin Champ Spotted 2
