Speedometer Question
TodE
I have read that you can check if your speedometer is working by attaching a drill to the speedometer cable. Someone told me you have to run the drill in reverse?
Before I do this I wanted to check if anybody has done this and is there any harm that can be done to the speedometer or cable.
Is there anything else I need to know before I trash a perfectly good speedo.
Thank you in advance.
andrewss
Yes you can... I suggest that you give it a good covering of WD40 and turn it by hand before attaching the drill. I assume that you want to test for accuracy ? If so, there are far more qualified members on this forum that can give you guidance on calibration..
bighealeysource
Bronze
Hey TodE,
If you're just wanting to check the accuracy of it, download one the free "speedometer" apps to your smart phone that have the built in GPS. Thought mine was off but after comparing it to the app speeds via GPS, found it was almost spot on.
Regards
Mike
If you have an old speedometer cable cut it off at about 12", chuck the cut end in your drill and use it to drive the speedo. Twirl the cable with your fingers first to make sure the speedo isn't frozen. It should spin in either direction--CC or CCW--but the needle will only respond in one (think it's reverse, but not sure).
Johnny
You haven't said if yours is working or not? What's the problem?
By just observing the speedo you can learn a lot.
Patrick67BJ8
The drill speed will normally run faster then the speedo cable does from the trans so be careful.
T
TodE
Johnny, Yes I just want to see if it is working. I had the speedo in the car, with the car on jack stands, I started the car put it in gear and slowly depressed the pedal. The cable in the angle drive broke. (I later found out you need the copper washer on the angle drive on the transmission side.) I thought the speedo was froze, but now I am not sure. This speedo did not come out of this car, it was a used one I bought.
Does anybody know if Nisonger rebuilds angle drives? If so does anybody know the cost?
At $43.50 from Moss, it's not worth rebuilding. We rebuilt a BN2 drive from a couple donors, but those are a couple hundred bucks.
J MGB 78 MGB question about the speedometer MG 6
Ohiobugeye Speedometer Question Spridgets 11
G Another speedoMETER question MG 4
Tinkerman Jaeger Speedometer Part Question Triumph 4
bcbug Another speedometer cable replacement question Spridgets 4
JPSmit speedometer cable question Spridgets 8
TR4 Jaeger Speedometer Question Triumph 5
H Speedometer Question Austin Healey 2
T How fast am I gong? A Speedometer question.... Spridgets 27
D Speedometer Question Triumph 2
Paulus Speedometer drive housing question. Triumph 0
dklawson Electronic Speedometer Question Jaguar 4
B Speedometer Cable Routing Question Austin Healey 3
M TR2/3/3A HVDA Speedometer Drive Triumph 10
GeorgetheTR3 TR2/3/3A Speedometer Triumph 4
jfarris For Sale TR3 Speedometer SOLD Triumph Classifieds 3
roscoe GPS Speedometer Austin Healey 6
J 1985 TVR 280i Speedometer Cable TVR 4
F TR4/4A Speedometer cable replacement access Triumph 0
DocDup1 MGB SpeedBox Speedometer Drive MG 0
R TR2/3/3A Speedometer Reset Triumph 26
BritBite Speedometer Right Angle Drive Austin Healey 5
roscoe GPS Speedometer Austin Healey 10
PAUL161 T-Series TD/TF speedometer gears. MG 3
AUSMHLY Speedometer Fluctuation Austin Healey 21
Magyar Rebuild Speedometer & Tachometer - mechanical or electronic? Spridgets 17
M TR6 Speedometer Triumph 2
S For Sale Early Sprite & Midget Speedometer/Tachometer/Generator etc. Spridgets Classified 2
P TR6 Jumpy Speedometer cable Triumph 4
PAUL161 T-Series Interesting Speedometer Scenario MG 5
John Turney Getting Speedometer out of the Case Austin Healey 6
K TR2/3/3A Speedometer needle bounce? Triumph 1
P Speedometer confusion Spridgets 1
J TR2/3/3A Speedometer Bounce with Odometer Gear Movement - Benchtop Calibration Triumph 3
RJS TR4/4A Speedometer and Angle Drive Triumph 6
T Speedometer Repair Problem Austin Healey 5
J TR2/3/3A Speedometer Works Removal Triumph 10
R TR2/3/3A Speedometer Routing Triumph 15
KVH General Tech Speedometer Not Working Triumph 5
AUSMHLY 1962 3000 Mk II BT7 speedometer Austin Healey 2
K TR2/3/3A Speedometer Error Again Triumph 8
G Spitfire gps speedometer Triumph 6
J Speedometer Tach Correlation 1965 Austin Healey BJ8 Austin Healey 3
B For Sale MGA JAeger Fuel Gauge, Dual Safety Gauge, Speedometer and Tachometer MG Classifieds 0
B For Sale Austin Healey 100 Smiths Fuel Gauge, Dual Safety Gauge, Speedometer and Tachometer Austin Healey Classifieds 0
B For Sale Triumph Tr3 Fuel gauge Temp gauge Oil pressure gauge, speedometer tachometer Triumph Classifieds 0
S Speedometer Angle Drive Austin Healey 2
T Wanted WTB 100 / 4 Speedometer Austin Healey Classifieds 0
B Differences between BN2 and BN4 speedometer gears?? Austin Healey 7
F How does overdrive Annulus effect speedometer Austin Healey 10
