The Roadster Factory Recovery Fund - Friends, as you may have heard, The Roadster Factory, a respected British Car Parts business in PA, suffered a total loss in a fire on Christmas Day. Read about it, discuss or ask questions >> HERE. The Triumph Register of America is sponsoring a fund raiser to help TRF get back on their feet. If you can help, vist >> their GoFundMe page.
Hey there Guest! If you enjoy BCF and find our forum a useful resource, if you appreciate not having ads pop up all over the place and you want to ensure we can stay online - Please consider supporting with an "optional" low-cost annual subscription.
I know a couple of you fellas out there have done this. What did you do about the radiator fill tank(brass bottle mounted above the right side shock). anyone have a pick of what they did?
Thanx, look forward to seeing it, I am just looking to see what others have done to mount it. the clearance to the forward bowl is just a little too close.
Seems like someone else had to cut a bit of the wheel arch to accomodate the dual SU's but that might have been SU's off of a Spit. Good luck with your's Mark. Post some picks when you get it finished.
JC
I have only a single carb on mine (S&S 2-1/8") but I moved my radiator fill tank. The new position is just slightly higher, which works fine.
This is a really crappy picture (because I wasn't trying to show the fill tank). The right side of the picture is the front of the car. Towards the left side of the car, you see a circular device (it's the fuel pressure regulator). Directly to the left of that is the fill tank, mounted on the slanted area about the passenger footwell. You can see some of the brass color as the black paint has worn off. I remounted it here so I'd have more room to duct cold air to the carb.
As you can probably guess, the real reason for this picture is to illustrate a last-minute, hack-job repair I did on the car when a carb stud stripped during race practice. I clamped the front part of the carb on with vise-grips (and safety wired the vise-grips in place). Got second place in a one-hour enduro at BeaveRun with this setup!
A friendly reminder - be careful what links you click on here. If a link is posted by someone you don't know, or the URL looks fishy, DON'T CLICK. Spammers sometimes post links that lead to sites that can infect your computer, so be mindful what you click.
(Click X in the upper-right to dismiss this notice)
