Removed my engine in order to check the clutch. Re-installed it and the starter. Turned the key to make sure the starter was working the engine immediately fired up. I immediately shut it off because I remembered I had drained the oil and it had none in it. The engine ran for maybe all of one second. My mechanic tells me probably no harm done.And yet I have a bad vibration at around 1500 rpm.above that the engine is smooth and oil pressure OK.The engine vibrates in neutral and while in gear so its not the drive line.I hear no knocks. But I'm thinking possibly a main bearing. Anybody got any ideas of what this could be ? The motor mounts are tight and OK.
Thanks, Don McQueen
1979 Midget 1500 eng.
Thanks, Don McQueen
