Results 1 to 8 of 8
Thread: Speedometer Question
  1. #1
    Join Date
    Aug 2005
    Location
    Delaware
    Posts
    124
    Thanks Thanks Given
    Thanks Thanks Received
    Thanked in
    I have read that you can check if your speedometer is working by attaching a drill to the speedometer cable. Someone told me you have to run the drill in reverse?
    Before I do this I wanted to check if anybody has done this and is there any harm that can be done to the speedometer or cable.
    Is there anything else I need to know before I trash a perfectly good speedo.
    Thank you in advance.
  2. #2
    Join Date
    Apr 2013
    Location
    Brussels, Belgium
    Posts
    141
    Thanks Thanks Given
    Thanked in
    Re: Speedometer Question
    Yes you can... I suggest that you give it a good covering of WD40 and turn it by hand before attaching the drill. I assume that you want to test for accuracy ? If so, there are far more qualified members on this forum that can give you guidance on calibration..
  3. #3
    Jedi Knight bighealeysource's Avatar
    Join Date
    Sep 2006
    Location
    Beaufort, SC
    Posts
    1,425
    Thanks Thanks Given
    Thanked in
    Hey TodE,
    If you're just wanting to check the accuracy of it, download one the free "speedometer" apps to your smart phone that have the built in GPS. Thought mine was off but after comparing it to the app speeds via GPS, found it was almost spot on.
    Regards
    Mike
    Mike Lewis, 1956 Austin Healey 100M - Registry Confirmed
  4. #4
    Join Date
    Feb 2007
    Location
    California USA
    Posts
    3,926
    Thanks Thanks Given
    5
    47
    Thanked in
    If you have an old speedometer cable cut it off at about 12", chuck the cut end in your drill and use it to drive the speedo. Twirl the cable with your fingers first to make sure the speedo isn't frozen. It should spin in either direction--CC or CCW--but the needle will only respond in one (think it's reverse, but not sure).
  5. #5
    Obi Wan Johnny's Avatar
    Join Date
    Dec 2001
    Location
    St Louis, Missouri, USA
    Posts
    2,065
    Thanks Thanks Given
    Thanked in
    You haven't said if yours is working or not? What's the problem?
    By just observing the speedo you can learn a lot.
  6. #6
    Obi Wan Patrick67BJ8's Avatar
    Join Date
    May 2007
    Location
    Holly Lake Ranch, (East) Texas
    Posts
    2,292
    Thanks Thanks Given
    76
    5
    Thanked in
    The drill speed will normally run faster then the speedo cable does from the trans so be careful.
    Patrick
    '67 Metallic Golden Beige/Red
    Owned since '72
  7. #7
    Join Date
    Aug 2005
    Location
    Delaware
    Posts
    124
    Thanks Thanks Given
    Thanked in
    Johnny, Yes I just want to see if it is working. I had the speedo in the car, with the car on jack stands, I started the car put it in gear and slowly depressed the pedal. The cable in the angle drive broke. (I later found out you need the copper washer on the angle drive on the transmission side.) I thought the speedo was froze, but now I am not sure. This speedo did not come out of this car, it was a used one I bought.
    Does anybody know if Nisonger rebuilds angle drives? If so does anybody know the cost?
  8. #8
    Join Date
    Feb 2007
    Location
    California USA
    Posts
    3,926
    Thanks Thanks Given
    5
    47
    Thanked in
    At $43.50 from Moss, it's not worth rebuilding. We rebuilt a BN2 drive from a couple donors, but those are a couple hundred bucks.
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
