1300 crank
johhny_utah
Hello all,
I am new to this forum and would like to kick off my time here with a question. I am rebuilding a 72 spitfire MkIV and have a question about the crank. Do all of the FK blocks come with a larger crank than the FD and FE series? I ask because my journals are measuring about the same as a 1500 crank. Also the cam has no bearings. it is fitted in the block just like the 1500. Any clarification on this would be greatly appreciated.
Thanks, John.
Don_R
I have a 73 Spit 1500 with a late FK motor.
As I understand it the FK is the big bearing 1300. More like the 1500 motor that the early small bearing 1300.
70herald
FK basically means "big crank"
Now not that I want to cause problems but if you have access to a small crank motor, that is what I would rebuild an put it. They rev up much quicker and a smoother than the big crank motors.
S Spitfire Triumph Spitfire 1300 engine SU carb problem Triumph 10
S Can’t get idle speed below 1300 RPM Austin Healey 28
T Spitfire Help, Lack power on spitfire 1300 engine Triumph 12
G Triumph 1300 head needed Triumph 20
JPSmit 1300 vs 1500 Triumph 11
rikiwho123 i started my 1300 Triumph 0
rikiwho123 starting rebuilt 1300 for 1st time Triumph 7
rikiwho123 rebuilding my 1300 motor Triumph 2
rikiwho123 rebuilding my 1300 Triumph 2
waltesefalcon 1500 head on 1300 Triumph 6
rikiwho123 Spitfire harmonic balancer for a 1300 spitfire? Triumph 2
rikiwho123 Spitfire stuck head bolts 1300 spit. Triumph 7
dklawson Spitfire 1300 Spitfire Compression & Leak Down Results Triumph 15
A Spitfire Spitfire 1300 camshaft dimensions Triumph 7
A 1300 cam bearings in Midget 1500 Spridgets 3
dklawson Spitfire ZS Stromberg vs HS4 SU on 1300 Spitfire? Triumph 11
B TR6 71 block & crank Triumph 1
J Wanted WTB Bell Crank Pivot Triumph Classifieds 2
K TR2/3/3A What is the best way to prevent the crank from turning ........ Triumph 27
Michael Oritt Rear Crank Seal Kit Austin Healey 7
M Wanted Dampener Tr4a crank pulley Triumph Classifieds 9
T MG Midget 1500 crank shaft pulley Spridgets 0
S TR2/3/3A Tightening the crank pulley dog bolt on a tr3 Triumph 7
nichola TR6 Door handle and window crank installation Triumph 0
D TR2/3/3A TR3 throttle linkage bell crank. Triumph 22
R Wanted 3 main crank MG Classifieds 1
Twit early TR4 Crank Handle wanted Triumph Classifieds 0
P TR6 Tight window crank Triumph 9
71TR6 Triumph TR4 Coventry Radiator with crank hole- recently refurbished Triumph Classifieds 0
D TR2/3/3A TR3A Crank Dog Triumph 2
K TR2/3/3A The timing mark on the crank pulley.... Triumph 5
K For Sale Starter Hand Crank Triumph Classifieds 0
jtaylor3 1275 EN40 Crank Spridgets 5
J TR2/3/3A Flywheel-Crank Dowel Alignment Triumph 6
R TR2/3/3A Extension Crank Bolt Attachment Triumph 12
M Wanted TR3 Hand Crank Guide Triumph Classifieds 3
Alfred E. Neuman TR4/4A TR4 fan extension and crank bolt length Triumph 9
D TR2/3/3A Crank handle support Triumph 11
Got_All_4 TR2/3/3A Hand crank misalignment Triumph 9
K For Sale TR3 crank handle Triumph Classifieds 0
M Wanted TR-3 Crank Handle Triumph Classifieds 3
R TR2/3/3A Temperature Gauge for 1954 TR-2 & Hand Crank Triumph 17
Got_All_4 TR2/3/3A TR3 engine hand crank Triumph 14
ckeithjordan Wanted WTB: TR3 Crank Handle Guide Stays Triumph Classifieds 1
D BT7 tri-carb installing my crank Austin Healey 4
R General Tech Crank bearing cap broke...Torque?? Triumph 37
Rut Crank/flywheel dowels Spridgets 3
R TR2/3/3A One more crank pulley question Triumph 7
R TR2/3/3A Crank pulley question Triumph 4
GTP1960 TR2/3/3A Timing cover/crank hub oil seal Question Triumph 4
