Results 1 to 10 of 10
Thread: Girling Brake Help needed (I hope)
  1. #1
    Great Pumpkin JPSmit's Avatar
    Join Date
    Nov 2004
    Location
    Toronto, ON
    Posts
    18,978
    Thanks Thanks Given
    Thanks Thanks Received
    72
    Thanked in
    Friends, I just found out that the brakes on my Vauxhall Viva are Girling and, at least the rears, the same as a Spitfire.
    When I got the car, it was essentially missing the brake lines completely. So, I have to re-create the lines. Unfortunately, the information on the interweb is really really confusing. So, here is what I do know - can someone help? thanks! (reposted from another site - so the syntax is off)
    specifically, what is the "Girling Bubble" is this the same as anything else? thoughts
    so, quick update - I got the cylinders off, only destroyed one clip, adjusters are clean and ready to go, just waiting on new clips and a few other bits and bobs. In the meantime, time to learn about brakes.
    I just learned (see other thread) that the car came with a hard line on the axle connecting the rear cylinders - thanks for that. Basically, the car had no brake lines at all when it came so, I am essentially starting from scratch! This is also new territory so, please forgive my ignorance.
    In the boxes of bits and bobs, this was found - a new pre made line shown here next to an old one (please forgive the focus)
    close up the label says:
    it does connect to the old line:
    but the ends seem different:
    are they different? or slightly different versions of the same? It looks like 3/16" double flared - is this correct?
    Thanks for any help, and, if this is the time to switch to an easier profile, please remember I essentially have nothing now except the Master Cylinder and Slave cylinders.
    as always, thanks for your help,
    JP
    John-Peter Smit
    1976 MG Midget
    1969 Vauxhall Viva GT
    1958 Fiat Multipla (Barn art)
  2. #2
    Great Pumpkin NutmegCT's Avatar
    Join Date
    Jul 2004
    Location
    Connecticut USA
    Posts
    11,722
    Blog Entries
    1
    Thanks Thanks Given
    101
    128
    Thanked in
    Re: Girling Brake Help needed (I hope)
    J-P - the two ends are different. Note the different flare shape and taper angles:
    Mac & Phyllis Take a Trip: http://nutmegflyer.com/trip-details-daily-updates/
    History: 1976 MGB, 1959 Triumph TR3A, 1960 Mercedes-Benz 190b, 1958 Rambler American.
    Current: 1953 MG TD27318.
  3. #3
    Moderator Andrew Mace's Avatar
    Join Date
    Sep 2002
    Location
    East Nassau, NY (nr. Albany)
    Posts
    6,200
    Thanks Thanks Given
    107
    6
    Thanked in
    Perhaps it would be best and easiest to simply buy a kit? One example (although the listing says Lockheed?) here on eBay, but I'm sure you could contact Automec directly. https://www.ebay.com/itm/Automec-Copper-Brake-Pipe-Set-Kit-Vauxhall-Viva-HB-66-70-Drum-Lockheed-/120803997182
    -- Andrew (Andy) Mace, VTR's Triumph 10/Herald/Sports 6 vehicle consultant and keeper of the North American Triumph Sports 6 and Herald Database
  4. #4
    Join Date
    Nov 2004
    Location
    Toronto, ON
    Posts
    18,978
    Thanks Thanks Given
    72
    Thanked in
    Quote Originally Posted by Andrew Mace View Post
    I certainly could - however, it is $220.00 to get it here - which is pretty spendy compared to making them plus, I'd like to develop the skill.
    John-Peter Smit
    1976 MG Midget
  5. #5
    Join Date
    May 2010
    Location
    Perkasie, PA
    Posts
    84
    Thanks Thanks Given
    Thanked in
    Here is a good NA supplier with lots of info....
    https://www.fedhillusa.com/
  6. #6
    Join Date
    Jul 2004
    Location
    Connecticut USA
    Posts
    11,722
    Blog Entries
    1
    Thanks Thanks Given
    101
    128
    Thanked in
    J-P - weren't you originally asking about the different flare shapes?
    Tom
  7. #7
    Join Date
    Sep 2002
    Location
    Posts
    6,200
    Thanks Thanks Given
    107
    6
    Thanked in
    Quote Originally Posted by JPSmit View Post
    Skill is fine. My thoughts are that your time is worth something, as is your ultimate safety and peace of mind. These kits come with proper fittings and flares, and the lines are all exactly the length they should be. You bend, fit, tighten and drive away.
    Cheers!
  8. #8
    Join Date
    Apr 2013
    Location
    redding,ca
    Posts
    1,067
    Thanks Thanks Given
    1
    11
    Thanked in
    Andy,
    I just looked up the brake line sets and saw that they are copper lines. My concern is the copper . I know that our lines were originally steel and now there is a copper nickel that is stronger than just copper but bends more like the copper. So is having steel an overkill and copper will be just as safe?
    Charley
  9. #9
    Join Date
    Nov 2009
    Location
    Steamboat Springs,Co.
    Posts
    232
    Thanks Thanks Given
    Thanked in
    When I rebuilt my 4A I went with the copper brake and fuel line sets offered.
    They were easier to bend into shape & had a great finish to them.
    Harry
  10. #10
    Join Date
    Sep 2002
    Location
    Posts
    6,200
    Thanks Thanks Given
    107
    6
    Thanked in
    Quote Originally Posted by charleyf View Post
    Andy,
    Charley
    "Pure" copper is actually frowned upon by many and even banned in some jurisdictions. But I'm pretty sure this and other companies offer "Kunifer" or Copper/Nickel lines as well, and those are pretty much universally accepted.
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
