T-Series 5 Speed Transmission
PAUL161
PAUL161
Found the Phidiles nuts and are on order.
Here I'm getting ready to pull the transmission, I need it out to repair the Aluminum sump threads. Had to make a temp floor to rest it on after pulling it out. I need a wide floor base as the heater is in the way of the bell housing and need to turn the tranny hopefully to get it to pass. I don't want to pull the heater out!! Will show progress, if there is any!?!? PJ
PAUL161
PAUL161
Ran into a problem, the transmission spline is stuck in the clutch disc! Soaked in Kroll last night and today I believe I'll get it out, we'll see.
Platinum
Paul, if the Kroil fails, try using the Weasel Pee. ATF seems to "creep" into corrosion better than all else.
PAUL161
PAUL161
I was going to do that Doc, but I decided to pull the unit with the pressure plate and disc attached. Working through the inspection hole with an 18" 3/8 extension and a short socket was a little much, but it worked. Transmission is out. Found out it wasn't rusted, it was a return spring on the pressure plate that broke, fell down, and jammed between the spline and plate. Borg & Beck pressure plate also! Here are a couple of pics. Kinda tough taking everything out through the top under the dash laying half on your stomach and being careful not to touch any painted surfaces! I do not want to do this job again, if needed I'll sell the car! :devilgrin: PJ
Platinum
HA!!
Well done.
..I won't go into too much detail about the body contortions, but understand: At some point I may elaborate about having been "trapped" by the steering wheel in an E-Type, under the dash, upside-down and experiencing butt-cramp trying to get back out... :ROFLMAO:
PAUL161
PAUL161
HA!! Well done. ..I won't go into too much detail about the body contortions, but understand: At some point I may elaborate about having been "trapped" by the steering wheel in an E-Type, under the dash, upside-down and experiencing butt-cramp trying to get back out... :ROFLMAO:
PAUL161
PAUL161
Well, Gary Krukoski in Minnesota is sending me a good pressure plate! (y)
PAUL161
PAUL161
Pulled the clutch shaft to transfer to the new bell housing, new 3/4 inch forks are NA! Seems to be what most guys do. The parts came out in like new condition. At least something is in my favor!
BUT, an email from High Gear yesterday told me my transmission won't be delivered to me until the end of February! Seems like the manufacture of the shafts just got a delivery of supplies and said they have 600 orders to fill, High Gears order of 75 won't be filled for two months! :rolleyes2: Nice huh!
PAUL161
PAUL161
Got this in the mail yesterday from Gary Krukoski, wow!! Other than a few shelf scratches, it looks like a NOS part! PJ
Not quite NOS, :thumbsup2: but looks like very little use. (y)
PAUL161
PAUL161
Just received info. my transmission will be sent out in 2 to 3 weeks. High Gear just got a supply of modified drive shafts. (y)
PAUL161
PAUL161
Just shipped this morning 1/25 with Fedex from the UK. (y)
PAUL161
PAUL161
Customs is holding up my transmission shipment in Memphis Tenn! After months of waiting, customs has thrown a wrench in its delivery! Two phone calls, many emails, and no word back from them! What else is new!! Disgusted, :unsure: :censored1:
Mickey Richaud
Nature of the beast these days. Hang in there!
Jerry
One other advantage of a new transmission is the heat released from the unit is much lower with a new transmission. The original transmission would get very hot and that heat came up the shifter. Does not happen with a modern transmission.
PAUL161
PAUL161
Well, after 4+ months of waiting, all I want is to get this thing back together. Sure has been a
Royal Pain in the :censored1: !!
PAUL161
PAUL161
UK FedEx is taking control of the situation! They actually emailed me and said they are sending all the needed documents to customs and not to worry. They will keep me advised. FedEx here seems like they have no idea what they are doing with customer relations and appear to drag their feet by not taking the bull by the horns and doing something about it. :rolleyes2:
Platinum
Had too many weird, unhappy experiences with FedEx recently.
I've noted before: FedEx couldn't find their a$$, even if they used both hands.
PAUL161
PAUL161
I spoke with a FedEx employee and he told me that they are so filled up with outgoing deliveries that the place is in a state of total confusion! Seems like their hiring qualifications in that department doesn't require any intelligence! :rolleyes2:
PAUL161
PAUL161
I just received a list of direct connections to US Customs, phone numbers, Fax numbers, some US Gov sites, and a FedEx customs page. Monday I'm going to call some and hopefully find someone I can talk to. Actually, it's the first time I have fax numbers to send paperwork to them. FedEx UK said they sent the 5 forms to customs here, :rolleyes2: , but I don't know who to believe anymore! Frustrating for sure!
All of this stems from a 2-liter container of oil! It's classified as a hazardous material! If they sent it in a separate shipment, none of these problems would have occurred! Royal PITA! (y)
Jim_Gruber Correct Transmission Oil for Datsun 210 5-speed Spridgets 1
K Putting a Getrag 5 speed OD transmission in a Jaguar Mkll ? Jaguar 4
WHT Tremec T-5 Five-Speed Transmission Austin Healey 39
Cappy Toyota 5 Speed transmission Austin Healey 4
Tullamore BN1 3 Speed Transmission Third Motion Shaft Disassembly Austin Healey 3
M FOR SALE: 280i 2.8 v6 engine and 4 speed transmission for sale TVR 2
PAUL161 Datsun 5 speed transmission MG 10
jhorton3 Rebuild 5-Speed Datsun Transmission Spridgets 19
RickB Saw my new 5 speed transmission today Spridgets 4
B How to identify a Datsun 210 5-speed transmission Spridgets 1
T 4 Speed Transmission in a BN-1 Austin Healey 0
M Datsun 210 transmission 5 speed shift lever Austin Healey 4
A New!!! Gear Shift Knobs for 5 Speed Transmission Triumph 1
AngliaGT 5 Speed Datsun Transmission Spridgets 8
1 5 speed Datsun transmission... Spridgets 34
AngliaGT Rover/Triumph LT77 5 Speed Transmission Triumph 5
Bruce_B %#@#%@ 5 speed transmission - rear mount!!--Help Spridgets 11
gubba TR2/3/3A TR3 B 5 speed Transmission conversion Triumph 0
Louie Mk 2 Auto transmission speed hold Jaguar 2
N 4-speed transmission--popping out of 4th gear Sunbeam (Rootes) 1
PAUL161 Jag 5 speed? Jaguar 3
T Datsun 5 speed potentially available from wrecker: Spridgets 0
Bayless What oil for Datsun 5 speed? Spridgets 7
L General MG Five speed MG 6
D Wanted WTB - clutch fork and shifter from Datsun 5 speed #60 Spridgets Classified 0
G 5-Speed Conversions Austin Healey 15
J TR2/3/3A TR3 Soft top speed limit? Triumph 9
Michael Oritt Pilot Bearing Adapter for Smitty's 5-Speed Kit Austin Healey 3
T Rut's 4 speed shifter modification - anyone have knowledge? Spridgets 3
Popeye Wanted WTB: two speed wiper motor TR4A / 75568 - Found Triumph Classifieds 2
shadowfever Datsun 5-speed info neede Spridgets 5
Michael Oritt Smitty's Five-Speed Manual Austin Healey 1
S TR2/3/3A Moss Motors Vitesse 5 Speed Conversion Kit Installation Issues Triumph 13
PAUL161 T-Series 5 Speed Road Test MG 25
Michael Oritt Difficult-Shifting Toyota Five-Speed Austin Healey 17
crispy Idle Speed Variation Austin Healey 19
Cappy Toyota 5-Speed Austin Healey 3
T Wedge TR7 4 speed wheel cylinders on 5 speed (locating pin) Triumph 0
G TR4/4A "Engine seized after engaging overdrive at low speed. Triumph 26
T maybe a Datsun 210 5 speed available in Oakland? Spridgets 2
B 1966 TR4A two speed wiper motor Triumph Classifieds 1
I GT6 A type OD vs D type - engagement speed? Triumph 3
HealeyRick Toyota 5 Speed - Truck or Supra? Austin Healey 16
Michael Oritt Toyota 5-speed shifter bushing Austin Healey 7
roscoe 5 speed conversion question Austin Healey 9
Lin Toyota 5-speed bell housing drain hole Austin Healey 14
S For Sale 3000 BJ8 Laycock 4 speed with 22% OD trans & 2 6 cyln engines / long blocks / BUNDLE Austin Healey Classifieds 1
roscoe Caving In [5-speed conversion for BN2] Austin Healey 29
HealeyPassion Aftermarket heater/defroster with 3 speed fan Austin Healey 15
