Steering Wheel Repair
BigGreen
Bitchun Bob
Anyone have a picture of a wheel, or parts of a wheel, with no plastic on it?
With old solid axle Corvettes the cracks usually mean that the underlying weld has broken, and needs to be repaired if the plastic repair is going to hold.
I'm just wondering if the Healey wheels have welds, or how the spokes are held to the outer ring. Will these suffice. Looks like there spot welded to ring.
Bitchun Bob
When I have repaired steering wheel cracks in the past I've used Tiger Hair. It's chopped fiberglass blended in a resin and you add a few drops of hardener to the amount you need for the job. When repairing cracks in your wheel you first need to grind it out a little and taper it in to the bottom of the crack. the wider the taper the better. Then fill and sand after hardening. Apply more if needed till satisfied with smoothness and look. Any two stage epoxy with fiberglass strands will work. By tapering and feathering in your fiberglass filler it should never crack again. Paint with a two stage epoxy paint. To eliminate cracking; avoid direct sunlight and extreme heat. Cold temps have no adverse effects, unless you smack it with a hammer or such. Also avoid using your steering wheel to keep you from going thru the windshield when you slam on the brakes at stop lights, animals crossing the road, or pretty girls standing on the corner, etc. etc.
PHulst
Bronze
Thanks for the photos. Definitely places where there is flex that can lead to cracking.
In Corvettes, my restorer friend finds that today's "larger owners" use the steering wheel as an assist to get in and out, flexing the wheel and causing cracks. That doesn't help.
Bitchun Bob
I can believe that. When they produce the steering wheel. They need to reinforce the plastic with fibers of some sort or make the thing using carbon fibers. The wheel could flex all it wants then and not crack. It's like pouring a slab of concrete and leaving out the wire mesh or adequate rebar. That's also the problem with JB Weld. There's nothing in it too reinforce it. The reason wooden wheels don't crack. Mother nature put fibrous strains in them.
Editor_Reid
Platinum
Several years ago I saw a Nash Healey at the Scottsdale Barrett-Jackson auction with the steering wheel rim broken off completely and lying on the passenger seat. My hunch is that their contract driver was a large fellow who wrenched on the relatively delicate steering wheel getting out and ... CRACK.
You can torque most American car steering wheels that way and it's no problem. Not so with the steering wheels of old European cars.
LarryK
Lots of wheel restoration guides on youtube. One guy actually makes a mold, inserts the metal and fills in one pour.
D Steering Wheel Repair Austin Healey 2
T TR2/3/3A Seeking advice on how to repair TR3 steering wheel broken spoke. Triumph 8
2 TR2/3/3A PC-7 for steering wheel repair Triumph 12
pkmh HBJ8 Steering Wheel Repair Experiment - VERY GOOD. Austin Healey 7
M TR2/3/3A TR3 Steering Wheel Repair Triumph 5
I Repair to bakelite steering wheel BJ8 Austin Healey 5
TR3driver Miata/MX5 Steering wheel repair Other Cars 7
N Steering Wheel Repair. See Photo Spridgets 4
DonPete3 Steering Wheel Repair Spridgets 3
T TR6 Steering Wheel Lock Triumph 2
D Removing the steering wheel hub Spridgets 12
K 1968 Midget Steering wheel Spridgets 1
Editor_Reid Wrapped Steering Wheel Austin Healey 9
B TR4/4A Steering Wheel Hub Issues Triumph 0
K TR2/3/3A Who sells steering wheel control head "Allen head'' grub screws? Triumph 5
EWD For Sale ‘74 TR6 original steering wheel Triumph Classifieds 0
S SOLD!! Mike Lempert 15" slotted Derrington Steering Wheel Austin Healey Classifieds 1
kodpkd Leather Steering Wheel Cover Austin Healey 3
S Steering Wheel Brand Austin Healey 5
B TR4/4A What is this Steering Wheel Center? Triumph 6
Martinld123 Steering Wheel Alignment [Lost centering on steering box 1956 Austin Healey, BN2] Austin Healey 14
Celtic 77 MGB Steering wheel fitment MG 11
S TR2/3/3A Steering wheel removal. Triumph 4
LAW75 Derrington Steering Wheel Austin Healey 19
waltesefalcon New steering wheel Other Cars 2
R TR2/3/3A Steering Wheel hitting my belly Triumph 22
bighealeysource T-Series My older Brooklands steering wheel is leaking ! MG 4
A Austin A40 trafficator steering wheel Other British Cars 5
T Steering Wheel Adjustment Range Austin Healey 0
R TR2/3/3A Steering wheel hub removal Triumph 11
K TR2/3/3A Question about installing the steering wheel control head? Triumph 1
J Wanted Adjustable steering wheel circlip Triumph Classifieds 4
E Wanted wanted Austin healey 3000 adjustable steering wheel & dash pad Austin Healey Classifieds 2
Cappy Moto-Lita Steering Wheel Installation Austin Healey 3
K TR2/3/3A Steering Wheel hold down Nut Triumph 6
Walter74 Adjustable steering wheel removal Austin Healey 4
D TR2/3/3A Shaking in steering wheel above 50 mph. Triumph 19
G Steering wheel offset Austin Healey 10
K For Sale TR3A Steering wheel Triumph Classifieds 4
K TR2/3/3A Non Adjustable TR3 Steering Wheel Triumph 7
Exotexs For Sale 1968 MG-B steering wheel and handbooks MG Classifieds 0
K TR2/3/3A Steering wheel Lock Nut? Triumph 2
R TR2/3/3A Frozen Steering Wheel [Adjustable] Triumph 7
S Steering Wheel Side to Side Movement Question Austin Healey 6
Ripper01 SOLD-TR6 Steering Wheel for sale Triumph Classifieds 2
K TR2/3/3A Making your own steering wheel stator tube? Triumph 16
BoyRacer Steering Wheel Location with non-adjusable column Austin Healey 6
Zitch For Sale Les Leston Wood Steering wheel with Triumph hub and boss Triumph Classifieds 0
BoyRacer Wanted Steering Wheel Hub Adaptor for non adjustable column Austin Healey Classifieds 1
Gliderman8 TR6 Corona boredom relief - Steering Wheel Bushings Triumph 6
