1275 Smoking Problem...
Kurtis
Here's an update on my smoking problem.
Recap - Blue smoke at idle and low speed. Disappears at higher throttle.
I ordered a leak down tester, which arrived today. I bought a cheapo unit from Harbor Freight, and leaned once again that you get what you pay for. The thing simply would not calibrate or give anything even remotely resembling consistent results. I'm sending it back tomorrow.
I did go ahead and pressurize each cylinder and listen for air leaks all the same. What I discovered was that all cylinders exhibit leakage through the rings. I assume some leakage would be normal, especially considering I performed all testing with the engine cold.
None of the cylinders exhibited leakage into the coolant (no sound at the radiator cap).
None of the cylinders exhibited leakage through the intake valves.
Cylinder 1 had significant leakage through the exhaust valve (listening at the tail pipe). All other cylinders exhibited no leakage through the exhaust valve.
I made sure each cylinder was at TDC with valves closed for each test.
Could this be my problem? I assume that for oil to actually get in there that it would have to be a problem with the valve guide and or seal, and not a burned valve. Is this correct?
dklawson
Since you found a leaky exhaust valve, I would consider that a red herring relative to the oil burning problem. It needs to be addressed, but it will not be the source of the blue smoke. On the other hand, tired rings will certainly allow for a lot of smoke.
I'm surprised that the HF leak-down tester wasn't any good. I know that a lot of their stuff is junk, but there isn't that much to a leak down tester. They are basically a pressure regulator with a 0.040" orifice in the discharge port and one or two pressure gauges. As for calibrating... how did they tell you to do that? Mine is homemade and all you have to do is set the regulator to deliver 100 PSI when the discharge port is plugged. After that, when you connect it to the spark plug hole, the pressure drop across the 0.040" orifice is "readable" as the percent leakage.
Jim_Gruber
Google Leak Down Tester and you will find info on making a homemade one with a compression gauge and a few fittings.
nomad
Before you tear down for the valve leak I would pull the valve cover, slide the rocker over and tap on the valve stem a few times. May just have carbon sticking in it. My .02.
KA.
Here's the thing about a LD tester either you have the cylinder being tested at TDC compression stroke or the air pressure will rotate the engine, so either you get a reading or see 100% leakage if not on TDC compression stroke.
bgbassplyr
KA.
And/or, with the engine running, squirt some water into the carbs (using a spray bottle). Rev the engine a little so that it won't choke on the h2o. A couple of applications of the water will usually blast the carbon deposits off of the valves and piston tops. There will be steam out of the tail pipe during this operation.
athenssprite
I am dealing with a similar issue. I'll give the water a try if it's a safe recommendation...
Billm
Fill a Coke bottle full and slowly pour it down the carb (one at a time) while trying to keep the revs around 3000 or so, takes a steady hand but works!
BillM
CARSINC WANTED: 1275 Engine Spridgets 0
M 1275 Timing Cover Vent Spridgets 2
drooartz 1275 cruising RPM Spridgets 5
D A distributer question on the 1275 engine. Spridgets 7
abarth69 Innocenti 1275 upgrade path Spridgets 1
D MG Midget 1275 rear oil seal. Spridgets 0
AngliaGT 1275 Engine Value? Spridgets 5
M 1275 Race Clutch Racing 5
drooartz Visual ID of a 1275 Spridgets 14
jehuie SOLVED: Fixing electrics on Morris Minor with 1275 swapped in Spridgets 13
M Need help removing the pinion assembly from a late 1275 steering rack Spridgets 7
jehuie Tuning up a 1275 Spridgets 17
B General MG 1275 Midget CamShaft Slot / Star drive to Oil Pump MG 2
BobHaskell Mini Cooper 1275 engine rebuild British Motor Corp 9
S 1275 oil pan removal Spridgets 30
M 1275 too high? Spridgets 2
R For Sale Fidanza Aluminum Flywheel for 1275 A-Series Spridgets Classified 0
Lin Checking static timing for a 1275 with Crane XR700 ignition Spridgets 0
Lin Fan belt for 1275 with alternator Spridgets 4
B Installing cam bearings 1275, can I do it? Spridgets 1
K 1275 Distributors Spridgets 6
T Dampner for a 1275 [damper? dampener?]: recommendations Spridgets 6
T Rebuilding a 1275 for a BE Spridgets 8
R 948 convert to 1275 info Spridgets 13
G Wanted ISO Gearbox for 69 Sprite, 1275 engine Spridgets Classified 2
Rut Bugeye 1275 temp probe placement. Spridgets 8
jtaylor3 1275 EN40 Crank Spridgets 5
S 1275 Blueprints Spridgets 7
A Bugeye engine swap, 948 to 1275 Austin Healey 11
M Judson Supercharger On A 1275 Spridgets 6
6 Oil pressure, or lack there of on fresh 1275 Spridgets 13
H Is there any difference in using the 1275 Float Bowl that have a different casting? Spridgets 6
Jim_Gruber 1275 Crankcase capacity is? Spridgets 4
N 1275 cams? Spridgets 2
T matching 1275 to bugeye rad ?? Spridgets 12
T Wanted wanted-- 1275 ribcase shifter and shifter seat cover if possible Spridgets Classified 0
6 1275 Head to block dowel pins Spridgets 10
DugMoney Need Advice - Moving Temp Gauge Sensor 1275 Spridgets 3
M Proper running temp for 1275 Spridgets 28
M Wanted 1960 Bug eye sprite 1275 ! Austin Healey Classifieds 0
M Wanted 5 speed tranny for my 1275 bug eye Spridgets Classified 0
doc50 Wanted H2 SU carbs / manifold for 1275 1973 MG MIdget Spridgets Classified 3
Jim_Gruber 1275 Damper Pulley Needed Spridgets 16
T How to add a bit more realiability/endurance to a stock 1275 engine rebuild? Spridgets 9
Gerard 1275 piston ID Spridgets 2
Gerard Wanted: 1275 Crankshaft Spridgets 3
T can't find timing marks on 1275 crankshaft pulley/damper Spridgets 8
Rut How much does a 1275 weigh? Spridgets 8
A For Sale Sprite/Midget 1275 clutch cover. Austin Healey Classifieds 0
