Hello All -
I'm trying to set the cam for a Midget 1500 (RB '76) engine. The Haynes book shows
Int opens 18d BTDC closes 58d ABDC
Exh opens 58d BBDC closes 18d ATDC
and
Rocker arm/valve clearance 7 & 8 (for valve timing only) 0.050"
I've got 2 cams that I've stuck in there and dialed out. They both show valves closing significantly earlier than the above specs. Roughly 20 degrees earlier. Total lift is 0.240" and 0.245" (intake & exhaust). I think those lifts are correct but I'm just guessing.
Does anybody know where I can find the cam specs for this engine?
The Triumph Spitfire used the same engine, but I don't know if the cam was the same.
and
