TR2/3/3A Amp Gauge-erratic reading after alternator conversion
R
Redoakboo
I have done a alternator conversion on my 54 TR-2 that I am restoring. I am now getting a erratic reading in the negative side of the gauge. Is there a wiring change I need to make to clear this up?
R
Redoakboo
Can you define “erratic”? I’ve got a similar setup, pos ground, with a shunt. On start up, ammeter reads high for 20-sec or so, while the battery is charging. Then for the first 10-min or so, I’ll see some spiking, irrespective of the load (like my OD). Then it goes away. Not concerned.
I have swapped the two heavy wire leads, including the overdrive relay wire. The gauge now records a positive, steady reading on the plus side.
Thanks guys, for all your help. Now, if I can find the elusive loose wire running the psgr side, rear blinker, everything will be fine.
Today I am installing a new radio. I am putting it under the rear seat, right in the middle. I have four speakers, two in front and two in back. I am going to use a surface mounted antenna behind the rear view mirror.
charleyf
Charley please pour oil on the lifters and cam with the valve cover and any other cam shaft voodoo you know. I want to keep my club very small.
steve
Thanks Steve. The engine has just been rebuilt with almost all new components. Professional friend did the rebuild, used lots of lube. This is the third TR engine he has built with me.
Charley
bammons
I am getting ready to convert my voltage regulator to a "dummy" as Hamish shows above. So I assume that this conversion would be the same for my TR4A correct? There is a comment below that by Steve stating not to connect the "F" wire. I assume he means just tape it? I have searched for Randall Young's post on this and surprisingly cannot find it despite spending considerable time on it. Does anyone have that post or direct me as I recall he had covered it very well. However I can use what is posted above but what is the definitive answer on the F wire? Bruce
R
Redoakboo
Bruce,
I have the original wiring diagram I got when I bought the alternator and Dummy regulator from British Northwest. Send me your email to redoakboo:at:yahoo.com and I will send them to you. Dick
DavidApp
Not a good idea to post an email address in a forum.
This is what I did to my regulator box as per Randall's diagram.
David
Administrator
Boss
Dick, you can go back and delete your address.
Charley
The problem with posting emails in a forum is that "bots" that crawl the interent (like Google does) will see it as an email address and "harvest" it to use in their lists that they spam people with. However, if you look under the smilies icon in the editor you will see I have a "smilie" that is an image of the @ sign. This allows you to post an email address that a human can read, but those spam bots that crawl th net will not see it as an email. So, if you need to post an email, it is higjly recommended you use that "picture" like this: basil:at:britiishcarforum.com << Any human can read that, but a bot will not see this an an email address - much safer if you need to post your email address.
bammons
I do not want to "hijack" this thread but I will go ahead since it is directly related. Basil if you feel it is inappropriate let me know (or anyone else). David - I see you are not using E and F but Hamish is using them. Can someone explain in simple terms (for me) why it is done both ways and is there a advantage to one way over the other. Another dumb question - are the leads that you are soldering to cut or do you just solder to them and that takes care of it? They don't look cut. Is the "coil" assembly simply left in place or removed? Bruce
Hamish Racing
Bruce I have NO electrical knowledge and followed advice from those in the know in the tr register
I did cut the “fixed” metal strips
And my observation was the connections for the thick wires join to each other and the same for the thin wire connections.
I also removed the innards ( use it to keep spares like a plug. Fuses and spare electronic ign unit.)
Sarastro
I suggested disconnecting the F (field) wire because it can be "hot" with the generator/alternator output voltage. If the other end is not connected to anything and is well taped, it won't matter. But on general principles, I'd keep it unpowered. I would also disconnect the E terminal, so it is no longer connected to the chassis. If you don't, the cutout and regulator relays will still be powered. Probably won't hurt anything, but they still will suck up current unnecessarily.
Or, just gut the innards of the regulator, so nothing inside is connected to any of the terminals.
bammons
Dick sent me this instruction which came with the Dyno-Alt (which I have misplaced somewhere). I am not knowledgeble but this seems different from what I am seeing above. F is disconnected as above but E has a lead coming off of it. Since the instructions do not call for any internal "shunts" or disconnects I am not sure how this translates to the above methods. I don't see me going back to a generator but I suppose this method is more reversible. I am fairly confused now. Bruce
DavidApp
I am only using the control box as a connection point in the wiring from the Alternator to the ammeter. It makes it look to the casual observer like it is still being used.
I believe that is the mod Randall posted.
David
Graham H
If you are using an alternator with a built-in regulator the original control box is only there for show and a convenient connector for the charge light, amp meter, and battery charging connections, so the internals are now obsolete.
bammons
I get that it's function is not needed anymore. I do want the box mounted for looks. Obviously all the above work. So I will just pick one. The great Randall was never wrong so I will use the picture that David posted of his recommendation above to do the modification. Bruce
Sarastro
Actually, I think that the picture in Bammons' post should be OK. As long as the D and F are not connected, you should be OK. Or, you could bridge the A and A1 as in David's picture, but I would not connect it to the D terminal. That would prevent powering the existing regulator's coils.
bammons
David - Thanks for the drawing. For someone like me this helps. My altenator is only 40 amp and I am using a high torque starter as well so this is the way I need to do it as well. Bruce
DavidApp
Hello Bruce
Notice I wired my High Torque starter so that the original solenoid acts as the switch for the starter. This way I can use the button on the solenoid when I am working on the engine.
David
S TR2/3/3A NW or the N side of the amp gauge for the OD? Triumph 4
K For Sale TR3 Amp Gauge Triumph Classifieds 0
Tr3aguy TR4/4A Amp Gauge TR3 vs TR4 Triumph 4
hondo402000 TR6 TR6 Wiring/amp gauge question Triumph 8
Webb TR6 TR6; Amp Gauge Not Reading Positive Triumph 7
C TR2/3/3A TR3 Amp Gauge to Volt Meter Triumph 8
D TR2/3/3A TR3 AMP Gauge Triumph 1
B TR4/4A In-Line fuse 25 or 35 Amp? Triumph 21
S TR2/3/3A amp meter Triumph 3
K TR2/3/3A Is a 25 AGC fuse equivalent to an original 30 amp fuse? Triumph 10
N TR5/TR250 amp gage shows discharge when lights are on Triumph 39
K TR2/3/3A 30 AMP Fuses Triumph 2
C TR6 30 amp to 60 amp ammeter conversion Triumph 2
TomMull induction amp meter Restoration & Tools 3
Kirk_Fisher TR4/4A Need oil pressure and amp guages Triumph 8
B TR6 Does a 75 amp alternator require a wiring upgrade of any kind? Triumph 3
rjc157 amp meter Austin Healey 4
S TR2/3/3A Another Amp Meter & Regulator Question - TR3A Triumph 19
V Fuse amp ratings MK III Spridgets 1
hondo402000 TR6 TR6 Amp Meter question Electrical guru needed Triumph 4
hymodyne 63 amp 7127 GM Delco alternator Triumph 1
tahoe healey amp meter Austin Healey 35
D TR2/3/3A TR-3 Amp Meter Triumph 17
sail Amp Meter Triumph 4
Brosky TR6 Up-date to Bolt On 72 amp Alternator for TR6 Triumph 35
PAUL161 Volt Gage Verses Amp Gage. MG 15
vping Amp Guage Questions MG 13
roofman Flippin out Amp guage Triumph 10
AUSMHLY volt meter vs amp meter Austin Healey 21
Lin Amp, MP3 player and speakers of choice? Austin Healey 28
J TR4/4A Amp to Volt meter wiring question TR4 Triumph 7
Got_All_4 HELP ON BOSCH 55 AMP ALTERNATOR CONVERSION Triumph 1
wkilleffer Series III XJ6 a/c amp questions Jaguar 1
O 110-amp Bosch Alternator Upgrade MG 47
J For Sale Gauge brackets (lot of 7) for sale Other British Classifieds 0
Rick_Thompson TR2/3/3A Overheat issue, gauge adjustment Triumph 9
G MGB ugh.....the fuel gauge went to *** again! MG 8
RJS TR4/4A Smiths Oil Temp Gauge Triumph 11
J MGB Oil Pressure Gauge Gives Constant Reading -- Doesn't Seem Right MG 15
roscoe Fuel Gauge Austin Healey 0
G Smith's temp gauge repair Restoration & Tools 4
CARSINC eBay Gauge Packages Spridgets 6
Gliderman8 TR6 Excessive reading on volt gauge Triumph 17
K TR2/3/3A Wiring a voltmeter gauge to replace the ammeter. Triumph 1
Gatheringtree TR2/3/3A Gauge Set Triumph 17
jfarris For Sale TR4 Fuel Gauge with 2 Transmitters Triumph Classifieds 0
D Fuel Gauge Austin Healey 7
BoyRacer Thread Pitch Gauge from "British Tool and Fasteners" Austin Healey 0
LD-Ordie TR2/3/3A TR3 gauge service Triumph 11
RJS General TR Oil Pressure Gauge - Test Triumph 11
