175cd stromberg carbs
sundown
Having a problem when I start up. The carbs spit /cough when I give it some throttle. Then it runs pretty strong could this be a mixture problem?
Brosky
Re: 175cd stromberg carbs
Is this after warmup, or during with the choke at which position? Fully engaged, 1/2 or not at all?
sundown
sundown
This happens when the choke is half out.What function does the trim screw play? I read keep it fully screwed in or you can fiddle with it to fine tune the idle.
Brosky
Have you read the three part Buckeye Triumph Carb Rebuilding and Tuning files that are available on their site? It takes you through everything, but you can pickup from the resetting page and go forward to make sure yours are all set up properly.
poolboy
I wouldn't waste my time on this. It's very fine adjustment that can only be detected by an CO sensor in the tailpipe.
You'll find the help that Brosky suggested here;
https://www.buckeyetriumphs.org/technical/technical.htm
Check all your adjustments as well as the condition and orientation of the air valve diaphrams.
M Help with Tuning Stromberg 175CD Carbs in Houston Triumph 37
H stromberg carbs....150cd and 175cd...diffrence? Other British Cars 7
Tim Tucker TR4/4A Stromberg 175CD (c.1825) rich above idle Triumph 12
R Stromberg adjustment screw tight 175CD Triumph 10
M zenith stromberg 175cd Triumph 0
T Stromberg 175CD Triumph 35
bmurphy7369 Stromberg Confusion, 175cd vs. 175cd-2 and engine fires... Jaguar 5
Bret Zenith Stromberg 175CD vs. SU HIF44? MG 13
E MGB MGB ZS Carb 175CD MG 4
Zimmycobra TR4/4A Who's right - float height on ZS 175CD? Triumph 5
sundown TR6 175cd strombergs Triumph 4
A Zenith 175CD carbs Triumph 9
S TR4/4A TR4-Stromberg throttle shaft play Triumph 3
Celtic 77 MGB 77 Stromberg issues MG 12
J TR6 Stromberg Carb Mixture Adjustment Triumph 6
V MGB Zenith Stromberg and a Cat on an earlier model car? MG 22
Quackedo TR6 1969 TR6 Stromberg 175 CD-6 Triumph 1
Got_All_4 TR6 Non Adjustable Stromberg Pistons Triumph 8
H TR6 1974 tr6 stromberg 175 cd-2 choke Triumph 2
S TR6 Stromberg Bypass Valves - Question Triumph 11
T TR6 My '74 TR6 Zenith Stromberg Carbs Float Bowls Leaking Gas Triumph 11
T TR6 Carb Vacuum Port- TR6 Zenith-Stromberg Carbs Triumph 4
M General MG stromberg carb MG 5
Sarastro TR4/4A Stromberg linkage question Triumph 4
SherpaPilot TR6 Stromberg War, Finally Success Triumph 2
R TR2/3/3A Stromberg vs. SU carbs [discussion/advice] Triumph 17
D Stromberg Dash Pot Screws Jaguar 3
Merlin63Tr4 TR4/4A Cracked Zenith-Stromberg float assemblies Triumph 13
steveg Online SU and Stromberg needle database with comparison charting Austin Healey 2
R J-H Stromberg carb connections? Where do they go? Other British Cars 2
R GT6 Carb Floats for Stromberg 150 . Triumph 5
bfitz Zenith Stromberg O ring question Other British Cars 8
K TR4/4A Stromberg..."coupler" that links vacuum outlet to diff vacuum line is N/A? Triumph 3
K TR4/4A Stromberg question. Triumph 13
SherpaPilot TR6 Stromberg CD 175 Carb Tuning Triumph 8
M TR4/4A Stromberg CD175carb query Triumph 7
RickB MGB Stromberg on my 80 MGB - fast idle this morning MG 6
RickB MGB HS6 or HIF4 bolt right on in place of Stromberg? MG 6
Zimmycobra TR4/4A Zenith Stromberg questions Triumph 13
M TR4/4A Stromberg ? Triumph 4
L zenith-stromberg carbs Lotus 11
P TR6 Tr6 stromberg carb gas leak from starter valve bolt shaft Triumph 5
G Stromberg cd150 question Spridgets 1
TR6BobNF General Tech Midget Stromberg 150 Adjustment MG 8
Airfix Wedge TR8 Zenith Stromberg carbs slow deceleration Triumph 1
W Weber/stromberg air cleaners Jaguar 3
dklawson Early Stromberg Floats - 150CD Triumph 5
bighealeysource Stromberg carb help needed for TR buddy Triumph 8
W Zenith stromberg carbs Jaguar 3
J stromberg float source or x referance Triumph 2
