1500 Exhaust
Blueghost
1978 Midget, originally had Cat converter right off exhaust manifold. Several years ago I eliminated that cat (it was totally empty and can shape couldn't be good for flow). P.O. added custom exhaust system many years ago. He used same routing as O.E.M., but added a new Cat just aft of forward pipe, and he eliminated 1st muffler just behind left wheel. Only has muffler behind gas tank. Also he used 1 3/4" OD pipe. This system is at least 10 years and 30,000 miles old, but is in reasonable condition. I would like to get rid of this Cat.
I have a parts car with useable O.E.M. pipe and 2-mufler system. I'd like to install this system, but just found OEM pipes are 1 3/8." Obvious advantage - get rid of Cat; disadvantage - 1 3/8" pipe instead of 1 3/4." I don't have factual information on internal condition of Cat or donor muffler. Any thoughts on which might be best? Thanks, Blueghost.
B
Blueghost
Also, this is not a performance car. But it does OK for a 1500. If there is an affordable better performance system that bolts on aft of the 1st pipe, I'd be highly interested. Moss/Monza looks a little overkill and expensive. Almost always better breathing means better performance, and by good luck, better economy, and sometimes, less emissions. Thanks, Blueghost.
JPSmit
Seems like you have a few options -
1. get rid of the cat in the existing system - replace with straight pipe. Advantage is it is cheap and quick and the larger size already installed. Disadvantage, the rest of the sytem is getting older.
2. Install other system. Advantage is it is all there and convenient, disadvantage is smaller pipe (probably not that big a deal taming those 55 or so screaming horses!)
3. A fresh start. I bought a header for Miss Triss and a Harley take off muffler (remember Ms Triss is now chrome bumpered, so the "side mounted" 1500 bumper was no longer an option.) At any rate, I took it to a muffler shop and had them install a stainless muffler - 2" if I recall, lovely sound, a little more expensive (but not too bad) and it will outlast the car.
Not sure there is a right answer here, time and money and your personal desire for a project seem to be the determining factors.
Jim_Gruber
JP did you install a muffler in addition to the Harley or just the Harley Muffler?
SaxMan
I don't think the 1500 cranks out enough to notice the difference that 3/8ths of an inch in diameter would make. I'd stick with the OEM system with no cat.
From what I recall from hanging out with the "car guys" back in high school and college, a more open exhaust may give you better breathing and more usable horsepower, but you lose some degree of torque in using a more open exhaust. For a small car like the Spridget, I'd take the torque over the horses.
JPSmit
just the Harley. I haven't punched it out like Billy tells me I should, sounds just right, performance is not really an issue with a stock 1500 and for the environment I think it actually has a cat.
B
Blueghost
1st, I agree this motor isn't going to do much no matter what I do. But,I don't want to go backwards.
Believe I will try local muffler shop and get estimate on 1 3/4" pipe, no Cat, and single muffler. If reasonable, I'll have new system, and best flow. Can't do until at least next week end.
SaxMan, your right about torque versus HP. But with the low gear ratio of the 1500, torque is not a problem. And 3/8" difference between the two pipes looks small at first. But, percentage of area difference between 1 3/8" and 1 3/4" is more than I thought at first. 1 3/8" Dia equals area of 1.48 sq in. 1 3/4" Dia equals area of 2.40 sq in. Area of 1 3/8" is only 62% of 1 3/4"; conversely, 1 3/4" is 1.62 times greater than 1 3/8". The big question is, "does any of this matter?"
When I searched this site for info on 1500 exhaust, most comments were about tone and volume. That may be way more important.
I'll let you know how things shake out in a week or so. My guess is there won't be much (if any) change. Thanks, Blueghost.
G
Volume or velocity? Volume effects velocity and that's what you need to worry about. A stock pipe with a punched baffle Harley muffler gives you both good flow and velocity. IIRC my stock pipe is 1 1/2", not 1 3/8 on my '79.
Jamie
I'd go no cat, smaller pipe. I have both a 1.5" and a 1.75" system for my '78. Both are from a 4 into 1 header to straight pipe to muffler by tank. 1.5" is to 1275 latest muffler. The 1.75" is to glass pack type bullet muffler. The 1.75" is too loud but mostly it gives away too much bottom end torque, the 1.5" is much better all around road system. Remember that the carb 'sees' whatever you do beyond the exhaust port. Use a Colortune or check your plug colour to make sure you don't go too lean.
Best mods I ever made to my 1500 from stock:
Remove the front bumper, cut down the stock spring height. Cooler running engine, looks better, weighs 75 pounds less, spring rate is higher.
Gut the cat, remove the air pump, richen up the mixture a turn or two. Way more power.
Replace the cat 'can' with a 4 into 1 header. More power.
Chop about .080" to .100" off the head, clean up the back of the gunky valves, add stem seals. More power again. Not your anemic 1500 any more.
Ditch the 'log' manifold and go to dual 1.25" SUs with manifold. No wait, they're too small for the 1500, go to dual 1.5" SUs from Spitfire 1500. I have both, the 1.5" just aren't on yet.
Remove rear bumper, install chrome one. 50 pounds lighter.
Cut the frame stubs out of the front grille area, install a proper Midget surround and grille.
Lay up a lower rear valance from a Sprite to fill in the missing body metal under rear lights. Have the mold made, just have to make the part.
B
Blueghost
Update from a week ago. I installed the O.E.M. 1 3/8" which eliminated the Cat and went to smaller diameter pipe. Great improvement. Throttle response 1,500 to 5,000 RPM sitting at curb (no load) is VERY fast. I have to be careful not to over-rev. This engine has mild cam and 9.1:1 pistons with Weber.
Actual performance is much improved. Pulls much better from 2,000 through at least 5,000 RPM. Didn't even think about it, but even shifting is noticeably improved, especially down shifting. I am guessing this is because I can more quickly match throttle response with load-unload-load.
Still has the 1,500 Speed limitation for late model 4-speed. Anything above 70 MPH sounds like it wants to blow up. Just more fun getting there.
For all you east coasters, it's been bitter cold here in Oregon - down into the lower 40s. Also had to shovel nearly half inch of rain.
Thanks, Blueghost
recordsj
Blueghost,
I have a similar setup (9:1 compression pistons in a 1500 MG Midget with Weber DGV) and over in the Portland Oregon area like you (down 99W in Dundee, OR).
I have a Harley muffler I installed last summer, did you end up going with the Harley muffler also?
What jets and and such do you have with your Weber carb?
Jason
bigjones 1500 exhaust manifold removal Spridgets 22
dklawson 1500 Intake/Exhaust Gasket - Siamese Ports? Triumph 10
M Monza Exhaust for a 1500. Good Idea? Spridgets 7
c5racer Spitfire 1500 Spit exhaust manifold fit a 1500 midget? Triumph 2
c5racer Fit an exhaust manifold from a 1500 Spitfire? Spridgets 2
B looking for 1500 exhaust manifold Spridgets 5
J midget 1500 exhaust system Spridgets 3
C appropriate exhaust size/muffler choice 1500 Spridgets 13
D 1500 Exhaust manifold and de-smogging Spridgets 3
1 1500 exhaust Spridgets 6
guzzul Spitfire Help! Spitfire 1500 exhaust flange studs broken. Triumph 16
G 79 Midget 1500 overheating Spridgets 2
G General MG Leaking Fuel on twin HS4's 1500 MG Midget MG 5
I Spitfire Triumph Spitfire 1500 refuses to awake after 10 year hibernation Triumph 5
I Spitfire spitfire 1500 refuses to awake after 10 years Triumph 2
M Spitfire 1500 LH Door Triumph Classifieds 0
M 1976 Spitfire 1500 (RHD) Triumph Classifieds 2
B COMPLETE DROP-IN Rebuilt 1975/6 MG Midget 1500 engine PLUS rebuilt Spitfire Overdrive trans NEVER INSTALLED Spridgets Classified 0
R Spitfire Spitfire 1500 Triumph 3
B MGA Solution! 1600 harness in a 1500 MG 1
S For Sale Mg t-series crankshaft tb tc td tf 1250 1500 MG Classifieds 0
R Spitfire 1500 gearbox question Triumph 1
R 1500 gearbox question Spridgets 0
A Spitfire Need help with 1980 Spitfire 1500 Triumph 5
A 76 Midget 1500 Oil filter Spridgets 6
M Wanted Twin carb manifold for 1500 Midget or spitfire Spridgets Classified 3
M Rocker feed kit for 1500 from Victoria British Spridgets 0
G For Sale TR2 TR3 TR3A TR3B Unrestored Hardtop with Window, New Hardware kit and Seals $1500 Triumph Classifieds 2
sparkydave 1500 battery cable colors Spridgets 1
GS67 1500 Operating Temperature Spridgets 2
doc50 Nash Metro w/MGA 1500 discrepancy... Other British Cars 2
doc50 Metro 1500 Has Slack Timing Chain? Other British Cars 20
B 1500 head studs Spridgets 3
DrEntropy For Sale MGA intake manifold [1500] MG Classifieds 0
busybrit For Sale 1960 MGA 1500 Restoration Project for sale. MG Classifieds 2
sparkydave 1500 clutch master Spridgets 4
Steve P. 1500 radiator in an earlier 1275 cross flow Midget? Spridgets 2
P Pristine MG TF 1500 Spotted 0
aseriesspares Spitfire What Gearbox are you using. Spitfire / Midget 1500 Triumph 2
aseriesspares What Gearbox are you using. Midget 1500 Spridgets 5
T Putting a Spitfire 1500 into a 1972 Midget Spridgets 6
AN5Sprite T-Series 1955 TF 1500 For Sale This Spring MG 3
JPSmit 1500 slave cylinder question Spridgets 0
bigjones Vacuum advance on a 1500 Spridgets 13
Rut 1500 gas pedal for sale Spridgets 7
dklawson Spitfire Spitfire 1500 Block Decking Following Boring ??? Triumph 4
dklawson Spitfire Spitfire 1500 - Front Pulley Nut Removal? Triumph 2
DanLewis Two midgets available: '79 is free [no engine, trans], running '77 $1500 [NFI] Spridgets 1
DanLewis 1500 cc MG Midget Radiator in a Bugeye??? Spridgets 5
Editor_Reid T-Series Original Price in US Dollars for an MG TF 1500 MG 4
