Help me fix the Cortina!
Elva164
Hey all,
So those of you who frequent the Racing section may be familiar with the 1965 Lotus Cortina I work on and occasionally race. It's a huge amount of fun and if you haven't seen the videos, feel free to check them out in my sig.
Anywho, we were using the car this past weekend at Summit Point. I was sharing the car with someone, and unfortunately he had an incident during his first session:
We have yet to take a close look at the car, but we're hoping that at the least the suspension towers weren't affected. In the meantime, we're looking for both front fenders, a radiator core support, a headlight grille, headlight trim rings, and a hood for a Mk1 Cortina. We would like to find parts that are straight and almost rust-free, as we want to make the car as perfect as possible.
Feel free to PM me or email at mrspitfire1500@yahoo.com if you have or know of anything we may be able to use.
Thanks,
Mike
Platinum
GAH! That saddens me.
About the only thing I've got left here is a turn-signal lens. And IIRC it's the port side one. :cryin:
Elva164
Elva164
Believe it or not, the parking lights appear to have survived somehow. Maybe because we removed the buckets and riveted the glass to an aluminum plate, who knows. We'll get it back together though...
The good news is that the panels from a regular Cortina should work.
Yeah, this car came with the steel panels so we don't need any of that fancy Aluminum stuff. :smile:
LarryK
Wish I could have stored the ones I had. Room forced my to give them away. Think I am getting close to where they are sitting now, still looking.
Elva164
Elva164
Thanks for the replies guys, I guess I missed them. Updates are that we believe we've found an appropriate steel piece from a LC to fix the outer skin and core support, and we have someone to straighten the inner fender and the chassis rails. Still figuring out how to get everything from California to New York, but we have a possible lead. That is probably the one from Summit and it will unfortunately miss the Jefferson this May... :( Our goal is the English Ford reunion at Waterford Hills, MI in July, but the car should be together before then.
Speaking of! This time around, we aim to make the car as original as possible cosmetically. We want to remove the upside-down GT dash and install an original Lotus one. Does anyone have any parts for a Lotus dash including the brackets? We'd also like to get the "Cortina" hood emblem and chrome surround. Thanks!
gjz30075
Do you have any more info on the English Ford reunion at Waterford? Waterford Hills facebook doesn't say anything about it yet.
Thanks
Elva164
Elva164
Sure- The event is still open to all comers, but will be focusing specifically on English Fords e.g. Cortina, Escort, Capri, etc. Austrailian racer Allan Moffat will be the guest of honor, famous for many types of racing but his first ride was in a Lotus Cortina.
Joel Hershoren--the event organizer--would love to have specialty races (all-FF, Lotus 7 vs. Ginetta, Cortina vs. Pinto, etc.) but that all depends on entries.
The event is July 25-27 and hotels are filling up quick!
Mink TR4/4A Help me fix my reverse lockout... Triumph 3
angelfj1 TR2/3/3A HELP! Need quick fix for missing bonnet hinge pin. Triumph 5
B TR4/4A Some Help with Setting Distributor Triumph 47
N Wanted Help with car identification Other British Classifieds 2
I MGB Help! What is this part for? MG 13
P Please help identify this tourer Spotted 13
C MGB More Weber help needed MG 27
V 96 Chimera help needed TVR 1
V Help with identifying morris eight Other British Cars 12
J MGB help, turn signals do not work MG 3
J MGB HELP, my horn does not work! MG 8
I MGB Alternator help MG 0
Southwarks TR2/3/3A TR2 door help! Triumph 2
P General Tech Positive Earth?? Very confused. A little help? Triumph 19
Texas TR3 TR2/3/3A Convertible top webbing installation help? Triumph 5
apbos The next rabbit hole. Help ID the chassis. Racing 27
R Help With Spridget Speedometers Spridgets 4
apbos Help Identify this car chassis Racing 20
tr6web TR6 Sputtering help Triumph 6
R TR6 Help: Brake Part Source or …. ? Triumph 1
B Help for Old Men Restoration & Tools 15
Basil Admn Note Our neighbors need emergency help Triumph 0
Basil Our neighbors need emergency help Spridgets 0
Basil Admin Note Our neighbors need emergency help MG 0
Basil Emergency help requested for our neighbors Austin Healey 0
B TR6 Help with color and color code / paint recommendation Triumph 4
JohnGone MGB Help getting my 1980 MGB to pass CA smog test MG 19
K TR6 Need help with Mimosa Yellow Paint Triumph 1
Bayless Help please installing bonnet release cable Spridgets 8
T TR2/3/3A Help - Cooling system problem Triumph 7
D TR6 Help with tr6 engine diagnosis Triumph 11
H Wanted MK2 - Please, help needed Jaguar Classifieds 60
D Spitfire 1980 California Spitfire, Help Figuring What To Do With It? Triumph 15
I Bugeye oil leak help Spridgets 4
A TR6 Carburetor help Triumph 5
Darwin GT6 Diff Help Please Triumph 2
J TR2/3/3A Need help with a value for this TR3 please Triumph 6
V VAUXHALL Astra diesel 1.7cdti loss of power 2012. HELP. Other British Cars 1
jehuie Help...replaced my alternator and now my water pump is leaking. Spridgets 16
algot1901 HELP with wheel bearings Other British Cars 1
K TR2/3/3A The guide bolts to help gearbox install? Triumph 19
S MGB Mgb with nissan cylinder head. I am a new member, introduction and help MG 1
T Lotus 7 - help identifying parts Lotus 5
TheRealDestrux MGB 1977 MG MGB need help putting top down MG 1
6 Electrical Help Please Spridgets 7
B MGB Help MG 2
P Help with torquing bolts Restoration & Tools 3
