1275 performance books
blkcorvair
Any one have preferences on performance books for the 1275 A series. Wanted to read up on the motor as Ive only worked on the 1500 previously. Suggestions for good reading? I see there are a few out there.
drooartz
"Tuning the A-Series Engine" by David Vizard. The bible on this motor.
dklawson
Forgive me if the following information was also included in Recordsj's links above.
Des Hammill also wrote at least one book on the A-series and a book on performance tuning SU carbs.
Vizard is very good, a bit dated by today's racing standards, but still very good, everyone should hope for a book this good on their engine.
Isn't he teaching a college course somewhere down there in SC or maybe NC?
spritenut
Daniel Stapleton's MG Midget AH Sprite high performance manual.
Just released late 2008, check Amazon.com
Oh yeah, I'm in this book too :wink:
NardisCNC 1st Time Overhaul / Performance questions?? - 1275 Spridgets 17
lbc_newbie Rebuilding 1275 for a little performance... Spridgets 8
M 1275 too high? Spridgets 2
R For Sale Fidanza Aluminum Flywheel for 1275 A-Series Spridgets Classified 0
Lin Checking static timing for a 1275 with Crane XR700 ignition Spridgets 0
Lin Fan belt for 1275 with alternator Spridgets 4
B Installing cam bearings 1275, can I do it? Spridgets 1
K 1275 Distributors Spridgets 6
T Dampner for a 1275 [damper? dampener?]: recommendations Spridgets 6
T Rebuilding a 1275 for a BE Spridgets 8
R 948 convert to 1275 info Spridgets 13
G Wanted ISO Gearbox for 69 Sprite, 1275 engine Spridgets Classified 2
Rut Bugeye 1275 temp probe placement. Spridgets 8
J 1275 EN40 Crank Spridgets 5
S 1275 Blueprints Spridgets 7
A Bugeye engine swap, 948 to 1275 Austin Healey 11
M Judson Supercharger On A 1275 Spridgets 6
6 Oil pressure, or lack there of on fresh 1275 Spridgets 13
H Is there any difference in using the 1275 Float Bowl that have a different casting? Spridgets 6
Jim_Gruber 1275 Crankcase capacity is? Spridgets 4
N 1275 cams? Spridgets 2
T matching 1275 to bugeye rad ?? Spridgets 12
T Wanted wanted-- 1275 ribcase shifter and shifter seat cover if possible Spridgets Classified 0
6 1275 Head to block dowel pins Spridgets 10
DugMoney Need Advice - Moving Temp Gauge Sensor 1275 Spridgets 3
M Proper running temp for 1275 Spridgets 28
M Wanted 1960 Bug eye sprite 1275 ! Austin Healey Classifieds 0
M Wanted 5 speed tranny for my 1275 bug eye Spridgets Classified 0
doc50 Wanted H2 SU carbs / manifold for 1275 1973 MG MIdget Spridgets Classified 3
Jim_Gruber 1275 Damper Pulley Needed Spridgets 16
T How to add a bit more realiability/endurance to a stock 1275 engine rebuild? Spridgets 9
Gerard 1275 piston ID Spridgets 2
Gerard Wanted: 1275 Crankshaft Spridgets 3
T can't find timing marks on 1275 crankshaft pulley/damper Spridgets 8
Rut How much does a 1275 weigh? Spridgets 8
A For Sale Sprite/Midget 1275 clutch cover. Austin Healey Classifieds 0
Rut 1275 rear seal help Spridgets 0
V Wanted rebuildable 1275 engine Spridgets Classified 0
AngliaGT Picking up a 1275 Engine Spridgets 6
pbraun Radiator for Bugeye with 1275 Spridgets 20
Jim_Gruber Thoughts on stock '69 1275 manifold vs LCB Headers for street use Spridgets 9
C Wanted Timing gear cover 1275 Spridgets Classified 2
drooartz ID a 1275 flywheel Spridgets 2
M 1275 Exhaust Manifold Needed Spridgets 6
T 1275 engine oil pressure warning light? oil filter warning light?? Spridgets 4
Rut 1275, 210 5 speed, adapter kit, 3.90 Spridgets 6
M 1275 to 948 Generator Swap - Need Input Please Spridgets 4
jmayzer 1275 Midget Bentley Shop Manual Download Spridgets 1
R 1275 engine with SU HIF single carb Spridgets 9
Steve P. 1500 radiator in an earlier 1275 cross flow Midget? Spridgets 2
