18V Engine Issue [Thinking Out Loud]
tony barnhill
Great Pumpkin - R.I.P
18V engine w/121,000 original miles - only 1 driver (me!) since day one - engine never opened but well maintained, never any problems - normal good, high oil pressure....
Running super, then wrrrrrrrrrr...lost all power & barely limped home.
Rocker had jumped off push rod...put it back on & adjusted valves & wrrrrrrrrrrr...lost power
Same rocker jumped off push rod...changed complete rocker assembly with a good, used one off shelf & changed the errant push rod....
Great power, then wrrrrrrrrrrrrrrr...no power & barely limped home.
Same rocker had jumped off push rod!
Now, I know that probably means tappet or cam problems...it could just be a tappet sticking or could be a bad cam lobe....way back when - under warranty - the dealer replaced the single chain assembly with a dual chain setup; it might be a problem but I doubt it is; there doesn't appear to be timing issues....it only happens under load; at idle everything is fine!
Tappet or cam, gotta be! DARN!!
I know what to do but I really don't want to do it!
I could pull the intake/exhaust & side cover & remove the offending tappet for examination...
Then, I could remove the radiator, distributor & front cover & timing chain (& slide the cam out for a visual inspection...
But, 120,000 miles? Is it worth it? Or should I just bite the bullet & yank the engine/transmission & do a complete rebuild?
She's back in the garage, cover is over her, oil's fine & she's now officially tucked away for the Winter; I've gotta finish the '63 Midget for the "50th..." show in Missouri before I take on anything else major.....DARN!!
Valve stickin' in the guide, morelike. If it produced good power when the thing's in place the cam is likely okay.
tony barnhill
tony barnhill
Never thought about that, Doc....
Now, hmmmmm, how can I check that without pulling the head?
BFH!!! /bcforum/images/%%GRAEMLIN_URL%%/devilgrin.gif
...just beware of flyin' collets! /bcforum/images/%%GRAEMLIN_URL%%/jester.gif
tony barnhill
tony barnhill
Yep, exactly what I thought....remove rocker assembly, rotate engine until that piston is way down in the cylinder & WHAM a couple of times...
Put it all back together & see how she performs...
If I have to open anything up, this puppy dog's coming out for a full rebuild! But I'm not touching anything until I calm down...breathe....breathe....
"OOOooooommmmmmmm...."
/bcforum/images/%%GRAEMLIN_URL%%/wink.gif
Use a piece of wood twixt stem 'n hammer or a soft deadblow. Maybe drizzle some Marvel down the valve stem before you "work" it, add some to the crankcase and run it thru a few hot/cold cycles. No high RPM revs, just get it thoroughly up to normal temp.
tony barnhill
tony barnhill
Its under its cover - out of sight....
My guess would be a cam lobe, you could always check lift on the offending valve by setting up a magnetic base with dial indicator on the retainer, turn the engine over by hand and see what the valve lifts. I know, I know, you're going to tell me you don't have fancy tools like that, well since you're building your 1098, no time like the present to get one, you can get a cheapie at HF, plus you're going to need one when you start degreeing your cam on the 1098 and the GT race car. So no more exuses big boy, go get yourself a magnetic base and dial indicator /bcforum/images/%%GRAEMLIN_URL%%/smile.gif
If the valve was stuck, it's a good possiblity it would bend the pushrod.
tony barnhill
tony barnhill
<div class="ubbcode-block"><div class="ubbcode-header">Quote:]If the valve was stuck, it's a good possiblity it would bend the pushrod.[/QUOTE]
HUH!! Just looked - pushrod I took out has a tiny bend in it...not much but I can see by holding it up against a straight edge....
Looks more & more like a valve, huh?
Okay, Hap - to HF to ask for a "magnetic base & dial indicator"....hope the instructions are good!!
You won't get the instructions for degreein' a cam with the tool, Tony. You need US for that. /bcforum/images/%%GRAEMLIN_URL%%/smirk.gif
Hap said:
So no more exuses big boy, go get yourself a magnetic base and dial indicator \:\)
AMEN!!
Roll the pushrod on a REALLY flat surface, Tony. If it has ANY deformation it'll roll "funny".
WA1KWA
Years ago we would use a pane of glass to check for pushrod straightness. Oft times it's straighter than a straight edge that's been banging around a tool box for years.
Colin
tony barnhill
tony barnhill
OKAY, I've cooled down...gotta go put tires on the Dodge truck this morning so will stop by HF & pick up a magnetic base & dial indicator....then, I'll try to get home early enough to check the valve lift (got an eye appointment in the early afternoon).
Still have to install the rebuilt brake & clutch master cylinders in the '74-1/2 GT after the last coat of paint I just put on the pedal box assembly dries.
& I need to run by the body shop to check on the '63 Midget.
Glad I don't have a job.......
lawguy
It looks like you are tracking it down well- here's hoping it's the valve- but in case the problem is deeper- a semi-philosophical viewpoint:
We've all heard it said- you can restore a car a dozen times, it's only original once. The same goes for engines...well maybe you can't rebuild a dozen times, but you get the idea.
You have a well maintained engine there and it has a problem (even if the cam) that can be corrected short of a complete rebuild. I know that you don't want to have to open the engine up again in a few months and if this were a car with a less personal history or unknown provenance, I would say- rebuild it. But I, for one, would like to see how long a cared for 18V will run well with the original bore, rings and bearings. I would be tempted to repair (well, of course) whatever is wrong, but not go beyond the problem in order to keep it as original as I could for as long as I could.
'Everyone' has a B with a rebuilt engine. Howmany are running a near original engine with 200,000? Now there's something for the museum.
Just mt 2 cents...wait a minute, that took .2 hours....just my $40.00.
tony barnhill
tony barnhill
hehehehe....lawyers!!
Went by HF today to pick up a dial indicator....its always best to go on-line & print out any of their specials before going to the store...the indicator I wanted is normally $14.99 in the store but on-line was $7.99!!
No magnetic base though...they'd sold out....seems some guys are jumping on the indicators & bases & reselling on ebay...he'll have more bases next week.
Don't know what I'm gonna do but I'll not get to it at least until Tuesday anyway.....& I have worked hard to keep that car completely original since I bought it (heck, I finally gave in & replaced the top & carpet in 2004!)
GTsRFine
The best way to keep it original is to "freshen" the engine at 50k - 70k miles.
Freshen= new rings and bearings and a valve job.
This helps keep the crank/ rods/ bore at original spec.
Running it out as far as you can will just accelerate the wear.
What did the ribcase look like on the inside?
tony barnhill
tony barnhill
<div class="ubbcode-block"><div class="ubbcode-header">Quote:]What did the ribcase look like on the inside?[/QUOTE]
Looks like we've got a winner! Good to see you here, David!
WhatsThatNoise
If I suspect a sticking valve I generally do the finger test.
Put a finger on top of the rocker where it contacts the valve & run the engine...
If it feels 'funny' (different than the others)...Something is wrong.
Some people like to do the strobe thing.
You could easily just replace the valve guide, pushrod & valve.
Sounds like you're going for a milage record... /bcforum/images/%%GRAEMLIN_URL%%/thumbsup.gif
I'd be interested in knowing what the most miles on a original engine is.
Hey-Look...I made Obi Wan...Cool! /bcforum/images/%%GRAEMLIN_URL%%/grin.gif
B 18V engine - how old is it? MG 3
J MGB Need help identifying pistons for 18V motor! MG 0
Marvin Gruber MGC Replacing 18 GB motor with 18V MG 12
B Can I bolt up 3Synco Trans to 18V motor? MG 6
B MGB MGB 18V Distributor base plate screw MG 5
B 18v Block and Big Valve Head for sale in SoCal MG 2
D 18V cam timing MG 5
G TR6 Engine Cutout, Black Smoke, Large Backfire Triumph 7
J TR2/3/3A TR3 engine cylinder top clearance Triumph 22
D TR2/3/3A Engine shakes as it is accelerated. Triumph 26
D Land Rover engine swop. Rover / Land Rover 0
BoyRacer Rover 3.5L (Buick 215 c.i.) Engine Swap Austin Healey 15
Kolecki TR2/3/3A engine assembly cam timing issue Triumph 8
Pool Dad 1960 TR3 engine serial number Triumph 14
J TR2/3/3A "TR3" painted on the engine block Triumph 13
D TR2/3/3A Engine mounts Triumph 11
R Engine Number Plate Austin Healey 2
BoyRacer Engine Swap: 3000 Engine Into a BN1 Austin Healey 22
alexisrexx TR6 Engine Hoses Kit or Hose by the foot? Triumph 6
B Bugeye Original Engine Compartment Sheet Metal. Act Fast! Spridgets Classified 0
BoyRacer Nissan/Datsun engine swap into a 100/4? Austin Healey 30
G TR4/4A "Engine seized after engaging overdrive at low speed. Triumph 26
B COMPLETE DROP-IN Rebuilt 1975/6 MG Midget 1500 engine PLUS rebuilt Spitfire Overdrive trans NEVER INSTALLED Spridgets Classified 0
D Engine replacement. Rover / Land Rover 0
pairof75's General TR Circulate fluids without engine start Triumph 10
nicko Strange Engine Noise Austin Healey 7
AngliaGT WANTED - Cheap TD Engine/Transmission MG Classifieds 0
tr6nitjulius Oil flow view inside operating engine Other Cars 4
71TR6 TR2/3/3A New engine mounts not sitting flat Triumph 41
B TR4/4A Engine ground strap Triumph 5
T Articles by Hap Waldrop reg engine disassembly and assembly Spridgets 1
6TTR3A Wanted GT6 MK one engine fan Triumph Classifieds 0
J TR6 Engine rotation direction Triumph 2
G Healey 3000 cutaway display engine Austin Healey 12
B TR4/4A Engine tilt Triumph 13
R Distributor: Reassembling BJ8 Engine Austin Healey 5
S MGB MGB engine conversion MG 12
R New Engine mountings BJ8 Austin Healey 1
tahoe healey Engine Stutter Austin Healey 19
D TR6 Disconnecting pipe from engine block to oil pressure gauge Triumph 6
F Spitfire Triumph Spitfire , what fuel to run Her on with no engine history? Triumph 11
N Classic Mini Engine Identification British Motor Corp 2
BJ8Healeys For Sale BJ8 engine for sale Austin Healey Classifieds 0
T For Sale Triumph TR6 N.O.S engine block [late] Triumph Classifieds 2
H T-Series Unknown British[?] Engine MG 3
L TR2/3/3A Stupid Engine cleaning question Triumph 9
L TR2/3/3A Engine removal questions Triumph 8
Y Wanted Looking for running 3.5L MK V engine Jaguar Classifieds 0
AngliaGT MGB FINALLY Got the Engine Out MG 5
M 1972 Midget Engine Issues Spridgets 10
